CRD starting problems - Page 2 - JeepForum.com
post #16 of 31 Old 06-12-2013, 05:06 PM Thread Starter
TurboDiesel
2008 WK
hmm sounds good thanks for the info, ill PM him now
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #17 of 31 Old 06-12-2013, 08:00 PM
jediknight
2008 WK
A while ago i've read somewhere that the volkswagon tdi series under bosch edc16 ecu are known to have similiar issue called hot start issue. It is solved by an update on the ecu done at the dealership, but ! this would be a premier if it happends to the jeep crd also... So i dont think this could be your issue.
SKIM module (where you plug you key in) could also act funny like that.
Finaly starter / starter relay.
If you have a tune try reload ori and see what happends, but like i said i'll be surprise that it has something to do with the tune.
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #18 of 31 Old 06-12-2013, 08:03 PM
fishinbama
2007 WK
Oh yes, I remember that now. Almost had forgotten it. I'm trying to remember what I did to blow that relay. I remember there were some other random things that were on that circuit also.
2007 limited crd 2wd, 3.07 ratio, GDE eco tune, dpf delete, tnadanzig resonator delete
fishinbama is offline
post #19 of 31 Old 06-12-2013, 08:08 PM Thread Starter
TurboDiesel
2008 WK
yea starter relay is $14 so i might change it anyways...
i should see about reloading my tune, i emailed Keith and he hasnt heard of anyone having problems..
i remote started this morning and tried to take a video but for some reason it wouldnt record sound lol
ill remote start again tomorrow and see if it starts fine then maybe start with the actual key
i have heard that sometimes the truck has a hard time getting signal from the key causing it to crank for a prolonged time..
so many possibilities!
post #20 of 31 Old 06-12-2013, 08:12 PM
jediknight
2008 WK
Oh ... Is your issue only when using wireless start ? If so this could also be WCM
post #21 of 31 Old 06-12-2013, 08:14 PM Thread Starter
TurboDiesel
2008 WK
it might be only when i start with key..but who knows? might be a random time it starts up fine when i use remote start..
post #22 of 31 Old 06-12-2013, 08:14 PM Thread Starter
TurboDiesel
2008 WK
its not always a long crank before it starts, sometimes its 1 second and rare times its more...
post #23 of 31 Old 06-12-2013, 08:28 PM
jediknight
2008 WK
Can also be air filter ...
post #24 of 31 Old 06-12-2013, 08:34 PM Thread Starter
TurboDiesel
2008 WK
yea i forgot to look at that, changed the fuel filter...
post #25 of 31 Old 06-13-2013, 11:06 AM
Radcrd
2007 WK
Are you parking on a slope? VW TDI's had an issue with Fuel filter fittings sucking air. If you were parked on a slope with the nose up air would suck into the system and all the fuel would make its way back to the tank. Resulting in long / hard start until the fuel lines refilled themselves. Make sure the filter fittings are not sucking air.
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #26 of 31 Old 06-13-2013, 12:48 PM Thread Starter
TurboDiesel
2008 WK
Just did filter and tightened everything
But ill double check
No parkin on hills
post #27 of 31 Old 06-13-2013, 05:34 PM Thread Starter
TurboDiesel
2008 WK
P1648 soft code
Which seems to be glow plug module
No cel on the dash but with my gde tool picked up the code
Wonder how hard that is to change??
post #28 of 31 Old 06-13-2013, 05:44 PM Thread Starter
TurboDiesel
2008 WK
or apparently could be:
P1648 Battery Condition Monitor (BCM) Module Communication Signal Circuit Problem
P1648 Motor Control Module (MCM) Communication Signal Circuit Problem
or something with my key? but even remote start had a long crank this morning
post #29 of 31 Old 06-14-2013, 09:28 AM
jediknight
2008 WK
Originally Posted by TurboDiesel
P1648 soft code
Not hard at all there's actually a youtube video for this ...
post #30 of 31 Old 06-14-2013, 05:40 PM Thread Starter
TurboDiesel
2008 WK
yea looks crazy easy
i hear theres a glow plug relay somewhere but cant find anything about it online
once i figure out if there is or not
ill either replace said relay or replace the module...
