CRD Glow Plug issue - Page 3 - JeepForum.com
post #31 of 301 Old 09-08-2010, 07:08 AM
BigSensFan
2007 WK
Originally Posted by merlinTec View Post
hi
I fitted one today mopar part number 05175756aa merc number on the box was A0011595001 I would check they are the correct plugs for your Jeep from that site as it's not the same I fitted today.
Just phoned the Merc dealer in town using the Merc number on the box.. I can get the glow plug for $40 plus taxes... I dont know why the Jeep dealer is so much more for the same part ($70 range)
BigSensFan is offline
post #32 of 301 Old 09-08-2010, 07:15 AM
BigSensFan
2007 WK
Also... does anyone know which plug is #4
post #33 of 301 Old 09-08-2010, 08:24 AM
suzieque
2008 WK
there was another thread about a guy asking for help to find cylinder #6. As it turns out, the CRD is backwards counting from a gasser. Here is that thread http://www.jeepforum.com/forum/f67/c...-error-961444/
so when facing the vehicle from the front, #1 is the first cylinder on the left, #2 is first cylinder on the right and you go back and forth. Therefore, #4 is the second cylinder on the left.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #34 of 301 Old 09-08-2010, 12:59 PM
merlinTec
merlinTec's Avatar
This is where I disagree as I have it as 1 to 3 down one side 4 to 6 down the other. If you have a code reader I just connect it first and see what code comes back.
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #35 of 301 Old 09-08-2010, 02:04 PM
BigSensFan
2007 WK
The guy at the Merc dealer said if it is like other Merc Diesel Engines it is Like this
==(PASS)===FIREWALL===(DRIVER)==
1---------------------------- 6
2---------------------------- 5
3---------------------------- 4
=======GRILL=========
(North American Drivers Position)
Is that what you mean Merlin??
post #36 of 301 Old 09-08-2010, 05:33 PM
BigSensFan
2007 WK
I talked with the Service Manager where I bought my Jeep (I no longer live near there)... He said they actually changed #4 Glow Plug on a 2007 CRD last week.. The Diagram showed it was supposed to be on the front right side of the vehicle (when looking at the engine from the grill)... but the plug was actually on the other side (front left)... they said they traced it by the wiring..
He told me the colour of the wiring for glow plug #4 was black&white... I checked mine and the black and white wire is where #4 is by the diagram...
I wonder (and I am not a tech so I dont even know if this is possible).. If sometimes in factory installation the wires are not put to the 'proper' glow plug as what the service diagram shows. And that is why we have the confusion over the glow plug placement order?? Is that even possible?
post #37 of 301 Old 09-09-2010, 04:28 PM
BigSensFan
2007 WK
So I changed it today.... Glow plug 4 was (looking from grill towards engine) was the front right plug..
I checked it with the multimeter to confirm
post #38 of 301 Old 09-14-2010, 03:55 PM
johnniebravo
2008 WK
subscribed, lets hope i don't have to use the info on this page any time soon!
2008 CRD GC
johnniebravo is offline
post #39 of 301 Old 09-16-2010, 06:49 PM
suzieque
2008 WK
corrected as per the Sprinter forum, I believe this is also what merlin was referring to.
3---------------------------- 6
1---------------------------- 4
suzieque is offline
post #40 of 301 Old 09-19-2010, 01:54 PM
merlinTec
merlinTec's Avatar
Yep that's the info I have too.
post #41 of 301 Old 09-24-2010, 10:14 AM
ethorson
The check engine light on my CRD came on last week and the code turned out to be P0672, which is for glow plug #2. Looks like it needs to be changed. Does anyone know what the tightening torque is? Should anti-seize compound be used on the threads? Thanks.
ethorson is offline
post #42 of 301 Old 10-30-2010, 05:17 PM
TonyVideo
TonyVideo's Avatar
2008 WK
I got a P0673 code today and it is glow plug #3. Any special tool needed? 73,000 and this is the first code I have ever gotten. Should all 6 be replaced at the same time?
Tony
2008 GC 3.0L CRD Limited, ProVent Installed, Clear Bra, Scangauge
1999 GC 4.0L Larado
1985 Jeep Larado 4.0L Sold
TonyVideo is offline
post #43 of 301 Old 10-30-2010, 07:36 PM
suzieque
2008 WK
I recall seeing a glow plug tool on ebay, but I also read posts from folks that just used a socket.
suzieque is offline
post #44 of 301 Old 10-30-2010, 07:43 PM
Dr. Internet
When I lost glow plug #2 at 35,000 miles, I asked the dealer if all should be replaced, especially as my warranty was ending. He said there was no reason to replace them until they failed and he has seen them fail as early as 20,000 miles and as late as 100,000.
Steve
2012 Black GC Overland Summit 4x4 2006 Red LJ Rubi
USN Club Hull TJ-13 TX Jeep Club #29
Dr. Internet is offline
post #45 of 301 Old 10-30-2010, 08:47 PM
TonyVideo
TonyVideo's Avatar
2008 WK
I am thinking of going ahead and buying a spare as I am sure others will fail over time. Then I would be able to replace it right away.
Tony
1999 GC 4.0L Larado
Glow Plug life roadman WK Grand Cherokee & XK Commander Forum 59 03-24-2016 11:17 PM
CRD #6 Glow Plug Circuit Error tallguy6464 WK Grand Cherokee & XK Commander Forum 26 01-07-2014 04:26 PM
Glow plug burnout smitheeee WK Grand Cherokee & XK Commander Forum 5 10-04-2012 01:14 PM
glow plug issue not solved roadman WK Grand Cherokee & XK Commander Forum 8 10-09-2008 03:58 PM
why canīt find glow/reverse glow gauges overlays for 2000 GC ? eschapiro ZJ Grand Cherokee Forum 0 02-14-2007 01:32 PM
