CRD Glow Plug issue - Page 8 - JeepForum.com
post #106 of 301 Old 11-28-2011, 04:18 AM
copterdoc
2008 WJ
http://www.partswebsite.com/berrydcj/
Berry dodge/chrysler/jeep in texas. All six glow plugs(new upgraded 7001 berus) 160 dollars, 181 with shipping. new black seal intake tube 72 dollars, 83 with shipping. Nice people good service.
copterdoc is offline
post #107 of 301 Old 06-26-2012, 10:47 AM
jiggadog
2008 WK
jeep threw a code for a bad #3 glow plug. going to replaceall of them with Bosch. Getting them at cost for $18 each and i've read quality is comparable so i'll try saving a few bucks. i'm assuming the following are quotes for beru's as i didn't ask what type, but dealership (taylor chrysler in hamilton) wanted 51, napa 48, and merc dealership in burlington 29. going to replace them tonight and without any issues..i hope!
2008 WK CRD Limited 4x4. Every available option package
jiggadog is offline
post #108 of 301 Old 06-26-2012, 11:18 AM
suzieque
2008 WK
thats a good price, where are you getting them from? what part number are you using?
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #109 of 301 Old 06-26-2012, 11:32 AM
jiggadog
2008 WK
getting them from barton auto in hamilton through uncle who is a mechanic and has an account there. not a lot cheaper than buying from merc dealership, but its enough of a savings to give them a try. i'll post up the part number when i get them as my uncle ordered/picked them up for me.
jiggadog is offline
post #110 of 301 Old 06-26-2012, 11:41 AM
suzieque
2008 WK
The whole glow plug system seems somewhat fragile. The dealer warned me about this too, he said that as soon as one plug fails, they just recommend replacing them all including the glowplug module. They did mine all under warranty last year so I'm hoping to not have an issue. I think the trick is to replace the failed glow plug as soon as it fails versus driving around longer, its almost like a serial (or is pararrel?) circuit so that if 1 plug fails, the other plugs get the extra voltage that the failed plug is not consuming and is more voltage than they are designed for.
suzieque is offline
post #111 of 301 Old 06-26-2012, 11:49 AM
jiggadog
2008 WK
that's good to know. was your repair covered under the 3yr/60 bumper-to-bumper warranty or the 5 yr powertrain warranty?
jiggadog is offline
post #112 of 301 Old 06-26-2012, 11:59 AM
suzieque
2008 WK
3yr/60 bumper-to-bumper warranty. I think that is all the warranty we CRD owners in canada have, there is no 5 yr powertrain as I recall.
suzieque is offline
post #113 of 301 Old 06-26-2012, 12:38 PM
jiggadog
2008 WK
I had the rear main seal replaced under the 5yr/100k warranty this year...thankfully.
jiggadog is offline
post #114 of 301 Old 06-26-2012, 02:14 PM
jiggadog
2008 WK
Part number for bosch plug is 80047
jiggadog is offline
post #115 of 301 Old 08-16-2012, 08:25 PM
LifeOnABoard
2008 WK
The Bosch plug is a rare find. I got fast service from Europarts but the packaging left much to be desired. The Beru's from EP made it across coasts OK though. Replacing #6 took over 2 hours. Anyone who can do all 6 plugs in less than 3 hours has done it before and is 7 ft tall. Very thin 45 degree needle nose pliars are needed for these things. About the connectors: grab the shaft, not the tabs.
LifeOnABoard is offline
post #116 of 301 Old 08-17-2012, 04:34 PM
jiggadog
2008 WK
yes i agree #6 was difficult. i ended up using a cable tie, lassoed it and pulled it off. worked great for me.
jiggadog is offline
post #117 of 301 Old 08-18-2012, 09:03 PM
copterdoc
2008 WJ
I fixed my glow plug issue, my dpf issue, my wheel speed sensor issue, my black seal, orange seal issue, my swirl motor issue, and my pro vent mod issue. I Sold the damn thing. actually I loved it and it was bitter sweet to see it go, but leave it to jeep to wrap an excellent little motor up in a horrible, poorly designed emissions system and sub par wiring.
post #118 of 301 Old 08-18-2012, 09:40 PM
Chirpz
Chirpz's Avatar
2007 WK
Well that is one way to fix it for sure. I'll have to think about it.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #119 of 301 Old 08-19-2012, 09:43 AM
jediknight
2008 WK
Got the p0673 and now going to do the gp #3 but before i need to find a place to purchase them ... Dont know any good place where to find them in Canada aside dealers merc and chrysler !?!
2008 WK CRD Blue, QD II, Startech SD6 mod.
jediknight is offline
post #120 of 301 Old 08-19-2012, 10:48 AM
jiggadog
2008 WK
try a local auto parts store..shouldnt take long to find someone who sells bosch or beru.
jiggadog is offline
Glow Plug life roadman WK Grand Cherokee & XK Commander Forum 59 03-24-2016 11:17 PM
CRD #6 Glow Plug Circuit Error tallguy6464 WK Grand Cherokee & XK Commander Forum 26 01-07-2014 04:26 PM
Glow plug burnout smitheeee WK Grand Cherokee & XK Commander Forum 5 10-04-2012 01:14 PM
glow plug issue not solved roadman WK Grand Cherokee & XK Commander Forum 8 10-09-2008 03:58 PM
why canīt find glow/reverse glow gauges overlays for 2000 GC ? eschapiro ZJ Grand Cherokee Forum 0 02-14-2007 01:32 PM
