CRD Glow Plug issue - Page 11 - JeepForum.com
post #151 of 301 Old 11-07-2012, 10:57 PM
brew1
Nice informative thread. 2008 Jeep GC here. Picked up a set of 6 Mercedes Benz glow plugs (Beru) #A 001 159 71 01 off of Ebay last year for much less than the Mercedes or Jeep dealership charge. Replaced #3 in August 2011 and #5 in October 2011. Been driving around for a couple of months with the dreaded #6 glow plug fault code.
Finally got around to replacing the #6 GP today and also did #4 while I was at it. About 93,000 miles right now.
Had to remove one bracket and loosen the plastic wire harness but was eventually able to use both a long needle nose with a flat end screwdriver to pry and pull the plastic connector from the GP. Used a 1/4 drive with a deep 8mm socket and about a 4 inch extension to remove the GP. Hosed them down with liquid wrench and let sit about 15 minutes before removing. With the engine cold, they came out easily.
Applied a liberal amount of Permatex dielectric grease to the terminal ends and a liberal amount of Permatex anti-sieze compound to the threads. Just like to keep it easy for removing the connector and the GP's next time around.
Used a laptop with a Ross/Tech program designed for VW/Audi to reset the fault code. It also has a generic scan setting that lets me scan and reset codes for other auto brands. 3rd reset attempt was a charm.
brew1 is offline
post #152 of 301 Old 12-01-2012, 09:56 AM
RobyD
2007 WK
Had to change glow plug No 4 on 08 CRD @ 51,000 miles.
And No. 5 on 07 CRD @ 61,000 miles.
RJD
RobyD is offline
post #153 of 301 Old 12-02-2012, 01:03 AM
sshaughn
2008 WK
Changed glow plug No 4 and 6 at @41,000 miles, about 1 month ago
2008 WK Overland 4WD CRD 3.0L, QD2, Green Diesel Engineering Hot-Tune, MBRP Exhaust, CB Engineering Turbo Resonator Delete Pipe, Kolak Addco Rear Sway Bar, K&N Air Filter, Propel Fuels B20 Biodiesel
sshaughn is offline
post #154 of 301 Old 12-11-2012, 12:33 PM
r_unda
r_unda's Avatar
Today I changed all six glow plugs @ 83,571 miles. It took a little less than an hour to replace all of them.
Glow plug #4 code came on around 83,000miles and since back in August I replaced the #1 plug @ 78,000 miles (see post #131 in this thread) I decided to replace all of them today including #1 since it was a BERU and the new ones I bought are BOSCH (I don’t think mixing brands matters but just in case).
My Jeep isn't getting older, it's getting newer part by part
2011 WK2 HEMI 4x4 Overland
2007 WK CRD 4x4 Limited GDE Tuned
1998 TJ SE
1973 CJ5 - YJ OME 2.5" lift, 33" tires
1951 Willys truck
r_unda is offline
post #155 of 301 Old 01-08-2013, 09:51 PM
DieselDevotion
2007 WK
Moved from another thread, maybe someone can move the previous discussion too
Originally Posted by scootr29
And you are sure that they have never been changed out before? Are you the original owner? And we may want to make another thread and get out of this one.
I am not the original owner but I have complete service records and only three were previously replaced, then I also changed out another forum members glow plugs. He was the original owner and never replaced any glow plugs, there were the same part number as the ones I removed from mine.
07 Grand Cherokee Limited 3.0L CRD QDII
89 5.9 Cummins powered F350
98 TDI Jetta
DieselDevotion is offline
post #156 of 301 Old 01-08-2013, 09:54 PM
SSF556
2008 WK
Link to post I just made....
http://www.jeepforum.com/forum/f67/c...plugs-1461029/
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #157 of 301 Old 02-04-2013, 05:25 PM
flacrd
2007 WK
Thank you to those that have posted about changing glow plugs. Sorry if I missed it but what about glow plug control module? I have skimmed several sites where this was the culprit and it was recommended to go ahead and change all six and the control module? Mine just turned 31,000 miles and I was surprised to see such an early failure like this. My Florida dealer wants $54.00 for a single glow plug and $250.00 for the module and a $100. for labor. I would appreciate all comments you have on this. I am a 100% DAV and will have to have someone do the labor and really don't want to pay for it twice or more if it can be avoided
07 GC CRD
flacrd is offline
post #158 of 301 Old 02-04-2013, 07:10 PM
brew1
07 GC CRD
Last week our GC was hard to start in the colder single digit temps here in Wisconsin. Engine would crank, sputter and wanted to start. It was throwing a Glow Plug #1 circuit fault code. Plugged in the block heater and let it sit for a couple hours and it fired up without too much drama. Can run the engine and let it sit for a couple hours and it will fire up fine, provided it is still warm.
