CRD Glow Plug issue - Page 9 - JeepForum.com
post #121 of 301 Old 08-19-2012, 11:33 AM
baggee
2007 WK
Originally Posted by copterdoc View Post
I fixed my glow plug issue, my dpf issue, my wheel speed sensor issue, my black seal, orange seal issue, my swirl motor issue, and my pro vent mod issue. I Sold the damn thing. actually I loved it and it was bitter sweet to see it go, but leave it to jeep to wrap an excellent little motor up in a horrible, poorly designed emissions system and sub par wiring.
Hehehehhh nice fix man...
baggee is offline
post #122 of 301 Old 08-20-2012, 11:43 AM
jediknight
2008 WK
Originally Posted by jiggadog View Post
try a local auto parts store..shouldnt take long to find someone who sells bosch or beru.
Right ... the plug #3 is now of the engine head and will be ending byuing one at Merc dealer for 31 $. Took 30 minutes to do ... man working on this engine is like doing a surgery ... you need white gloves and need to have had a good sleep.
At the merc dealer, I've been told that it's not necessary to change all the GP at the same time. It all depends on the mileage of the vehicle ... which kinda make sense. However I've been told that it can not be tested independetly with a ohm meter like it will be for a normal resistor. It need to be tested with the vehicle on with the ECU. Any thoughts on this ? I'd like to avoid changing a glow plug for nothing and playing the musical chair with the rest of the GPs ... I'm worried that it could also be a fault from the GP module
... how can I confirm that ? My fault code was a single P0673 code.
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #123 of 301 Old 08-20-2012, 07:25 PM
jiggadog
2008 WK
only reason i changed all of mine out is i was replacing berus with bosch..probably wouldnt have mattered if i only changed one, but i figured i'd do them all at once.
if you change all the glow plugs and still get the code, then you can be pretty sure it's the module. actually my uncles module just failed last weekend. they aren't that expensive and pretty easy to change.
on a side note, my uncle has a subscription to alldata which from what i understand is used by a lot of shops and is pretty expensive for a license. anyway, my uncle printed out a page showing fuel system. check out the numbering of the glow plugs..this isn't consistent with what has been agreed to in this thread..very confusing.
2008 WK CRD Limited 4x4. Every available option package
jiggadog is offline
post #124 of 301 Old 08-20-2012, 08:13 PM
jediknight
2008 WK
Yeah I've seen that printout somewhere on the forum, but it seems to be wrong as it looks like, by looking at the numbering, to represent the firing sequence and not the glow plug numbers.
post #125 of 301 Old 08-21-2012, 04:04 PM
jediknight
2008 WK
Changed gp #3 and now she's runing fine ... Seems that p0673 code is accurate.
post #126 of 301 Old 08-21-2012, 05:02 PM
suzieque
2008 WK
yup, the picture was called out already as being incorrect.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #127 of 301 Old 08-21-2012, 06:11 PM
jiggadog
2008 WK
ok thanks for the heads-up..didn't realize that.
jedi..that's great, glad it wasn't the module.
jiggadog is offline
post #128 of 301 Old 08-21-2012, 09:39 PM
YB Normyl
YB Normyl's Avatar
2016 JK Wrangler
Got a code for glow plug #2, no check engine light just an active fault code.
YB Normyl is offline
post #129 of 301 Old 08-22-2012, 05:01 AM
jediknight
2008 WK
Weird... Do you have a tune on ?
I had a code and a mil ...
post #130 of 301 Old 08-22-2012, 08:37 AM
YB Normyl
YB Normyl's Avatar
2016 JK Wrangler
No tune, but the mil light just came on this morning while idling.
post #131 of 301 Old 08-23-2012, 08:32 PM
r_unda
Got code for #1 glow plug (@ 78,000 miles) , just replaced it with a BERU plug. Battery was disconnected for more than 10 minutes but still have check engine light on. Does this mean that the module is bad or the codes don't clear when disconnecting the battery like other cars do?
Thanks!
My Jeep isn't getting older, it's getting newer part by part
2011 WK2 HEMI 4x4 Overland
2007 WK CRD 4x4 Limited GDE Tuned
1998 TJ SE
1973 CJ5 - YJ OME 2.5" lift, 33" tires
1951 Willys truck
r_unda is offline
post #132 of 301 Old 08-23-2012, 08:40 PM
jediknight
2008 WK
Originally Posted by r_unda
Got code for #1 glow plug, just replaced it. Battery was disconnected for more than 10 minutes but still have check engine light on. Does this mean that the module is bad or the codes don't clear when disconnecting the battery like other cars do?
Thanks!
Yep disconecting the batery will not ease all the DTC... Some can remain in the ecu and after a few driving cycle it will go if problem is solved OR erase the code a obd tool if you got one ...
post #133 of 301 Old 08-23-2012, 08:43 PM
r_unda
Ok Thanks! Don't have OBD tool so I guess I will have to wait and see.
1998 TJ SE
1951 Willys truck
r_unda is offline
post #134 of 301 Old 08-23-2012, 08:45 PM
jediknight
2008 WK
... But how did you get the code for gp #1 then??
post #135 of 301 Old 08-23-2012, 08:49 PM
r_unda
The parts store read me the code
1998 TJ SE
1951 Willys truck
r_unda is offline
Glow Plug life roadman WK Grand Cherokee & XK Commander Forum 59 03-24-2016 11:17 PM
CRD #6 Glow Plug Circuit Error tallguy6464 WK Grand Cherokee & XK Commander Forum 26 01-07-2014 04:26 PM
Glow plug burnout smitheeee WK Grand Cherokee & XK Commander Forum 5 10-04-2012 01:14 PM
glow plug issue not solved roadman WK Grand Cherokee & XK Commander Forum 8 10-09-2008 03:58 PM
why cant find glow/reverse glow gauges overlays for 2000 GC ? eschapiro ZJ Grand Cherokee Forum 0 02-14-2007 01:32 PM
