06-10-2009, 11:34 AM
#1
Bought, not built.
I was just getting ready to install the new exhaust, after cutting the old one, when I noticed that the hanger bar on the main pipe was missing. They're going to send me a new one. I've put everything in place but I won't tighten everything down unless I have to go somewhere before the new pipe comes in.
I would have had it done within an hour otherwise.
Tools needed
Sawsall - to cut the old pipe
Channel Locks - to help remove the rubber hangers
17mm, 9/16" & 5/8" sockets
getting (2) 9/16" bolts that are 1/4" longer than those originally supplied will make attaching the pipe easier.
I'm averaging 22+ mpg. With the mbrp, I'm hoping for a 10% improvement which will give me 24 mpg. So that's about 44 more miles per tank or about 2 gallons per tank more at $3/gallon which is $6/fillup
Total price was $307.72. Divided by $6 will pay for itself at 25,000 miles. Not to mention less back pressure + less wear & tear on the engine.
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | Provent | MBRP XP Exhaust | New Intake Tube & Seal + EHM | Alternator Splash Guard | Crank Sensor | GPS AK InMotion Hack | Swirl motor bypass | Fuelly.com - wookiee | Blue WK Club Member #13 | 100,000 Mile Club | Dogpiled Club
06-10-2009, 11:56 AM
#2
Nice, but is there no muffler?
06-10-2009, 11:58 AM
#3
Wookie..
It would be nice to know what this does to the sound... I know the Cat and turbo absorb most of it but could you let us know what this does..
Ron
08 Overland CRD with InMotion Tune
Livin at 9200Feet lookin down at ya!
06-10-2009, 12:05 PM
#4
The only piece on the stock exhaust past the DPF is a resonator, so even stock there is no muffler.
2008 GC CRD, OME 2" lift kit, 265/70/R17 Cooper Discoverer S/T's, 1.5" Spidertrax spacers, gutted turbo resonator
06-10-2009, 12:15 PM
#5
Well its not really back pressure you want to deal with... id say more on the lines of increased velocity. Back pressure is commonly miss understood.
06-10-2009, 01:00 PM
#6
Guy's..
OK no muffler on standard exhaust.. What does it sound like without the resonator?
Ron
06-10-2009, 02:05 PM
#7
Bought, not built.
It does have a Catalyst (that looks like a muffler) & the DPF that are still there. The book shows a pre-catalyst as well, but I don't see it.
Sounds good. Deep whoosh. Wife says it sounds 'shallow', like coming out of a tunnel. She likes it.
The resonator is straight through, so no back pressure, I guess. But the pipe is bigger than the original.
After I get the replacement pipe and crank down the clamps, I'll put up a recording of the sound.
06-10-2009, 02:10 PM
#8
I'm guessing that instead of paying mbrp, you could have gone to a muffler shop and have the muffler shop remove the stock resonator (the thing that looks like a muffler) and install a nice exhaust tip for less money. That's what I'm thinking of doing.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
06-10-2009, 02:35 PM
#9
on my 3.7 that is all I did was replace the muffler and add a tip it was much cheaper. Having a CRD I would upgrade to a bigger pipe size. I look the look on the exhaust you got very nice.
06-10-2009, 04:18 PM
#10
The benefit of the MBRP kit over just removing the resonator and getting a tip is that the stock exhaust is only 2.75" while the MBRP is mandrel bent 3". You could always have a custom made 3" exhaust made, but the MBRP seems pretty easy to install and I think the price is pretty fair.
06-10-2009, 10:27 PM
#11
I have the mbrp exhaust install for a while on mine and the sound diffrence is noticable but not much louder. It does sound better of you are standing outside of the Jeepp though.
07 Silver 3.0 CRD, Clifford matrix 50.5x remort start/turbo timer, 265/70R17 Goodyear DURATRACS, XD Series Spy wheels, OME Lift Kit, Kenwood navigation system with reverse camera, Inmotion tuned, Amsoil air filter, Fitch fuel catalyst, Air Lift suspension air bags with air compressor, P3 brake controller, MBRP Exhaust, Accu Pro Calibrator, Addco front/rear anti sway bar, Husky Liner floor mats, upgraded air intake tube, Quick Oil Drain Valve.
06-11-2009, 04:24 PM
#12
Thank you for that, I'm a little new to jeeps.
06-11-2009, 04:39 PM
#13
What is the real benefit, if any, to a DPF back exhaust when all the the other factory components(i.e.- the intake, restrictive turbo/engine kidney resonator, exhaust manifold, DPF, etc.), are all still in place? Sell me on it and I'll buy the MBRP. By the way, what's the difference between the 3 that they offer other than price and Tip design?
2008 Grand Cherokee Limited 2wd CRD-InMotion Stage 2 Tune, K&N Air Filter, Elephant Hose CCV Mod, Gutted Turbo Resonator, MBRP Pro Series Exhaust
06-11-2009, 05:26 PM
#14
With all the restriction from the two cats and the DPF it's debatable. I'm not sure if it's 3" to the DPF or not but if it is then at least the increase is bringing it to 3" is the whole way through, but I'm not 100% on that on the size of pipe to the cats and DPF.
The difference between the 3 is the material used. I'm not sure about the lowest model but the middle model shouldn't rust out and the top model shouldn't rust out and should keep it's shine.
As for the two cats they are definitely there. You can see the first pre-cat from the engine bay, otherwise you have to get right underneath the down pipe to see the first cat as it's very close to the engine.
06-11-2009, 05:40 PM
#15
Would you spend the $ on the exhaust or purchase an intake instead once they come out? That's assuming one does eventually hits the market. By your signature, it's looks like you adapted one of your own designed for another engine.
