CRD Glow Plug issue - Page 13 - JeepForum.com
post #181 of 301 Old 02-14-2013, 10:16 AM
flacrd
2007 WK
Originally Posted by Radcrd View Post
It is a type of muffler to muffle the airflow noise. Its a pain to remove due to space. Search around, some of the guys removed them and took the baffles out to increase airflow (myself included) Not sure it made any difference and would not bother doing it again.
So the fix is to replace the resonator? It gets clogged up? This will be a pain to deal with.
Anyone got a part number and/or source by chance?
flacrd is offline
post #182 of 301 Old 02-14-2013, 10:27 AM
flacrd
2007 WK
Originally Posted by Zlartibartfast View Post
are you referring to the "resonator" described in this thread?
http://www.jeepforum.com/forum/f67/w...-pipe-1403115/
Thank you for the link. What I could not determine was what was thier problem with it (resonator) to start with? Oil leak or some other problem. How did you resolve it?
flacrd is offline
post #183 of 301 Old 02-16-2013, 05:09 AM
brew1
Originally Posted by flacrd View Post
Thanks for the replies CRDers. Yes it is tight even to look at. Do you think this is were the oil leak is coming from? Since there was oil present in the turbo openings during the glow plug change out that I saw it would stand to reason that it would be under pressure and leak from the resonator, Its irritating that I cannot see exactly were its coming from. It is the obvious culprit.
Did you already replace the orange turbo intake seal with the revised black one? This is a known area for oil leakage, thus the revised seal from Chrysler. Using a Provent or a tune such as GDE to disable the EGR should also help.
08 GC CRD, GDE, CBE
04 Audi A4 Avant 3.0, JHM, Revmax TC
15 Audi A3
16 Audi A3 S-Line
brew1 is offline
post #184 of 301 Old 02-16-2013, 05:34 AM
brew1
Were they ceramic or steel? Yes, I will probably stay at 7500 intervals for changes and yes I only have used Mobile 1 Turbo Diesel Oil 5w-30. I was more than pleased when Walmart started carrying this oil, by the gallon for around $29.00.
I prefer using AMSOIL 15W-40 Premium Heavy Duty Diesel & Marine Synthetic with 12 TBN in the VW TDI and Liberty CRD and will be switching the GC CRD over to it this weekend. Recommend for MB 228.1/228.3/229.1. My local Farm Supply store stocks it in gallon containers but it is a bit more expensive than the Mobile 1 Turbo Diesel.
I have used the 5W-30 Mobile 1 Turbo Diesel and 5W-30 Shell Rotella synthetic in the past with good results in all my diesel vehicles. However, I'm more comfortable with the AMSOIL for extended drain periods, 8,000+ miles.
Glad to hear you worked out your glow plug issues.
08 GC CRD, GDE, CBE
15 Audi A3
16 Audi A3 S-Line
brew1 is offline
post #185 of 301 Old 02-16-2013, 11:39 AM
flacrd
2007 WK
After learning or should I say re-learning how important quality oil is for a turbo and a diesel it looks like Amsoil for me in the future.
Thanks go to you and others on this site for the glow plugs and the 2008 tsb for the SQUEAK/RATTLE/VIBRATION under hood that has irritated the crap out of me for years. Yes, I have the documentation from the dealer to show that this was reported and written up on the service order 4 times since 2007 and never fixed. Just venting, I paid cash for the last time this written up, to bad the dealer lost their franchise during the recession? I had forgotten what this engine really sounded like without the extra noise.
2007 GRAND CHEROKEE LTD Q2 CRD GREYSTONE/L GREYSTONE
2006 MAGNUM HEMI COOL VANILLA
2006 JETTA TDI
2005 LIBERTY LTD CRD (LEMON LAWED)
flacrd is offline
post #186 of 301 Old 02-18-2013, 11:03 AM
terrasmak
2007 WK
Swapped plugs around, kinda looking like the new Bosch glow plug is bad.
"Racing makes Heroin addiction look like a vague wish for something salty." -- Peter Egan
terrasmak is offline
post #187 of 301 Old 03-14-2013, 09:58 AM
zedtechus
2008 WK
My dealer replaced glow plug #2 with BOSH new version 80050 (I bought myself the glow plugs) and code still on along with check engine. Dealer told me is the fault of GP control unit and I need to replace it but scanning with my OBD2 I dont get any other code than P0672 for GP #2.
Im thinking that could be because of mixed glow plugs (5 BERU and 1 BOSH) or maybe a new faulty BOSH glow plug?
How did you fix your problem?
Thanks
Adrian
PS: I tried to reset the code but it came back after a few engine starts.
2008 GC CRD Laredo - QT II - Jeep Black with 18" chrome wheels
zedtechus is offline
post #188 of 301 Old 03-14-2013, 10:15 AM
jiggadog
2008 WK
Thanks
Adrian
same thing with my uncles jeep. replaced #2 but still got same code. had to change the module.
2008 WK CRD Limited 4x4. Every available option package
jiggadog is offline
post #189 of 301 Old 03-14-2013, 06:17 PM
flacrd
2007 WK
Yes, unfortunately it seems either problem can cause the same code.
2006 JETTA TDI
flacrd is offline
post #190 of 301 Old 04-03-2013, 01:32 PM
jugganator
2006 WK
i been trying to replace the glow plug 1 for a while now, but i cannot see the grey clip thats shown in pictures on page 6/7. all i see is 6 black connectors, which if unplugged reveal 2 very thin metal connectors on the inside.
near them are a star shaped nut again 6, 3 of them each side, can these be the actual glow plugs? can someone maybe send me a picture and show me the where these things are?
3.0 crd 2006 WH model
jugganator is offline
post #191 of 301 Old 04-04-2013, 12:44 PM
zedtechus
2008 WK
I finally received and replaced my Glow Plug unit. Before installing the new one I delete the check engine code and since 2 days no more glow plug error codes So finally I got it fixed.
It feels so good especially that I was able to get the unit for 168$ and installed it myself when the dealer was asking 360$ for the control unit plus 30 min labor time!
Thanks everybody for the valuable help.
post #192 of 301 Old 04-04-2013, 02:01 PM
LJS8510
LJS8510's Avatar
2015 WK
Glad to hear it worked, I may have same issue where did you get the control unit?
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #193 of 301 Old 04-04-2013, 07:59 PM
zedtechus
2008 WK
I bought it from here:
http://www.factorymoparparts.com/642-900-28-00.html
They actually shipped the newer model: A-642-900-58-01
post #194 of 301 Old 04-04-2013, 08:46 PM
jjt250
2007 WK
Check out post #159. I included where I got it (which was the best price we could find - $144) and a YouTube video of how to do it.
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
post #195 of 301 Old 04-04-2013, 10:20 PM
terrasmak
2007 WK
Looks like I need one, and grab a few extra glow plugs. Just no need till the CEL has to be out for smog check in Dec.
Glow Plug life roadman WK Grand Cherokee & XK Commander Forum 59 03-24-2016 11:17 PM
CRD #6 Glow Plug Circuit Error tallguy6464 WK Grand Cherokee & XK Commander Forum 26 01-07-2014 04:26 PM
Glow plug burnout smitheeee WK Grand Cherokee & XK Commander Forum 5 10-04-2012 01:14 PM
glow plug issue not solved roadman WK Grand Cherokee & XK Commander Forum 8 10-09-2008 03:58 PM
why cant find glow/reverse glow gauges overlays for 2000 GC ? eschapiro ZJ Grand Cherokee Forum 0 02-14-2007 01:32 PM
