-   WK Grand Cherokee & XK Commander Forum (http://www.jeepforum.com/forum/f67/)
-   -   CRD oil dipstick (http://www.jeepforum.com/forum/f67/crd-oil-dipstick-1816882/)
SSF556 11-22-2013 10:29 AM
CRD oil dipstick
CRD guys....I am getting different readings on my oil dipstick....one side shows oil level between the full and fill mark. The other side shows oil at the fill level.
This was check after sitting all night. Just curious what everyone else is seeing.
Drudgery1971 11-22-2013 05:15 PM
I'll check tomorrow AM once it's light out scottr29. I recall talking about this a couple years ago as there seemed to be a weird coating on the dipstick that made it harder to read - almost like an anti-stick plating or coating. Will take some pics too.
Chirpz 11-22-2013 05:49 PM
I have had this happen on occasions. Don't know why. It also happens on my old 91 XJ. Annoying.
SSF556 11-22-2013 06:29 PM
thanks...also i have the numbers facing forward on the yellow tip of the dip stick
suzieque 11-22-2013 06:52 PM
I have not looked or noticed different readings, i will check this out tomorrow.
Drudgery1971 11-23-2013 02:16 PM
1 Attachment(s)
Just checked - oil is at 7.5k miles and changing tomorrow but it looks the same on both sides - had driven for about 5 minutes before checking after it was sitting for only a couple minutes, so probably more oil would come down out of engine if had waited longer . Sorry so blurry - was freezing. I put numbers facing forward - front end of Jeep. I'll check it cold before driving tomorrow AM and see any difference.
SSF556 11-23-2013 03:51 PM
Thanks:2thumbsup:
suzieque 11-23-2013 04:49 PM
Mine looked the same on both sides.
Drudgery1971 11-24-2013 02:26 PM
Checked mine cold this am... about 30 F, driveway is pefectly flat and it was at about 80%-85% of max and matched both sides.
Radcrd 11-26-2013 09:24 AM
The dipstick is strange on these.. sometimes I pull it out and it shows nothing! I put it back in and remove it again and get a reading. Had me scared the first time I checked it when I drove it home from the dealer and it showed empty! thought there was something seriously wrong... I think there may be an air pocket that gets created in the base of the dipstick tube when the engine is running. Then once you pull out the dipstick it allows air to exit, then you get a reading. I pull it, clean it, re-insert it then check again to get accurate reading.
BAH101 11-26-2013 10:09 AM
Just like holding you finger over the end of a straw. There is a O ring at the top
The time now is 05:30 PM.
