CRD Questions: Swirl Motor, PVC Valve, and Glow plugs - Page 2 - JeepForum.com
post #16 of 41 Old 06-16-2011, 01:59 PM
Chirpz
Chirpz's Avatar
2007 WK
Orange seal
Thanks for the added info, Scooter. I did not know the specifics of the problem until I examined my seal and it became obvious. I did buy a new seal today but it looks the same. Since I'm doing an elephant hose, I hope it will no longer be an issue.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #17 of 41 Old 06-16-2011, 04:03 PM
SSF556
2008 WK
I do not think you can buy the seal by itself...you need to buy the entire air tube with the black seal.....
Orange = bad
Black = good
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #18 of 41 Old 06-16-2011, 05:09 PM
rhusak
2017 WK
Hi All..
Does anyone have the part number for the improved tube and seal? Is there an on line resource to buy this at a more reasonable price..
Thanks a bunch..
Ron
2017 Grand Cherokee Overland
Livin at 9200 Feet lookin down at ya!
rhusak is online now
post #19 of 41 Old 06-16-2011, 06:36 PM
SSF556
2008 WK
Originally Posted by rhusak View Post
hi all..
Thanks a bunch..
Ron
53013672ae
2008 CRD QT2
SSF556 is offline
post #20 of 41 Old 06-16-2011, 06:51 PM
Robert J. yates
Orange = bad
Black = good
The way the improved "black" seal interfaces with the intake tube is completely different which creates the need for the new intake tube. You need to buy the entire assembly.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #21 of 41 Old 06-17-2011, 05:36 AM
LJS8510
LJS8510's Avatar
2015 WK
here is what I think is the original thread on this issue
http://www.jeepforum.com/forum/f67/c...9/#post7983033
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #22 of 41 Old 06-17-2011, 01:19 PM
suzieque
2008 WK
I examined my air intake hose today while putting my Jeep back together. Take a look at the gasket where the intake hose connects to the turbo. That's a factory defect as far as I can tell, I don't think it has ever been removed. As you can see, the V pattern at the bottom edge would allow oil to drip right out and right on top of the swirl motor.
my factory seal was also damaged from being forced on when the tube was not square to the turbo. this seems to be a common issue, I blame the jeep assemblers, not mercedes, since i think the air tube is installed on the jeep assembly line.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #23 of 41 Old 06-17-2011, 03:45 PM
Chirpz
Chirpz's Avatar
2007 WK
Swirl Motor Oil Inside
This will be my last pictures of this little servo motor. This is the 4th puddle of oil that has drained out of it. Finally, I ripped the lid off so all can see how it is made inside.
It looks a lot like the inside of an RC airplane servo and has the same function...only it is bigger and stouter. In the second picture you can get the basic idea how it looks if you ignore the holes that I bored in it to aid in removing the swirl clips.
Chirpz
Chirpz is offline
post #24 of 41 Old 01-17-2012, 09:01 PM
bobholthaus
2007 WK
My dealer just did $3800 in repairs on engine at 82,000. I bought the jeep new and it has been maintained to book specs. The dealer doesn't do much CRD work so they had the jeep 21 days. Took entire engine out twice (because at 14 days when I picked it up the interior was filling with exhaust fumes). Letter going to Chrysler this week. I'm at 84478 miles and my extended warranty ends at 85k. Tonight the dash lights all,came on three times in two minutes while driving, like I had turned the key off. Anyone know what this is? This thing is a POS in my opinion. I've had tons of issues.
'14 GC Overland Diesel
bobholthaus is offline
post #25 of 41 Old 01-17-2012, 11:29 PM
Chirpz
Chirpz's Avatar
2007 WK
Sad story for sure. You did not say in our post exactly WHAT they were trying to fix.
What was their diagnosis?
Chirpz
Chirpz is offline
post #26 of 41 Old 01-18-2012, 08:41 AM
bobholthaus
2007 WK
Sorry, I should have mentioned that my $3800 in repairs was the swirl motor issue. The car went into "limp mode" and I could only go 35 mph on the highway. That's what got me to the dealer. I'll post all of my issues later when I finish my letter to Chrysler.
post #27 of 41 Old 01-18-2012, 09:06 AM
SSF556
2008 WK
Hey Bob...I have yet to be get bite by the swirl motor issue...but every letter to Chrysler helps. $3800 is absolutely insane for that specific project...was there more done?
I think the swirl motor is like $250 dollars and a competent mechanic should be able to remove and replace in at least 8 hours...lets give them 10 hours just in case. Add in some additional parts that he may break.
