CRD RPM climb but no movement - JeepForum.com
post #1 of 8 Old 08-09-2015, 01:19 PM Thread Starter
TurboDiesel
2008 WK
hey
ive had a couple times not where i have gone to punch it and my jeep goes to about 3k RPM or more but i move nowhere
ive had it happen while driving and didnt think too much of it, assumed maybe crazy turbo lag
but today pulling out of a driveway i went to step on it and my RPM shot up but i wasnt going anywhere, i let off the throttle then went back into it softly and got going again
i have no codes with my GDE scanner or anything
anyone else experience this???
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #2 of 8 Old 08-09-2015, 01:34 PM
kwikrnu
2007 WK
I have many times. I don't know what it is. I'd like to change out the transmission valve body, rebuild it, and stick in some blue top amg solenoids to see if that takes care of the problem... I just hope I don't get into a wreck before I cam fix it as it is intermittent.
I started THIS thread about it awhile ago.
2007 WK CRD QDII,OME / bilstein 5100 lift,K&N intake,GDE hot tune,hidden winch mount Warn vr12000.
kwikrnu is offline
post #3 of 8 Old 08-09-2015, 02:43 PM Thread Starter
TurboDiesel
2008 WK
hey i am in that thread! hahah i shall bump it, thanks
post #4 of 8 Old 08-11-2015, 03:55 AM
Tuco
Tuco's Avatar
2007 WK
To start, Id probably take it to a dealer to have the fluid level checked. And change fluid/filter if its near time. Or buy the tools needed to check level, its not a simple dipstick.
07 WK CRD Limited
Tuco is offline
post #5 of 8 Old 08-11-2015, 05:24 AM
ggrassmid
2008 WK
Mine would do that periodically, not as bad, but i check the fluid level and it was about 1/2qt low. Filled it up and so far has been great! By 1/2qt I actually used the measured dipstick and used only half of a quart to get me to the correct measured area. Once I added in the 'cold' fluid, I drove it for another 10min to mix it in and checked it to verify it was correctly filled.
Mine was low due to a couple pan screws being a little loose. Tightened them up, cleaned the pan off, and haven't had a problem since.
ggrassmid is offline
post #6 of 8 Old 08-11-2015, 04:41 PM Thread Starter
TurboDiesel
2008 WK
i did my tranny change close to 3 years ago, never seemed to have an issue like this
i have had it where at cruise speed i punch it and when it goes to change gears it fades and then takes off
last time i was under, didnt notice anything around the tranny...i wonder if i should just buck up for a miller tools dipstick or just buy a 3' zap strap and start from there
im at 168xxx KMS so i still have another year and a half before i have to do another change...unless of course there is a problem then i will do it anyways cause i dont remember it being overly expensive
post #7 of 8 Old 08-14-2015, 03:47 PM
kwikrnu
2007 WK
I checked the fluid today with a $10 generic dipstick off amazon. I measured the fluid with a ruler because the markings on the dipstick didn't correspond with the actual length. I checked the temp with a scan tool while in gear. It was 3 cups low, or 20mm according to my measurements and I added mopar atf +4 fluid. We'll see if that helps me.
kwikrnu is offline
post #8 of 8 Old 08-14-2015, 11:02 PM Thread Starter
TurboDiesel
2008 WK
mine hasnt had an issue since, and that was the first time in a long time it had happened
my cousin actually has a wayyy worse issue
his jeep just wont shift or anything and he has to turn it off and back on again to be able to drive
rpms go up but there is 0 movement
