CRD swirl motor resistor ???? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > CRD swirl motor resistor ????
All Bilstein shocks & struts - Lowest Prices Ever and RuffStuff Memorial Day Sale!Poison Spyder to donate 10% of Memorial Day W/E Sales to R
Unread 06-12-2012, 09:42 PM   #1
ylimits
2008 WK
Ok so i seen this on another thread and i didn't want to high jack it but it sounds interesting to me and I was wondering if anyone else has done it and what does it help with....also how do I hook it up and pics would be great to
And do I need a tune to put it on
I would also get a 4.7K ohm resistor for your swirl motor and you will have one bulletproof WK CRD.
The resistor is connected to the live and signal wires which are red/green and grey on the crd, these are actually the two center connections on the plug, and it is a four pin plug with three wires
ylimits is offline   Reply With Quote
Unread 06-13-2012, 08:39 AM   #2
tnadanzig
2007 WK
That would be me who suggested installing a 4.7K ohm resistor in your swirl motor plug. I was told about this by a fellow member and read about it on the 300C forum. A bunch of guys in UK are doing this and having good results so I figured I would give it a try. I followed the instructions on the 300C forum; they have pictures as well, and have been running it for over a week with zero problems. You unplug the connector at the swirl motor and install a resistor between those two wires and it fools the computer in thinking the motor is still hooked up and working. The swirl valves default to open when the vehicle turns off. This mod keeps the valves open and no more swirl valve issues to worry about.
http://www.300cforums.com/forums/eur...pennies-5.html
This way I have the ultimate CRD setup. No dpf, no egr, and now no swirl motor worries. This motor should last forever. Now I just need to install my methanol injection setup and clean out all the crap in the intake that accumulated before I deleted everything.
Some members have been talking about the GDE tune and how it disables the swirl motor. Well this is a way to get around purchasing that tune and still disable the swirl motor.
I was looking at the wiring diagram for the EGR throttle body and it should be the about the same setup. The throttle body necks down to about 2” with a butterfly valve. It’s supposed to help with egr mixing and flow, but only really reduces flow. However, the biggest offender is the egr duct into the air charge pipe. It a huge restriction in the intake track to help the egr flow into the intake.
2008 3.0L CRD WK LTD - Wifes, GDE DPF Delete Tune, Turbo Resonator Delete, Upgraded Stock Intercooler, Kolak Addcoo Front and Rear Sway Bars, coming soon 3.07 gears & SRT8 Wheels
2007 3.0L CRD WK LTD - Mine, Custom Spooling Tune - Stage 2 Performance DPF & EGR Delete, Custom Cold Air Intake , 3" Intercooler, Turbo Resonator Delete, DPF Delete Pipe, Devil's Own Methanol Injection, SM resistor plug, SRT8 rear spring, stock fronts SRT8 rear sway bar; 255/70/17 Hankook ATM's, dechromed stock wheels
2003 F250 6.0L CCLB - Gearhead Tunes
tnadanzig is offline   Reply With Quote
Unread 06-13-2012, 03:08 PM   #3
tdoster
2007 WK
I am curious the legality of selling a connector for "Emergency Use Only"
One of my biggest fears is being a thousand miles away with the family and travel trailer in tow and having the swril motor go out and truck fall into limp mode while being out in the middle of nowhere. Think if nothing else will make a connector with instructions and soldered to spades and kept in the glove box for when it does happen.
tdoster is offline   Reply With Quote
Unread 06-13-2012, 05:43 PM   #4
TurboDiesel
2008 WK
hmm interesting..
curious to hear more
who is gonna be the guinnea pig?
-]All Blacked Out[-
2008 Jeep Grand Cherokee 3.0 CRD
2" RC lift
255/75R17 BFG KM1's
17" ion alloy rims
15" kicker solo baric L7 w/ Alpine m1000 amp
aftermarket headlights w/5000k HIDs
Red interior LEDs and Red license plate LED
Tinted tails
5% tint over the rear windows
more to come....
