CRD Glow Plug issue - Page 16 - JeepForum.com
post #226 of 301 Old 11-30-2013, 02:14 PM
BoraBoy
2008 WK
Got my plugs from England but did not save much; my Dad paid so they were technically free ;-)
Just replaced 1, 4, 5 & 6 When I did 6 the end of the connector snapped off as I was not perpendicular DUH but I applied dielectric grease to all connectors. I did notice that the connector on #3 was mangled by the dealer.
My main question is that # 1 came out all rusty and I am trying to figure out how to test the harness output without killing myself?
I will tackle # 6 and replace # 2 if the check engine does not go out.
One tip is to try to use your finger to keep the connector straight and apply a bit of extra pressure.
BoraBoy is offline
post #227 of 301 Old 12-07-2013, 10:46 AM
diesel88
2008 WK
Hi does anybody know what size reverse torx I would need to buy to change out my glow plug control module. Thanks
diesel88 is offline
post #228 of 301 Old 12-17-2013, 09:58 PM
Chirpz
Chirpz's Avatar
2007 WK
The wife had the Electronic throttle code light flashing yesterday, but it went away after a restart this morning. I have been having a "lingering" glow plug light for the last two months, the light would stay on for about 30-45 seconds after the engine started.
Today I got the P0673 error code, reported to me by my Garmin Mechanic GPS display. The Garmin reported Glow Plug #3 and refused to clear the code. It advised me to see a technician.
Looks like I'll be replacing one or more glow plugs. Merry Christmas!
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #229 of 301 Old 12-17-2013, 10:00 PM
jaje
2007 WK
I'd do them all if you've not done it before. I have 3 spare GPs in my parts box just in case and will get 3 more and the module if I get a glow plug code. I'm at 109k and not done any yet - which in a Hemi I'd likely have done spark plugs 3x by now (so glow plug replacement breaks even with spark plugs).
'14 WK2 EcoDiesel Limited
'13 Subaru BRZ
#74 Exocet - NASA ST3 / E0
jaje is offline
post #230 of 301 Old 12-21-2013, 12:45 PM
WKDiesel
It might be an issue with the crank sensor.
WKDiesel is offline
post #231 of 301 Old 01-04-2014, 07:39 PM
eeeehaw
2008 WK
[QUOTE=cougar93k;12335865]Chad,
I'm not sure where you got your diagram, but here's the numbering that I've seen for the CRD:
==(PASS)===FIREWALL===(DRIVER)==
3---------------------------- 6
2---------------------------- 5
1---------------------------- 4
=======GRILL=========
(North American Drivers Position)
QUOTE]
I can also confirm that the correct cylinder positions is in the above quoted diagram. I just replaced my #5 (middle of drivers side) glow plug this evening; went without a hitch (unscrewed easily). The bad one measured 33ohms, the new good one measured 0.7 ohms. I cleared the P0675 code along with resetting the MIL lamp using my Code Scout scanner. Engine starts much better now, esp since it's about freezing outside temp here.
BTW, the replacement glow plug I bought is a BorgWarner BERU Systems GmbH (ie, made in Germany) # GE105 (ISS) 0-100-266-011, which I got at my local NAPA store for about $35 (you can find it in their online store, also). I would have had to cough up at least $200 at my local Jeep dealer service center for this replacement, so well worth the <20 min to do this replacement myself.
What if the Hokey-Pokey IS what it's all about ?
eeeehaw is offline
post #232 of 301 Old 03-25-2014, 12:10 PM
andypasto
2007 WK
These jeepforum threads are fantastic! My check engine light was on with my 2007 WK 3.0 CRD, 90K miles, and I'm no longer under warranty. I'm a shade tree mechanic with zero diesel experience, so I relied on the service department at the local dealership to identify the problem. This $TEALERSHIP told me that the OBDII system indicated that I needed 6 new glow plugs as well as a new glow plug module. Estimated bill would be $1,000. (Would my vehicle even start if all of the GPs were bad and the module failed?) Since there were no apparent performance issues and I was now suspicious of this $stealership, I declined the work, retrieved my WK and headed home.
On a whim, I stopped by Advanced Auto Parts for advice. The employee grabbed an OBDII scanner from her bench, plugged it in to my vehicle and advised me that my #5 glow plug was faulty. That's all. These GPs weren't in stock, but she was happy to order one for me to the tune of $33.
Looking through the jeepforum threads, I determined how ridiculously simple it would be to replace the GP myself. These threads walked me through the process of locating the appropriate cylinder, and gave step-by-step instructions as well as a couple of pitfalls to avoid. It took me a total of 20 minutes to replace my #5 Glow Plug (fortunately the most accessible), and if I had known what I was doing in advance, it would have probably only taken 5 minutes.
Harbor Freight Tools happened to have a simple CAN OBDII scanner on sale at this time (Item # 98568), so I picked one up for $55. I was able to confirm that the fault no longer existed, and this scanner also allowed me to reset the check engine light.
