CRD oil change - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > CRD oil change
8.8 Swap Kit w/ TRUSS for JeepsROCK BOTTOM prices on LIFT KITS at Rockridge4wd!! WANT TO Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-11-2015, 03:41 PM   #1
joe989
2008 WK
CRD oil change
Why are people saying put half the oil down the oil filter tube to "coat the bearings" on the right side of the engine when the oil is just going down through the oil pump. Makes no sense.
joe989 is offline   Reply With Quote Quick reply to this message
Unread 03-11-2015, 05:16 PM   #2
jlgail4309
2008 WK
I don't know either. Watched on Videos. My first oil change is coming up. But what could it hurt.
jlgail4309 is offline   Reply With Quote Quick reply to this message
Unread 03-11-2015, 05:27 PM   #3
mushkasdad
2008 WK
Why take a chance? The results could be catastrophic.
It's only a couple minutes extra time and in my opinion, well worth it.
Gives me time to do other work.
mushkasdad is offline   Reply With Quote Quick reply to this message
Unread 03-11-2015, 05:44 PM   #4
chevra
2008 WK
I have never really looked into it either. But it must be in the procedure for a reason. It takes a little extra time, but yesterday I changed my fuel filter at the same time so it wasnt so bad.
3.0L CRD OME HD
17" XD Addicts with 255/75/17 Dynapro ATMs
GDE Eco Tune and DPF Delete
chevra is offline   Reply With Quote Quick reply to this message
Unread 03-11-2015, 06:35 PM   #5
bersh
2008 WK
It can't hurt, and it really doesn't add that much time as you can alternate pouring oil in both spots. I probably poured about 40% down the oil filter tube on my last change. Let it sit for 15ish minutes before you fire it up.
bersh is offline   Reply With Quote Quick reply to this message
Unread 03-11-2015, 06:53 PM   #6
jlgail4309
2008 WK
What oil is everyone using ? Napa has the Mobil 1 ESP 5-40 229.51 for 5.99 a quart.
Unread 03-11-2015, 06:53 PM   #7
TangoTango
2008 WK
There was a really good mechanic on here name merlin, and his idea was that side is a little dry for a split second.
Technically it is the "best way" to do it... I never bother.
Black WK Club #147
Life is hard. ...- John Wayne
TangoTango is offline   Reply With Quote Quick reply to this message
Unread 03-11-2015, 08:47 PM   #8
bersh
2008 WK
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
Unread 03-23-2015, 06:32 PM   #9
jlgail4309
2008 WK
Just bought the Jeep just finished the first oil change almost 60000 miles.Well tried the Total will see how it go's. What a mess the oil went all over the place.
Unread 03-23-2015, 06:42 PM   #10
SSF556
SSF556's Avatar
2008 WK
Buy this and then attach some clear hose...turn the valve and it is easey peasey... http://www.amazon.com/dp/B003T7XUE4..._Bklevb0BD7PN3
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline   Reply With Quote Quick reply to this message
Unread 03-23-2015, 07:46 PM   #11
TangoTango
2008 WK
that link is not working ... but get one of these... next time you change the oil.
if you leave the skid plate on there .. yes it's a mess, but with the value you can tube the oil.
Black WK Club #147
Unread 03-23-2015, 09:05 PM   #12
caddydaddy
2007 WK
Originally Posted by SSF556 View Post
Buy this and then attach some clear hose...turn the valve and it is easey peasey... http://www.amazon.com/dp/B003T7XUE4/..._Bklevb0BD7PN3
I went with the version they sell that has a 90 degree drain. I don't need to use a hose and there's no mess!
http://www.fumotousa.com/parts.php?p...&partnumber=56
2007 CRD Grand Cherokee Limited 4x4
GDE ECO Tune, Turbo Resonator Delete, EHM
171,000+ miles!
caddydaddy is offline   Reply With Quote Quick reply to this message
Unread 03-24-2015, 03:03 PM   #13
jlgail4309
2008 WK
Thanks thats a great idea.
Unread 03-24-2015, 10:32 PM   #14
Red_liner740
i got the fumoto drain and yes, i should have gotten the one with the 90degree elbow. I currently jack up the front slightly, slide in a low 5gal bucket, attach a hose and we're off to the races!
Red_liner740 is offline   Reply With Quote Quick reply to this message
Unread 03-24-2015, 10:41 PM   #15
ggrassmid
Make sure you get the valve with the curved seal for our oil pans. If you do not get it, the little o-ring seal that is on it will not work and you will have a slow leak. I have a thread posted up about my first oil change and it should have the part number for it.
Linked HERE
Black 2008 Limited CRD
GDE EcoTune, EHM, 2014 Rubicon take-offs
JF Black WK Club #168
ggrassmid is offline   Reply With Quote Quick reply to this message
