CRD Oil Test Results - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > CRD Oil Test Results
ROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO April Instant Rebate: Up to $75 off Flowmaster Products!50% Off Sale at KrawlOff-Road.com
Unread 06-27-2008, 11:28 PM   #1
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Says it all...
TONY: We haven't tested too many of these new 3.0L CRD engines so we are still building the averages file for them. You had this oil in use for 10,476 miles and the wear metals we found in it very close to averages, which are based on a 5,000-mile oil change interval. The oil's TBN was 1.8, which means there was a little active additive left but not much. The oil's viscosity was high for a 5W/30 reading in the 10W/30 range. No gas or anti-freeze was found and both air and oil filtration (see silicon & insolubles) were normal.
Try ~11,000 miles for your next oil change & check back.
Full pic of report here
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | Provent MBRP XP Exhaust | New Intake Tube & Seal + EHM | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | 100,000 Mile Club | Dogpiled Club | pre-N23 FDCM |
Last edited by wookiee; 01-07-2010 at 10:50 AM.. Reason: tried posting the picture...
wookiee is offline   Reply With Quote Quick reply to this message
Unread 06-28-2008, 06:31 AM   #2
jmelgin
Very interesting! How much does it cost for the analysis?
[B]'08 JK Wrangler X[/B] - Jeep Green, Dual Tops, 5.7L Hemi, 6-spd, 3" Black Diamond lift, 35x12.50 BFG Mud Terrain KM2's, ProComp 1079's.
[B]'08 WK Grand Cherokee Overland CRD[/B] - Steel Blue
[B]'05 KJ Liberty[/B] - Black
jmelgin is offline   Reply With Quote Quick reply to this message
Unread 06-28-2008, 07:41 AM   #3
FanofallDiesels
Tony,
What brand of oil are you running?
Jeff
2007 Grand Cherokee 3.0 CRD
2003 Ford Excursion 6.0L
2001 VW Golf TDI
1996 John Deere 455
FanofallDiesels is offline   Reply With Quote Quick reply to this message
Unread 06-28-2008, 08:16 AM   #4
johnniebravo
2008 WK
the cost of the analysis is $25 and an extra $10 for TBN. I was going to do one on my CRD but will hold off now.
If you call them they will send you a box of bottles for future samples. I have done around 6 samples with them and they are great.
Maybe I will send my next one in just to help them build a base for the CRD.
I'd also like to know what oil you are/were using.
2008 CRD GC
johnniebravo is offline   Reply With Quote Quick reply to this message
Unread 06-28-2008, 09:16 AM   #5
Section106
I had mine done too. I'm running B100 in my 08 CRD and was worried about fuel dilution with the DPF regen issue. Here's what Blackstone wrote:
WILLIAM: Slightly high silicon was found in this initial sample from your Mercedes Benz engine, but everything else looks normal. Silicon can be from airborne dirt getting past the air filter, so you might want to have that checked. Wear metals were generally around average, so the silicon may be additive instead of dirt (dirt causes higher metals). Regardless, the engine in your Grand Cherokee looks good and is mostly past wear-in already. That's impressive. They must have worn white gloves when they built this one. The TBN read 5.3, still strong. Try 5000 miles next.
I wrote 'was worried" because after reading these results I think it's much ado about nothing. I changed the oil at 4282 miles because I had nothing else to do that day at automotive lab. I'll change again at 5,000 and then go to 6,000 and so forth.
Section106 is offline   Reply With Quote Quick reply to this message
Unread 06-28-2008, 11:00 AM   #6
magellan
Here"s mine:
magellan is offline   Reply With Quote Quick reply to this message
Unread 06-28-2008, 12:40 PM   #7
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Originally Posted by FanofallDiesels View Post
Tony,
Jeff
That last oil change was a free one from the dealer.
I'm now running the stuff from germanfilters and will have that tested as well.
Unread 06-30-2008, 02:31 PM   #8
johnniebravo
2008 WK
if it is the same as my dealer, it is the mobil 1 5w-30 ESP.
2008 CRD GC
Unread 07-02-2008, 01:58 PM   #9
boxcab
boxcab's Avatar
2007 WK
M1 ESP 5W-30 good for 9000 miles
I just got back the results for my latest sample. 9490 miles on Mobil 1 ESP 5W-30 (MB 229.51) and 15,637 miles on the Jeep.
TBN has dropped from 4.66 at 6,249 miles to 2.18, abnormal range.
Oxidation increased from 21 to 25, critical range.
Iron increased from 29 ppm to 44 ppm, just shy of abnormal range.
Boron dropped from 145 ppm to 121 ppm.
Soot increased from <0.1% to 0.1%, still less than the 0.3% peak I've seen.
Viscosity unchanged from 11.4 cS to 11.5 cS.
All other values are essentially unchanged. Next week I'll change the oil to Amsoil AFL 5W-40 and finally hook-up my bypass filter.
Doug
2007 WK CRD
boxcab is offline   Reply With Quote Quick reply to this message
Unread 07-02-2008, 03:04 PM   #10
Two questions:
[1] Which brand cone filter are you using?
[2] Is this your first analysis since changing the filter?
---- is offline   Reply With Quote Quick reply to this message
Unread 07-02-2008, 07:48 PM   #11
magellan
Which by-pass filter do you have? Let us know how the install goes, esp. on the return line. I plan to add one soon.
Unread 07-03-2008, 01:59 PM   #12
boxcab
boxcab's Avatar
2007 WK
10/16/07: Factory fill sampled and changed at 6,147 miles.
5/20/08: First oil change sampled at 12,396 miles, with 6,249 miles on the oil.
5/23/08: I changed the filter at 12,506 miles, with 6,359 miles on the oil.
6/17/08: Last oil sample taken at 15,637 miles, with 9.490 miles on the oil.
Cone filter is Amsoil's largest, EAAU3090-EA. I fitted it directly to the the MAF housing. In fact, it's so long that it just touches a protrusion on the back of the headlight assy, requiring the judicious use of some foam pipe insulation to prevent a nasty rattle.
The bypass filter is the Amsoil EABP110 10" (2 quart) mounted to the BMK-11 mount. I attached this to the fender behind the coolant tank using a sliding bracket I made from 80/20 tubing and some tooling components.
I hope to get to all of this next week, at which time I'll take pictures.
Doug
2007 WK CRD
Unread 07-03-2008, 02:16 PM   #13
Ridin' Around
You can have oil samples done through OAI, also. They test for TBN as part of the test. The tbn you have listed at 1.8 seems low. I sell the postage paid sample kits for $27.00. PM me and I will get you one. I included the link to Amsoil's oil testing page and the OAI page. Looking forward to seeing the By-pass setup pictures. I have some on my website of a 4.0L we installed a single filter kit on. my website link is in my signature, then go to the Jeep & off-road page for those photos.
http://www.amsoil.com/redirect.cgi?z...px?category=22
http://www.oaitesting.com/
Ridin' Around is offline   Reply With Quote Quick reply to this message
Unread 11-20-2008, 11:07 AM   #14
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Here's my test from this week with 7,578 miles. I drove in 120 weather on and off road, high speed highway & some stop and go. Looks like it's holding up quite well. I'll change it at 11,000 miles.
This was using the oil from germanfilters.
Unread 11-20-2008, 02:44 PM   #15
johnniebravo
2008 WK
Wow, that UOA looks pretty good! Got some life left with a TBN of 4.9. Thanks for sharing.
Just for clarification, this is with the ELF LSX 5w-30, correct?
2008 CRD GC
