CRD MBRP Exhaust Install - Page 2 - JeepForum.com
post #16 of 38 Old 06-11-2009, 08:54 PM
Spider-One
2008 WK
It's just a cone filter placed on the end of the line. Took out the stock intake filter box, a filter with a 3.25" opening fits perfectly on the line. Sounds nice but any improvements are debatable. Personally I'd probably go with a decent exhaust before CAI, but it's probably best to combine the two for the least amount of resistance. Combined with a DPF delete you'd definitely see some improvements. Next time I get a chance I'd like to stop in a muffler shop and have a straight pipe made up in place of the DPF, the only issue with that is what type of flanges they use since they may be hard to come by.
2008 GC CRD, OME 2" lift kit, 265/70/R17 Cooper Discoverer S/T's, 1.5" Spidertrax spacers, gutted turbo resonator
Spider-One is offline
post #17 of 38 Old 06-12-2009, 06:37 AM
MBRP
Originally Posted by wookiee View Post
I was just getting ready to install the new exhaust, after cutting the old one, when I noticed that the hanger bar on the main pipe was missing. They're going to send me a new one. I've put everything in place but I won't tighten everything down unless I have to go somewhere before the new pipe comes in.
I would have had it done within an hour otherwise.
Tools needed
Sawsall - to cut the old pipe
Channel Locks - to help remove the rubber hangers
17mm, 9/16" & 5/8" sockets
getting (2) 9/16" bolts that are 1/4" longer than those originally supplied will make attaching the pipe easier.
I'm averaging 22+ mpg. With the mbrp, I'm hoping for a 10% improvement which will give me 24 mpg. So that's about 44 more miles per tank or about 2 gallons per tank more at $3/gallon which is $6/fillup
Total price was $307.72. Divided by $6 will pay for itself at 25,000 miles. Not to mention less back pressure + less wear & tear on the engine.
Did someone from our customer service department get you set up with that new mid pipe yet? Let me know if you have not received tracking info yet.
Scott
Phone 1-888-636-7223
Web
MBRP is offline
post #18 of 38 Old 06-13-2009, 07:53 AM Thread Starter
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Yes they did and it's on it's way. Thanks
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | Provent MBRP XP Exhaust | New Intake Tube & Seal + EHM | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | 200,000 Mile Club | Dogpiled Club | pre-N23 FDCM |
89 GW w/plow
wookiee is offline
post #19 of 38 Old 06-13-2009, 03:21 PM
rhusak
2008 WK
Hey Guy's..
Are most of you using the stainless exaust or the Aluminized?
Are you happy with the sound.. Not too loud without any muffling?
Do you have to cut the old one out? Just in case it doesn't work out for me?
I guess you could use band clamps in any case..
Ron
08 Overland CRD with GDE Hot Tune
Livin at 9200Feet lookin down at ya!
rhusak is offline
post #20 of 38 Old 06-14-2009, 11:40 AM Thread Starter
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Ron
Yes, you have to cut it. Took 15 seconds with a sawsall.
DPM MBRP article
89 GW w/plow
wookiee is offline
post #21 of 38 Old 06-14-2009, 03:56 PM
rhusak
2008 WK
Wookie..
Hmmm.. Rea t6he article in your post.. Wonder if any increse is in order with the inmotion.. In stock tune none noted..
Ron
rhusak is offline
post #22 of 38 Old 06-16-2009, 08:18 PM
USN_BlackWK
FLY NAVY
USN_BlackWK's Avatar
Hey Guy's..
Ron
As for the volume, it is not much louder than stock. It just has a deeper growl. At highway speeds the volume increase is not noticable, only during acceleration at lower speeds.
Aug '16 COTM!
Aug '15 COTM!
2016 GMC Sierra Denali 6.2L The tow rig
USN_BlackWK is offline
post #23 of 38 Old 06-16-2009, 09:12 PM
suzieque
2008 WK
thats a good read. Interesting that the dyno showed almost no change in torque or horsepower over stock. They thought the computer needed to be chipped to take advantage of the MBRP exhaust.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #24 of 38 Old 07-09-2009, 01:32 PM Thread Starter
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
I just took a short 600 mile trip yesterday. I've done nothing to the car other that add the MBRP. Same passenger, same 100 lbs of tools and same skid plates. I was getting 19 -> 22 1/2 mpg recently.
This trip got 26.3 & 24.7 mpg, mostly highway 75 - 85 mph.
Purely anecdotal, but interesting nonetheless.
89 GW w/plow
wookiee is offline
post #25 of 38 Old 11-05-2011, 07:35 PM
bmw_686
can you make a video of the exhaust i cant find any videos on youtube
bmw_686 is offline
post #26 of 38 Old 11-06-2011, 06:26 PM
fishinbama
2007 WK
My dream exhaust starts at the downpipe with no converters,no pressure sensors, no 02 sensors, no resonators, mufflers or dpf. It also has the pcv (elephant hose mod) plumbed into it. Wonder how loud it would be. I am already talking to a tuner that can make it so that there are no codes.
fishinbama is offline
post #27 of 38 Old 11-06-2011, 06:43 PM
suzieque
2008 WK
this may be as close as you will get
http://www.dieselpowermag.com/tech/0...e/viewall.html
suzieque is offline
post #28 of 38 Old 11-06-2011, 07:12 PM
bmw_686
oyah i want to hear it but they said its not that load anyways because of the dpf filter.
bmw_686 is offline
post #29 of 38 Old 11-06-2011, 08:18 PM
2008Me
2008 WK
This is what I drive every day, the F250. Its got the 7.3L or 444ci Turbo diesel. I have a 4'' SS straight pipe, no muffler no cat no crap! Its no louder than it was with a muffler on it. When it comes to a turbo diesel the turbo eats all the sound so it stays pretty quiet. When your talking about back pressure on a turbo diesel the less the better you dont need/want any! So the money you spend on an exhaust will continue to pay for itself over time... it takes a long time to get your money back but worth it. They should be mandrel bent pipes too which helps flo unlike the rippled pipe you get from the factory
My Build: http://www.jeepforum.com/forum/f22/willys-truck-3522066/
2008Me is offline
post #30 of 38 Old 11-06-2011, 10:51 PM
TurboDiesel
2008 WK
^ change ur signature....
bmw 686 lets see a pic of ur ride, i live in Langley BC too lol
TurboDiesel is offline
Anyone Have an MBRP Exhaust?? BigStout99 WK Grand Cherokee & XK Commander Forum 16 09-27-2010 12:37 PM
MBRP CRD Exhaust Questions CRD Dawg WK Grand Cherokee & XK Commander Forum 5 01-19-2010 05:19 AM
MBRP DPF Back Exhaust CRD Dawg WK Grand Cherokee & XK Commander Forum 6 11-19-2009 02:53 PM
good price on MBRP exhaust CRD micky_blue WK Grand Cherokee & XK Commander Forum 9 08-24-2009 02:59 PM
MBRP performance CRD exhaust LJS8510 WK Grand Cherokee & XK Commander Forum 4 08-01-2008 06:19 AM