Since #1 and #2 glow plugs were the only ones I hadn't replaced yet, I replaced them yesterday and cleared the fault code. Same issue returned, engine cranks great but won't start in the cold, plug in the block heater and it would start. Fault code for Glow plug circuit #1 returned.
I picked up a Glow Plug Control Module from a local MB dealer today for $199. MB part# A6429005801, prior MB part# was A6429002800. Prices at local MB dealers ranged from $182 - $202. Local Jeep dealer was $240 with a 5-7 day special order. Only 1 MB dealer out of 3 had the part in stock, the others were a 2 day wait.
Easy install.
The module is located on the front/top of the engine to the left of silver colored intercooler tubing. Disconnect negative battery terminal clamp using a 10mm open end wrench and a flat head wrench to spread the terminal clamp. Wrap the terminal clamp in a small towel/rag. Remove engine cover (2) 10mm bolts. Remove Glow Plug Control Module mounting bracket (4) 8mm bolts, (1) 10 mm nut. Remove the two electrical connections, round one first. The oval connector was a PITA to remove due to the two plastic snaps that hold it in place. I sprayed the connector and snaps with silicone and let it soak for a few minutes and eventually pressed, wiggled, pulled and pried off the connector with the help of a flat end screwdriver.
Installation was reverse and took a little longer lining up the bolt holes and fishing out an 8mm socket that fell down between the engine block and pulley. I use a little dielectric grease on the electrical connections when re-installing. Cold engine fired right up after sitting for about 10 hours without the heater block connected. Cleared the fault code and we'll see how this fix holds up.
Hope this helps.
Mark
08 GC CRD, GDE
04 Audi A4 Wag 3.0, JHM, Revmax
03 Jetta Wag TDI, RC5, 17/22 turbo
brew1 is offline
post #159 of 301 Old 02-04-2013, 07:52 PM
jjt250
2007 WK
07 GC CRD
We ordered the glow plug module from genuinemercedesparts.com for $144 for my mom's 07 ML320 CDI.
This is the part number we used: 6429002700
There have been newer versions and revisions so that's why there are multiple part numbers. I believe that part number is the newest revision. It was smaller than the one that it replaced and now the car is running perfectly.
Here is a video of how to change it that I found on Youtube. It is very easy.
https://www.youtube.com/watch?v=6lTHsyjuquE
2007 Grand Cherokee Limited | QDII | 3.0L Diesel | S4xC Shackles Mounts | Goodyear Duratracs
Bilstein HD Front/Rear | Rusty's 1/2" Strut Spacer | Hemi XK Front/Rear Coils | HID Projectors
jjt250 is offline
post #160 of 301 Old 02-04-2013, 10:24 PM
brew1
Easy install.
Hope this helps.
Mark
Correction on my post above. The code that kept repeating itself was actually P0467 Glow Plug Module Circuit #1, not Glow Plug #1. Both the glow plug and the glow plug control module have been replaced and the vehicle is working fine.
Ordering parts online is fine if you don't mind waiting, there are some great prices from various sources, however, I like purchasing local to make sure you can compare the new part with the replacement part before purchasing.
08 GC CRD, GDE
brew1 is offline
post #161 of 301 Old 02-05-2013, 09:35 AM
flacrd
2007 WK
Thank you brew1 for the fast response and valuable info. What did you pay for the glow plugs and did you stick with OEM?
07 GC CRD
06 VW TDI
05 Liberty CRD (Lemon Lawed) after two years of patience
flacrd is offline
post #162 of 301 Old 02-05-2013, 10:09 AM
flacrd
2007 WK
Thank You
There have be newer versions and revisions so that's why there are multiple part numbers. I believe that part number is the newest revision. It was smaller than the one that it replaced and now the car is running perfectly.
