CRD swirl motor resistor ???? - Page 19 - JeepForum.com
 1Likes
post #271 of 408 Old 03-07-2013, 11:21 AM
Taquache
2007 WK
Thanks everyone, this wouldn't have come around with out Kurt and Shibby Engineering. A big thanks to them for taking on this idea.
If I end up with another daily driver in the future I plan on tearing down and building this jeep to about 400hp or so. That will provide a lot of R&D for new parts
Taquache Motorsports
'07 Jeep Grand Cherokee 3.0L Mercedes CRD 2wd 110k miles and counting Murdered Out - Elephant Hose - Dashhawk - Powdercoat - "CAI"
'07 Fiat 2500 Dually Highly Modified
Taquache is offline
post #272 of 408 Old 03-27-2013, 06:25 AM
r_unda
Just an update. The SMRP has been installed for a month now with no issues. I even took a 530miles trip towing my TJ on a trailer last weekend, no issues there also. The WK did great.
My Jeep isn't getting older, it's getting newer part by part
2011 WK2 HEMI 4x4 Overland
2007 WK CRD 4x4 Limited GDE Tuned
1998 TJ SE
1973 CJ5 - YJ OME 2.5" lift, 33" tires
1951 Willys truck
r_unda is offline
post #273 of 408 Old 04-02-2013, 08:24 AM
segona
2007 XK Commander
I have just sent all the payments via Payal .
2 set of resistor and 2 set if plugs
Wish it could be here as soon as possible .
Thanks a lot ...
segona is offline
post #274 of 408 Old 04-02-2013, 08:28 AM
Taquache
2007 WK
Mine is still working like a champ!! A lot of miles and no issues
Taquache is offline
post #275 of 408 Old 04-02-2013, 06:54 PM
Fasito
2007 WK
Thanks to all you for sharing your knowledge. It seem's I've got the swirl motor problem in my 07 GC CRD but I'm not sure yet. Symptoms are loss of power (could drive back home at 55mph or so for 250 miles), ETC light flashing and yellow engine solid lit on the dashboard. Some oil on the plastic CRD engine cover. After removig the cover, it was a hose unplugged from its position, radial to the left, from the turbo inlet (please see attached image). Plug it in place but obviously, all the symptoms are still present. I'll visit the local Jeep dealer tomorrow but ?How you could positively be sure what the problem is? ?could be some EGR clogging problem too or instead? ?the swirl motor resistor is just as perfect as it seems (fouling the computer with the resistor and nothing else have to be done)? Thanks a lot again.
Fasito is offline
post #276 of 408 Old 04-02-2013, 06:57 PM
Fasito
2007 WK
Sorry, forgot to mention thet the picture is not from my car. I've copyied it from Chirpz's "Swirl Motor Replacement
for Dummies".
In my car there are more oil around (including the electric plug that is very close to the right side of the hose i vertical position).
Regards.
Fasito is offline
post #277 of 408 Old 04-02-2013, 07:33 PM
jediknight
2008 WK
Best way is with a code reader. This is the CCV return hose. I would also check for your engine oil level... Especialy if you've been runing with this hose unpluged for a while, you might have lost a few onces :\
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #278 of 408 Old 04-02-2013, 07:44 PM
Fasito
2007 WK
Thanks Jediknight. I was near the oil change mileage. Checked the oil level, it was low so I added 0.75 litre to raise half the way between min and max level...
Fasito is offline
post #279 of 408 Old 04-02-2013, 09:35 PM
jediknight
2008 WK
There's the elephant hose mod which involve rerouting those ccv gases away from entering turbo inlet ... This way there's no possible oil leak from the intake rubber seal, which seems to be a plausible cause of swirl actuator failure.
post #280 of 408 Old 04-04-2013, 06:41 PM
Fasito
2007 WK
This morning I've tried with the resistor and it seems to go OK. The ETC light went out right away. The swirl motor is very expensive down here (about 750u$ dollars + labor) and I shoul wait about 45 days for it. ?it safe for the motor keep that long the "deleted swirl motor"? It's adviceable to replace it anytime in the future. Thanks you all again.
Fasito is offline
post #281 of 408 Old 04-04-2013, 07:45 PM
Tango.
2008 WK
There is no need for the swirl motor, unless you want to get a very little better gas mileage at low idle speeds. You are better off buying the green diesel tune which is about $700 which will give you better mileage, more power and delete that swirl motor need for the resistor.
Tango. is offline
post #282 of 408 Old 04-05-2013, 02:06 AM
Stuboy
2007 WK
Ordered my plug last week and it arrived in the UK yesterday, Great service, thanks.
Stuboy is offline
post #283 of 408 Old 04-06-2013, 07:18 AM
Fasito
2007 WK
I've drove two days so far with the resistor, city driving mainly and, the mpg seems to have decreased. Thanks for the advise on GDE. Do you have more data to share about it? (other than the available from their website). Regards.
Fasito is offline
post #284 of 408 Old 05-13-2013, 08:10 PM
wkmb
2007 WK
Well it's been 5 days since my crash course in P2015. I have just over 100,000 miles on my 07 WK Ltd CRD and as I drove from work in limp home mode, I too found out that my swirl motor had bitten the dust. Put the code scanner on it when I got home, and got the P2015 code. After reading up on this issue on Jeepforum I immediately contacted Kurt to get my hands on the resistor plug and the aluminum plug for good measure. Took my WK to Suburban Chrysler Jeep in Novi, MI and it took them over 2 days to diagnose what this forum, and this thread in particular, taught me in an hour. I decided to get them to diagnose to roll the dice on my just expired MaxCare 7 yr/100,000 mile extended warranty to see if Chrysler would still cover it, and was very pleasantly surprised to find out they would cover the repair. So I'll put my resistor plug in the glove-box for now. I also got them to order the updated intake with the black seal to hopefully avoid this design defect to re-appear in the form of oil dripping on the swirl motor. Although I was more than ready to bypass the swirl motor, I'll take the repair seeing how it is such a pain to do.
Are there any things I should be checking for once I get it returned? Obviously I want to make sure I have the updated intake with the black seal. I plan on getting underneath since I think I read that the transmission had to be disconnected so want to make sure that a mechanic that's never done a swirl motor replacement before, torqued the bell-housing bolts, the transmission mount bolts. Any thing else obvious I should be checking that others have run into?
wkmb is offline
post #285 of 408 Old 09-09-2013, 06:46 PM
blenderman
Swirl flaps started sticking. Got them worked loose and stuck a resistor plug on. Problem solved. Looks good, simple and better than my tape hack job would have been.
blenderman is offline
CRD Swirl Motor Project Thread Tuco WK Grand Cherokee & XK Commander Forum 381 04-10-2017 01:36 PM
WK CRD: Swirl Motor Question for the experts Drewd WK Grand Cherokee & XK Commander Forum 19 02-12-2013 05:41 PM
Swirl motor delete? Dusan WK Grand Cherokee & XK Commander Forum 11 04-14-2012 09:51 PM
glorious swirl motor jp971x WK Grand Cherokee & XK Commander Forum 48 02-09-2011 03:42 PM
CRD Bad swirl motor symptoms? Bzwth WK Grand Cherokee & XK Commander Forum 9 12-28-2010 01:45 PM
