CRD starting problems - JeepForum.com
post #1 of 31 Old 06-10-2013, 01:49 PM Thread Starter
TurboDiesel
2008 WK
2008 CRD 130k KMS - dpf delete with GDE tune
Had starting problems a couple weeks ago and thought it was the battery.
Changed it and it was good for abit but has started again..
Need to do fuel filter this weekend
Only seems to happen in the morning and no CEL
Battery? Starter? Injector? Glow plug?
Any ideas?
Any link to when the starter is located on the CRD?
Thanks
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #2 of 31 Old 06-10-2013, 02:38 PM
suzieque
2008 WK
the starter is a bugger to get at in the north american jeeps
http://www.jeepforum.com/forum/f67/2...eeded-1519587/
if it turns over well but does not start, I'd be more inclined to check for a fuel related issue.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #3 of 31 Old 06-10-2013, 03:18 PM
BAH101
2008 WK
Crankshaft position sensor?
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #4 of 31 Old 06-10-2013, 03:46 PM Thread Starter
TurboDiesel
2008 WK
It turns over eventually just takes a couple seconds
Was bad untill i changed my battery but has gotten long again... Not as bad as before the battery tho
I need to do the filter.. But just weird it only happens in the morning
post #5 of 31 Old 06-10-2013, 04:56 PM
suzieque
2008 WK
oh so you turn the key and nothing happens for a few seconds? does sound like a starter to me.
suzieque is offline
post #6 of 31 Old 06-10-2013, 06:48 PM Thread Starter
TurboDiesel
2008 WK
was just at a local auto parts place and apparently there is a starter relay that sometimes screws up??
couldnt see if in my manual but didnt seem to show any relays so i may take a look at that
also gonna hook it up to a tester today i believe, should be able to check the starter apparently...
just got a thing in the mail that i can trade mine in and get more than market value and stuff....seems so tempting at this moment :P
post #7 of 31 Old 06-10-2013, 07:38 PM Thread Starter
TurboDiesel
2008 WK
did u guys fill your new filter with diesel before putting it in?
or can u just hook it all up, turn the key to ON position and wait till it fills and then start it?
or hook it up and turn it to on till it squirts out the top? lol
might do it tomorrow
post #8 of 31 Old 06-10-2013, 08:56 PM
jediknight
2008 WK
I do the second option i.e. bleed it with the use of the electrical fuel pump ... switching the key at On.
I dont think this has something to do with your issue thou.
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is online now
post #9 of 31 Old 06-10-2013, 11:06 PM Thread Starter
TurboDiesel
2008 WK
yea i got it installed....guess ill see tomorrow..
took 45 minutes...not bad for not alot of mechanical knowledge
post #10 of 31 Old 06-11-2013, 09:52 PM Thread Starter
TurboDiesel
2008 WK
bump
any other ideas?
gonna check tomorrow to see if my new batter is a dub
then its either wait till it will never start and i get a CEL or start replacing **** like glow plugs and starter
any chance the starter relay could be messed up?
post #11 of 31 Old 06-11-2013, 10:30 PM
suzieque
2008 WK
I suppose you cleaned the terminals of the battery. I custom made an extra 2 gauge negative battery cable between the battery and the engine block, kind of a hyper-grounding experiment, not because I was having issues.
I remember quite a while ago another crd owner had a defective fuse or fuse relay. I will hunt for that thread.
suzieque is offline
post #12 of 31 Old 06-11-2013, 10:40 PM
Drewd
It is summer out there, glow plugs aren't typically needed or used above 45 deg F so replacing them now would be a waste of time.
Remove fuel line leaving the fuel rail pressure relief valve and plug it. Install a cheap clear tubing/line from a hardware store to the pressure relief valve on the fuel rail and (cleamp it down) and feed into a fuel storage container. Start engine and measure fuel flow from this relief valve. You should not have any fuel flowing out of it while cranking (a no-no) and very little if any while engine is idling. A bad pressure relief valve on high fuel pressure rail is a common cause of hard starting.
Starter should be fine but cranking for long periods of time can kill it.
Is your battery good? If you are using OEM battery, replace it ASAP before you troubleshoot further. Diesels are hard on batteries.
Drewd is offline
post #13 of 31 Old 06-11-2013, 11:01 PM Thread Starter
TurboDiesel
2008 WK
battery is 2 weeks old
worked great for a week after i replaced it but has gotten worse [not as bad as before the battery tho]
dont really have a problem when the engine is warm either..
i pondered just paying the $14 for a new starter relay to see if that helps..
suzieque i always pondered doing the "big 3" upgrade but never got around to it..
thanks for the help thus far BTW
ill check into the fuel line there too
post #14 of 31 Old 06-11-2013, 11:04 PM Thread Starter
TurboDiesel
2008 WK
how often is a brand new battery a dub?..if thats the problem i would be so happy lol
post #15 of 31 Old 06-12-2013, 08:57 AM
suzieque
2008 WK
I have not had a battery fail that quick. I suppose you could get it load tested. I did not do the full "big 3" upgrade, I just did the one ground cable.
By the way, it was "fishinbama" that had the relay issue on his CRD, but I'll be dammed if I can find his original thread now. Perhaps send him a PM and post back what he says. At the time, I remember thinking "I gotta buy one of those relays and through it in the toolbox just in case".
suzieque is offline