Thanks jjt 250 for saving me a $$$hundred bucks vs dealers prices. I will be visiting the mb site you referenced. I found one one ebay for $$200. Where and what brand glow plugs did you go with? I found six NIB, OEM, Beru branded on ebay for $130., no tax and free shipping. Now I will pay homage to the turbo god after I have seen that they cost 2G's and a $600 intercooler as well. Better yet I will slow down before I get home and allow it to cool down properly and change the oil more frequently than the 7500 I have been.
07 GC CRD
06 VW TDI (Jetta)
05 Liberty CRD (Lemon Lawed) sadly after two years of failures from bumper to bumper
flacrd is offline
post #163 of 301 Old 02-05-2013, 09:24 PM
brew1
flacrd,
I picked a set of Mercedes glow plugs on Ebay for around $120. They appeared to be OEM Beru, same as the ones I removed.
I see no reason to change your oil more frequently than the 7,500 mile interval you currently practice unless you are not using a quality synthetic oil and not changing your air filter regularly.
08 GC CRD, GDE
brew1 is offline
post #164 of 301 Old 02-06-2013, 09:18 AM
flacrd
2007 WK
Oil changes
flacrd,
Were they ceramic or steel? Yes, I will probably stay at 7500 intervals for changes and yes I only have used Mobile 1 Turbo Diesel Oil 5w-30. I was more than pleased when Walmart started carrying this oil, by the gallon for around $29.00.
Bosch wrote me an offered six glow plug for $85. delivered. Thinking hard on this even after I have purchased the 6 Beru's. My mechanic told me he had to remove a head on a Liberty after a ceramic broke off and was un retrievable. Maybe steel glow plug is the way to go.
I am trying to locate the factory engine code, any clue to it's location? I have also found a NIB OEM module for $125.00 delivered.
flacrd is offline
post #165 of 301 Old 02-06-2013, 07:14 PM
brew1
The Beru GP are all metal. The Beru GP that came in the MB boxes were identical to the ones that I removed from the GC.
My Liberty CRD uses an Italian sourced diesel and I can't comment on the GP used in the Liberty because I've never had to replace one yet.
The GP that I replaced in my VW TDI are also all metal.
Removing the GP from the GC was quite easy. I removed them when the engine was cold and just sprayed them with some Liquid Wrench a few minutes prior to removal. Ask your mechanic to apply some anti-sieze thread compound to the threads on the GP prior to installation. The next person that has to remove the GP will appreciate it.
I'm not sure what the engine code is but I'm pretty sure if you provided the VIN from the dashboard, any Jeep dealer could probably tell you everything you wanted to know about the vehicle, including the engine.
Is the NIB OEM module for $125 a Glow Plug Control Module? I posted the latest revision number from MB in my prior post. The revised MB GP Control Module looked slightly different that the original. I'm hoping the latest revision is an improvement over the original. It seems quite a few of the original units met a premature death. My GC is at about 99,000 miles, but I have to seen several posts where the module expired at much lower mileage.
In any case, I've decided to run the GC without the plastic engine cover to help dissipate heat from sensitive electronic modules trapped under the engine cover. I understand the GDE Hot Tune that the GC is currently running may cause some extra heat to be generated by the turbo.
Good luck with your GC!
Mark
08 GC CRD, GDE
brew1 is offline
Glow Plug life roadman WK Grand Cherokee & XK Commander Forum 59 03-25-2016 12:17 AM
CRD #6 Glow Plug Circuit Error tallguy6464 WK Grand Cherokee & XK Commander Forum 26 01-07-2014 05:26 PM
Glow plug burnout smitheeee WK Grand Cherokee & XK Commander Forum 5 10-04-2012 02:14 PM
glow plug issue not solved roadman WK Grand Cherokee & XK Commander Forum 8 10-09-2008 04:58 PM
why canīt find glow/reverse glow gauges overlays for 2000 GC ? eschapiro ZJ Grand Cherokee Forum 0 02-14-2007 02:32 PM
