CRD leakin' fuel.....and stinkin'... - JeepForum.com
post #1 of 3 Old 12-27-2012, 03:44 PM Thread Starter
FLHXSE3
2014 WK
.....noticed a bit of diesel smell....got worse.....then saw an oily spot on the wet pavement after I backed out of a spot. Took it into the Jeep dealer and they say it needs a HP pump, an injector, and some hoses.....also tie rods.....and an oil leak. All will be covered by warranty...sure glad I got the extended (gold) warranty...no deductable and includes a week's rental. By the time it's all done, they say it should be ANOTHER $5-6 K...yes another!!! The turbo and associated items were over $6 K a year ago!
I sure hope the Fiat diesel will be better than this MB
FLHXSE3 is online now
post #2 of 3 Old 12-27-2012, 04:28 PM
Radcrd
2007 WK
I call BS! They will not change half of those items yet charge it back to Chrysler. The dealer is milking the manufacturer.... The MB is known to be reliable so is the VM Motori but time will tell...
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #3 of 3 Old 12-27-2012, 04:32 PM
suzieque
2008 WK
hmmm, do these guys really know what they are doing? or are they just replacing everything and getting chrysler to pay for it all? Injector seals can leak, but are easily fixed with a new seal. The injector pump normally leaks internally and fills the crankcase with diesel fuel - a good reason to check your oil frequently, but you would not see external signs of this type of failure from what I have read.
These engines commonly leak around the fuel filter, especially where a non-Mopar filter was used or if the clamps were not correct. I read a thread about a fuel tank leak, but that would show up around the fuel tank skid plate.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
