CRD Oil Loss. - JeepForum.com
post #1 of 5 Old 02-15-2012, 12:08 PM Thread Starter
smoothone12
2008 WK
CRD Oil Loss.
Just curious to find out if any CRD owners have to top up their oil midway through oil change periods. It seems that I have to top up the oil (about a litre) I don't see any visible leaks anywhere. I wait 30mins after I run it so oil settles before I check. Any other ideas.
smoothone12 is offline
post #2 of 5 Old 02-15-2012, 04:11 PM
suzieque
2008 WK
well, I've started following my dealer's advice now about oil and the CRD. You only fill up the engine to right between the empty and full marks on the dipstick and then in theory, you should never see the oil level change between oil changes. that is their theory, I'm only 5000km since my last oil change and I've not had to add any oil, the oil stil reads right between the empty and full marks on the dipstick.
now I don't drive it hard, that may have a bearing on oil consumption, I know my car uses no oil until I drive over 120 km/hour on the highway.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #3 of 5 Old 02-15-2012, 08:19 PM
Tango.
2008 WK
Well I only wait about 30 seconds (not minutes) to check my oil level.
No noticeable loss.
What oil do you use? I run the Mobil-1 Europe 0W-40. Syn.
Tango. is offline
post #4 of 5 Old 02-15-2012, 09:33 PM
suzieque
2008 WK
i run 5w30 ESP (229.51 spec) mobil1
suzieque is offline
post #5 of 5 Old 02-16-2012, 08:44 AM
Mickey63
2006 WK
I normally have to top up my oil about 1/2 to 3/4 of a litre mid service interval.
I put it down whatís been blown out the crankcase into the turbo intake,
I have a Provent to stop it going into the turbo intake, it collects into a small bottle which I empty now and again.
TOP TIP, make sure you put the oil filler cap on fully, then double and triple check it after you top up the oil,
it makes one hell of a mess if itís even one little bit loose. I had oil dripping from everywhere after a 10 mile trip...... it's not funny
Mickey63 is offline
oil
At a loss, what's next? coastieZJ ZJ Grand Cherokee Forum 6 08-15-2011 01:46 PM
why the 5 hp loss? 96grandcherokee ZJ Grand Cherokee Forum 11 09-06-2005 09:38 PM
Oil Loss jeeper31 ZJ Grand Cherokee Forum 12 04-09-2005 10:02 PM
loss of oil? nineseventhree ZJ Grand Cherokee Forum 9 06-10-2003 03:34 PM
help please! I'm at a loss. uwgKA ZJ Grand Cherokee Forum 5 07-19-2002 02:44 PM