Swirl motor = $250
10 hours x $100 = $1000...and I know some shops the hourly rate is a lot less than $100 per hour.
Misc Parts and Tax = 200
That adds up to roughly $1450...give or take a few dollars.
Where did they get $3800 from?
2008 CRD QT2
SSF556 is offline
post #28 of 41 Old 01-18-2012, 01:43 PM
bobholthaus
2007 WK
Here are my notes from that repair:
- There are valves in the intake manifold - stopped up with greasy substance - actuator moves the valves and they get stuck and causes loss of power - took out engine/transmission and turbo - new manifolds and new actuator and new EGR Valve -
Parts: $2045.29
Labor: $1228.75
Rental: $560.00
21 days of rental car as well.
If you read some of these posts, I recall seeing others experience the same costs. It's incredible. For that one repaid, they had the engine and transmission out of the vehicle twice in 21 days. There were a bunch of gaskets leaking after the first repair, having them to take it all out the second time.
Since I bought the vehicle, I've had: the entire front axle and transfer case replaced, the entire AC system (literally the entire thing, complressor, etc - took three visits to get it all complete), most of the elctronics in the dash, the autostick transmission lever, both front window switches twice, the rear pinion seal, two or three of the glow plugs have been replaced, and a number of other things that I don't have spelled out. Almost all of these items listed happened after the 36,000 mile warranty expired. Thanksfully, I have a Chrysler extended warranty, or I would have paid almost $10,000 in repairs (the axle and differential were like $2000 and the AC I think he told me was like $2000). Since I bought this Jeep new, the dealer has had it more than 2.5 to 3 months for all of the service. It's crazy. I had a 2002 Grand Cherokee that I bought new and had the exact same kind of issues, all starting right after the factory warranty expired. On that one, I had a non-Chrysler warranty and when I sold the car I called the warranty place to have it transferred and the guy said, "Well, you've gotten your money out of this one." When I asked how much had been charged to it, it was like $7000 in repairs (from 36,000 to 85,000 miles, which for me, was about 2.5 year - almost 100% highway miles too). So, I'm sending a letter to Chrysler asking them to extend my extended warranty to 100,000 for all of the troubles I've been through. Dealing with rental cars each time, having to take my car back to the dealers repeatedly, it has been enough to drive me crazy. Thankfully, the Chrysler extended warranty ($0 deductible) provides for a free loaner car (which is one of the main reasons I bought it), but the time I've wasted on this vehicle has been incredible. My friends all think I got a lemon. By the way, I am 39 years old with two young kids, so it's not like I'm out abusing this vehicle. The outside and inside look just about as good as it did the day I bought it (I'm in real estate and development and have customers in my car all of the time). So I'm fed up, and I've been a repeat Jeep client. I hope that they extend some good will towards me. If they do, I'll drive it another year and then dump it right before the warranty expires. If they don't, then I may be dumping it sooner than later. I'm too scared to own this car while not under warranty.
post #29 of 41 Old 01-18-2012, 02:03 PM
Chirpz
Chirpz's Avatar
2007 WK
Swirl motor = $250
Well, that low price you are quoting depends on whether or not your "mechanic" accidentally breaks the fragile linkage on the manifolds. If he does, then you have to replace the manifolds at over $700 a pop and then there is more time and trouble so more labour. I guess the key word is competent.... but stuff happens.
When I took mine in to the dealer, they told me 1238.00 to replace the Swirl motor BUT if we accidentally break the linkage it could go as high as $4000.00. That's when I decided to have my own accidents and do the job myself. Which I did with help from the friendly people on this forum.
Chirpz
Chirpz is offline
post #30 of 41 Old 01-18-2012, 02:26 PM
SSF556
2008 WK
Parts: $2045.29
Labor: $1228.75
Rental: $560.00
Damn....
2008 CRD QT2
SSF556 is offline
CRD Swirl Motor Project Thread Tuco WK Grand Cherokee & XK Commander Forum 381 04-10-2017 02:36 PM
WK CRD: Swirl Motor Question for the experts Drewd WK Grand Cherokee & XK Commander Forum 19 02-12-2013 06:41 PM
glorious swirl motor jp971x WK Grand Cherokee & XK Commander Forum 48 02-09-2011 04:42 PM
CRD Bad swirl motor symptoms? Bzwth WK Grand Cherokee & XK Commander Forum 9 12-28-2010 02:45 PM
Swirl valve parts mr12volt WK Grand Cherokee & XK Commander Forum 25 08-01-2010 02:59 PM
