CRD long crank start in the morning - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > CRD long crank start in the morning
New rockridge 4wd sales rep!!!FS: Wranger BRIGHT License Plate LED! Just $3! Great valueTJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 03-01-2015, 07:02 PM   #1
r_unda
This morning my CRD took a long time to start. It cranked but didn’t start. I tried 4 or 5 times but nothing. Plugged my reader and there were no codes. Went inside had breakfast, then tried again and started right up. Ambient temperature was about 45 deg. F. Started find the rest of the day.
Now in the last few month (always in the morning, cold weather but nothing less than 40 deg. F) this has happened before but it has never taken that long to start. Usually starts up after a long crank or on my second try. I always attributed this to me not waiting enough time for the glow plug to warm up.
Glow plugs where replaced about 50,000 miles ago. I have not replaced the Control module. Current miles are 128,000 miles. Could this be glow plug related? What else could it be?
Thanks!
My Jeep isn't getting older, it's getting newer part by part
2011 WK2 HEMI 4x4 Overland
2007 WK CRD 4x4 Limited GDE Tuned
1998 TJ SE
1973 CJ5 - YJ OME 2.5" lift, 33" tires
1951 Willys truck
r_unda is offline   Reply With Quote Quick reply to this message
Unread 03-01-2015, 07:36 PM   #2
SSF556
SSF556's Avatar
2008 WK
Originally Posted by r_unda
This morning my CRD took a long time to start. It cranked but didn’t start. I tried 4 or 5 times but nothing. Plugged my reader and there were no codes. Went inside had breakfast, then tried again and started right up. Ambient temperature was about 45 deg. F. Started find the rest of the day. Now in the last few month (always in the morning, cold weather but nothing less than 40 deg. F) this has happened before but it has never taken that long to start. Usually starts up after a long crank or on my second try. I always attributed this to me not waiting enough time for the glow plug to warm up. Glow plugs where replaced about 50,000 miles ago. I have not replaced the Control module. Current miles are 128,000 miles. Could this be glow plug related? What else could it be? Thanks!
how old is the battery...
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline   Reply With Quote Quick reply to this message
Unread 03-01-2015, 08:04 PM   #3
r_unda
Made and bought on 10/2013 so almost 1-1/2 years old
1998 TJ SE
1951 Willys truck
Unread 03-01-2015, 08:10 PM   #4
BAH101
2008 WK
Check the battery terminal clamps. If there is any movement, take them off, clean them and reinstall. Make sure they are tight.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline   Reply With Quote Quick reply to this message
Unread 03-01-2015, 10:54 PM   #5
Drudgery1971
Drudgery1971's Avatar
2007 WK
It's likely not the plugs at that temp. Validate battery is good under load but I don't think that's it either but you have to rule out. My CRD is starting to do it's hard long start the WARMER it gets but it still starts so far but I am going to need to address it pretty soon. Your issue seems different but I will keep following because hard start has the same components yet different issue in my case. - Good luck - hope it's something simple.
2007 WK Limited 3.0 CRD - Stock (Mine)
2010 XK Sport 5.7 Hemi - Stock (Wife)
Drudgery1971 is offline   Reply With Quote Quick reply to this message
Unread 03-02-2015, 09:44 AM   #6
r_unda
Tightened the battery terminals last night. Started fine this morning. Will keep you posted if the issue comes back.
Thanks for the help.
Unread 03-06-2015, 12:08 AM   #7
Palak
2008 WK
Mine was this way as well.... not sure if it's related, or if CAUSED by it... but I just had to replace my starter. (3 days ago)... easy starts now.
Palak is offline   Reply With Quote Quick reply to this message
Unread 03-08-2015, 10:45 AM   #8
oldsmoke
2009 WK
Yah, my old diesels around the farm that had mechanical fuel injection would always start if you could get the motor to crank over but modern electronic fuel injection requires the proper voltage at the control module or it won't actuate the injectors. If your battery or starter motor is faulty the voltage drop from cranking
will create a low voltage condition and no fuel will be injected.
Diesel Ecotune-DPF, 32" tires, 2" lift. 4xGuard bib, tow hooks
oldsmoke is offline   Reply With Quote Quick reply to this message