I saved $900, and I now have a simple scanner for future fault identification on multiple vehicles.
I also have absolute respect for www.jeepforums.com
andypasto is offline
post #233 of 301 Old 03-31-2014, 10:44 PM
Red_liner740
Investing in a OBDII Scan tool is probably the best bang for the buck tool you could spend $$$ on.
It has saved me and my family/friends literally thousands of dollars. I use an Ultraguage to monitor up to 43 paramaters on my Jeep and also clear CELs and view any potential fault codes
Two weeks ago my morning routine was shattered. It consists of me waking up in the morning, grabbing the spare FOB and remote starting the CRD while i take the 10 min to get ready for work.
It started, idled for about 5 seconds and shut off. It did not even attempt to restart until i started it with the key in the ignition. No CEL's, no warnings.
It did this intermittently a few more times before i caught it turning on the glow plug light while driving. One of the signs of a bad glow plug.
I bought 5 (all they had in stock) Bosch glow plugs from Rock Auto and less than 5 days later they arrived.
In the meantime a CEL code came up on the Ultraguage (still no CEL on the dash) indicating a P0671 code, Glow plug #1.
I Sprayed some penetrant a day before doing the job. I replaced all glow plugs except for no. 2 (easiest to access) whether they were bad or not. Only #1 was shorted but now i have 4 spares in case of emergency.
Red_liner740 is offline
post #234 of 301 Old 05-30-2014, 03:12 AM
steveno
2009 WK
This worried me as I have Max Care Chrysler coverage and I am taking my 2008 Jeep in for the glow plug number 3 problem, I did a search and found that under Max coverage "electrical section" Glow plugs are covered, hope this helps others.
See: http://www.chrysler.com/en/service_c...les/index.html
steveno is offline
post #235 of 301 Old 05-30-2014, 12:57 PM
SSF556
2008 WK
Originally Posted by steveno
This worried me as I have Max Care Chrysler coverage and I am taking my 2008 Jeep in for the glow plug number 3 problem, I did a search and found that under Max coverage "electrical section" Glow plugs are covered, hope this helps others. See: http://www.chrysler.com/en/service_c...les/index.html
Decide if you want them to do the recall N23...if so you will not have a functioning 4LO
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #236 of 301 Old 05-30-2014, 01:07 PM
steveno
2009 WK
Yes been reading about the recall and its associated problems, as I always use a parking brake and turn my wheels to the gutter when parking the risk of miss-shifting then rolling away is very low for me, so I will be telling them no.
steveno is offline
post #237 of 301 Old 07-03-2014, 04:37 PM
strokendiesel
2008 WK
I had the P0672 pop up. Went ahead and changed all 6 (BERU from EBAY) as it has 108XXX and I bought it with 92XXX miles. Put it all back together, cleared the codes and it immediately came back on. I cleared it 3 more times (KOEO) and it continues to come back... anyone else have this? (yes I did pull the intake back off, pull the connector, remove the GP and reinstalled everything to double check my work)
edit - the GP light comes on momentarily after the engine has fired
Bummer- appears as though the module also throws the same code... Should've checked the plugs resistance first.
strokendiesel is offline
post #238 of 301 Old 09-13-2014, 01:35 PM
RobyD
2007 WK
I found 6 for $120 at German Auto Supply. Free shipping. Bosch part no 80050
Germanautosupply.co
RJD
RobyD is offline
post #239 of 301 Old 11-16-2014, 05:08 PM
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Originally Posted by wookiee View Post
Same here. Mine has 90,000 without a problem, so far.
Never did buy the spares. # 2 crapped out the first day below freezing.
180,000 miles. Looking for cheapest seller of plugs. Looks like it's GAP for $120 with free shipping.
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | MBRP XP Exhaust | New Intake Tube & Seal | Alternator Splash Guard | Crank Sensor | GPS AL InMotion Hack | Swirl motor bypass | Blue WK Club Member #13 | 200,000 Mile Club | Dogpiled Club | pre-N23 FDCM |
89 GW w/plow
wookiee is offline
post #240 of 301 Old 11-17-2014, 03:09 PM
Dusty280
2008 WK
Chirpz
Replace the module, clear the codes and then find out what plugs need to be replaced. I replaced all plugs and the module and found out one of the new plugs was no good after all the codes were cleared (new code came on couple of weeks later).
Dusty280 is offline
Glow Plug life roadman WK Grand Cherokee & XK Commander Forum 59 03-25-2016 12:17 AM
CRD #6 Glow Plug Circuit Error tallguy6464 WK Grand Cherokee & XK Commander Forum 26 01-07-2014 05:26 PM
Glow plug burnout smitheeee WK Grand Cherokee & XK Commander Forum 5 10-04-2012 02:14 PM
glow plug issue not solved roadman WK Grand Cherokee & XK Commander Forum 8 10-09-2008 04:58 PM
why canīt find glow/reverse glow gauges overlays for 2000 GC ? eschapiro ZJ Grand Cherokee Forum 0 02-14-2007 02:32 PM
