CRD horrible mileage! - JeepForum.com
post #1 of 39 Old 10-18-2013, 11:00 PM Thread Starter
TurboDiesel
2008 WK
hey all
so lately my 2008 CRD has been gettin progressively bad mileage
my evic was always around 12.4-12.6L/100km [18.6MPG]
my last tank was 13.5L/100km on fuelly [17.4MPG]
and now my evic reads 14.8L/100km [roughly 16.5 MPG ??]
i have gde eco tune w/ dpf delete aswell... [for over a year]
i do 0 highway driving but still ...
i was told to look into o2 sensor, but any other possibilities?
thanks
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #2 of 39 Old 10-18-2013, 11:12 PM
ravens9322
Hey, why don't you go ahead and Americanize those numbers for us?
As of right now, I don't see the problem. Lol
Sent from AutoGuide.com Free App
ravens9322 is offline
post #3 of 39 Old 10-18-2013, 11:27 PM Thread Starter
TurboDiesel
2008 WK
HAHAH sorry
average is 18.6MPG
last tank was 17.4MPG
its reading probably close to 16MPG right now...
post #4 of 39 Old 10-19-2013, 04:35 AM
Cherokee30D
2007 WK
Originally Posted by TurboDiesel View Post
hey all
thanks
Hi TurboDiesel, I have the same problem. I was also told that it could be the O2 sensor.
Have ordered one and waiting for it to arrive.
Will let you know the result once I have fitted it.
Cheers, Craig
Cherokee30D is offline
post #5 of 39 Old 10-19-2013, 07:27 AM
SSF556
2008 WK
hey all so lately my 2008 CRD has been gettin progressively bad mileage my evic was always around 12.4-12.6L/100km [18.6MPG] my last tank was 13.5L/100km on fuelly [17.4MPG] and now my evic reads 14.8L/100km [roughly 16.5 MPG ??] i have gde eco tune w/ dpf delete aswell... [for over a year] i do 0 highway driving but still ... i was told to look into o2 sensor, but any other possibilities? thanks
Have they switched to winter blend in Canada....probably so. For city driving in the winter this is not bad. Even here in SC I see numbers like that....
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #6 of 39 Old 10-19-2013, 08:32 AM
quicksilverado
2007 WK
x2 on the winter fuel. Are you hand calculating or going by the EVIC. Mine is off anywhere from 2-4 mpg.
07 Grand Cherokee Limited CRD 4X4 GDE tune
00 Silverado 10 sec work truck
quicksilverado is offline
post #7 of 39 Old 10-19-2013, 03:05 PM Thread Starter
TurboDiesel
2008 WK
yea im assuming we have winter diesel now
it gets close to freezing at night now..
also remembered i installed new sub thursday then went burning around with my buddy
[install new sub = disconnect battery = reset stats]
so i guess 1L/100km or so isnt bad for winter diesel...ill keep an eye on it as i have to fill up today
i use fuelly to calculate...ill post my results when i fill up today
also Cherokee30D i have not ordered one as i was just told to look into it yesterday...ill see how my mileage goes but i am probably due for one anyways
please do let me know how it works for u tho
might also clean the MAF as it may be dirty from offroading and what not
thanks for the responses
post #8 of 39 Old 10-19-2013, 06:44 PM
jediknight
2008 WK
Jamed caliper maybe ??
Bad O2 will cause dtc ??
Bad O2 will make your exhaust gaz smoking black ... i.e richer then required ??
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #9 of 39 Old 10-19-2013, 08:00 PM Thread Starter
TurboDiesel
2008 WK
jamed caliper??
i dont have a CEL but i can check for codes
i had a code for leak somewhere but i changed air filter and made sure everything was closed tight...ill have to check again
exhaust doesnt smoke black but there is smoke with dpf and reso deletes
post #10 of 39 Old 10-19-2013, 08:13 PM
BAH101
2008 WK
Originally Posted by jediknight
Jamed caliper maybe ?? Bad O2 will cause dtc ?? Bad O2 will make your exhaust gaz smoking black ... i.e richer then required ??
This happened to me. Front drivers side caliper had a piston stuck. Took a good hit on mileage before I could get it replaced.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #11 of 39 Old 10-19-2013, 09:30 PM Thread Starter
TurboDiesel
2008 WK
how can i check if its jammed?
sorry not a mechanic
i build houses lol
post #12 of 39 Old 10-20-2013, 08:24 AM
BAH101
2008 WK
how can i check if its jammed? sorry not a mechanic i build houses lol
Go for a half hour drive, then get out and feel the wheels near the hub. The dragging one will be quite hot. After a 14 km drive, I used my laser thermometer on it and the drivers side rotor read over 500 degrees C.
BAH101 is offline
post #13 of 39 Old 10-20-2013, 01:01 PM
terrasmak
2007 WK
18 MPG with 0 highway driving. That sounds pretty good.
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline
post #14 of 39 Old 10-20-2013, 02:52 PM Thread Starter
TurboDiesel
2008 WK
i gotta get new rotors and pads anyways
ill check it out when i do that
they squeal like a mofo at the moment lol
post #15 of 39 Old 10-20-2013, 05:02 PM
BAH101
2008 WK
i gotta get new rotors and pads anyways ill check it out when i do that they squeal like a mofo at the moment lol
I got Stillen pads and rotors through Kolak. Good price.
BAH101 is offline
