CRD oil dipstick - JeepForum.com
post #1 of 11 Old 11-22-2013, 10:29 AM Thread Starter
SSF556
2008 WK
CRD oil dipstick
CRD guys....I am getting different readings on my oil dipstick....one side shows oil level between the full and fill mark. The other side shows oil at the fill level.
This was check after sitting all night. Just curious what everyone else is seeing.
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #2 of 11 Old 11-22-2013, 05:15 PM
Drudgery1971
2007 WK
I'll check tomorrow AM once it's light out scottr29. I recall talking about this a couple years ago as there seemed to be a weird coating on the dipstick that made it harder to read - almost like an anti-stick plating or coating. Will take some pics too.
2007 WK Limited 3.0 CRD - Stock (Mine)
2010 XK Sport 5.7 Hemi - Stock (Wife)
Drudgery1971 is offline
post #3 of 11 Old 11-22-2013, 05:49 PM
Chirpz
Chirpz's Avatar
2007 WK
I have had this happen on occasions. Don't know why. It also happens on my old 91 XJ. Annoying.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #4 of 11 Old 11-22-2013, 06:29 PM Thread Starter
SSF556
2008 WK
thanks...also i have the numbers facing forward on the yellow tip of the dip stick
2008 CRD QT2
SSF556 is offline
post #5 of 11 Old 11-22-2013, 06:52 PM
suzieque
2008 WK
I have not looked or noticed different readings, i will check this out tomorrow.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #6 of 11 Old 11-23-2013, 02:16 PM
Drudgery1971
2007 WK
Just checked - oil is at 7.5k miles and changing tomorrow but it looks the same on both sides - had driven for about 5 minutes before checking after it was sitting for only a couple minutes, so probably more oil would come down out of engine if had waited longer . Sorry so blurry - was freezing. I put numbers facing forward - front end of Jeep. I'll check it cold before driving tomorrow AM and see any difference.
post #7 of 11 Old 11-23-2013, 03:51 PM Thread Starter
SSF556
2008 WK
Thanks
2008 CRD QT2
SSF556 is offline
post #8 of 11 Old 11-23-2013, 04:49 PM
suzieque
2008 WK
Mine looked the same on both sides.
suzieque is offline
post #9 of 11 Old 11-24-2013, 02:26 PM
Drudgery1971
2007 WK
Checked mine cold this am... about 30 F, driveway is pefectly flat and it was at about 80%-85% of max and matched both sides.
post #10 of 11 Old 11-26-2013, 09:24 AM
Radcrd
2007 WK
The dipstick is strange on these.. sometimes I pull it out and it shows nothing! I put it back in and remove it again and get a reading. Had me scared the first time I checked it when I drove it home from the dealer and it showed empty! thought there was something seriously wrong... I think there may be an air pocket that gets created in the base of the dipstick tube when the engine is running. Then once you pull out the dipstick it allows air to exit, then you get a reading. I pull it, clean it, re-insert it then check again to get accurate reading.
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #11 of 11 Old 11-26-2013, 10:09 AM
BAH101
2008 WK
Just like holding you finger over the end of a straw. There is a O ring at the top
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