TurboDiesel is offline   Reply With Quote
Unread 06-13-2012, 06:18 PM   #5
CustomSpooling2
See tnadanzig's post above. He's been running with the resistor for over a week
Originally Posted by TurboDiesel View Post
hmm interesting..
CustomSpoolingUSA - Customized ECU Tuning for Gas/Diesel European Vehicles www.customspooling.com on Facebook at www.facebook.com/customspoolingusa
CustomSpooling2 is offline   Reply With Quote
Unread 06-13-2012, 07:57 PM   #6
tnadanzig
2007 WK
I will try to get some pictures of my install, but its pretty much the exact same as in the 300C forum. I don't think it would be illegal to sell a connector but I don't see why you would need one. Those companies market as off road only. However, I wouldn't have something like this stored in my glove box. I am running the resistor mod at the moment and I don't ever plan to take it off. If anything I plan to remove the swirl valves from the intake manifolds once I get the time to pull them.
Unread 06-13-2012, 09:17 PM   #7
pixelcodex
2007 WK
Where did you get the resistor? RadioShack? D you put it inside a male plug or have it kind of loose like the one pictured on the 300 forums? How can you tell it worked and the swirl flaps are open? Thanks.
pixelcodex is offline   Reply With Quote
Unread 06-13-2012, 09:46 PM   #8
TurboDiesel
2008 WK
ahh ok i mis-read it
i thought he meant people over there have been running it for a week with no problems
my mistake, reading too fast lol
i would love to see install pics, and yea...how do u know its working? and where did u buy the resistor?
how long was the install?
-]All Blacked Out[-
2" RC lift
255/75R17 BFG KM1's
17" ion alloy rims
Tinted tails
more to come....
Unread 06-13-2012, 11:06 PM   #9
terrasmak
2007 WK
So if i read this properly , you install the resistor and leave the plug off.
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline   Reply With Quote
Unread 06-14-2012, 07:27 AM   #10
tnadanzig
2007 WK
TurboDiesel, I will try to get some pictures probably not till this weekend. We are trying to sell our house so I don’t have much time lately. I will post them as soon as I get them, but it looks just like what they did on the 300C forum.
I know it is working because the plug is no longer connected to the swirl motor. I installed the resistor between the two wires and no DTCs. It didn’t take that long ~ 30 min, but the hardest part was getting the plug out, and then taping the resistor to the plug. I have AutoEnginuity to check and all good. I got my resistor from digikey, but had it for some time in my tool box. I play with some electronics stuff and I luckily had some of the right flavor.
Terrasmak, yes, you leave the plug off and just jumper two wires with the resistor and tape it up.
I would like to come up with a cleaner more permanent solution. I am not sure what I would like to do, maybe cut the plug off and solder the resistor between the wire and heat shrink or find the opposite connector and make my own device. Not sure, but this will work for now.
Unread 06-14-2012, 10:40 AM   #11
BAH101
2008 WK
If you can find a number on the plug, there is a good chance of finding the manufacturer on the Internet.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline   Reply With Quote
Unread 06-14-2012, 11:01 AM   #12
baggee
2005 WK
How did you solved problem with egr valve? How to take it out of sistem without throwing a code or puting engine in limp home program?
baggee is offline   Reply With Quote
Unread 06-14-2012, 11:09 AM   #13
tnadanzig
2007 WK
I am running the Custom Spooling Tune with dpf and egr delete settings.
Unread 06-14-2012, 05:54 PM   #14
TurboDiesel
2008 WK
awesome thanks for the info
thats not bad at all...once u find the right wires....u can buy 100 resistors off ebay for less than $2 shipped lol...i may see what i can find locally.
did u just tape the **** outta it with electrical tape? or what tape did u use?
-]All Blacked Out[-
2" RC lift
255/75R17 BFG KM1's
17" ion alloy rims
Tinted tails
more to come....
Unread 06-15-2012, 09:45 AM   #15
tnadanzig
2007 WK
Yup, I just used electrical tape. I know you can get resistors at Radio Shack, but any electrical supply house should have resistors.
