CRD exhaust tip - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > CRD exhaust tip
KrawlOff-Road.com now Carries Iron Rock Off Road!!!!!Toxic Brakes - 3000 PSI Braided Stainless Steel Brake LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 04-26-2015, 06:23 AM   #1
plunix
2008 WK
CRD exhaust tip
I'm considering removing the resonator at the end of my stock CRD exhaust.
It's currently set up with a down turn exhaust at the tip. Would you guys recommend a similar style exhaust tip? Having a white car has me worried about soot build up from a straight tip, even though they look better in my opinion.
Stock piping is 2.75" diameter. What measurements would I need on an exhaust tip for proper fitting? Or can step up to fill the gap with another piece? I've seen nice ones with 4" receiving end, so I'm wondering if they're obsolete for my requirement.
2008 Jeep Grand Cherokee CRD
GDE Hot Tune
Turbo Resonator Delete
plunix is offline   Reply With Quote Quick reply to this message
Unread 04-26-2015, 09:37 AM   #2
oldsmoke
2009 WK
The stock exhaust tip is tucked up in there tight so that it doesn't get hit by rocks, tree stumps, dirt piles, etc. etc. when you go offroading. I know it does not look very sexy but it doesn't soot up the back of your vehicle and adding a tip will seriously reduce your departure angle.
Diesel Ecotune-DPF, 32" tires, 2" lift. 4xGuard bib, tow hooks
oldsmoke is offline   Reply With Quote Quick reply to this message
Unread 04-26-2015, 10:57 AM   #3
SSF556
SSF556's Avatar
2008 WK
This
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline   Reply With Quote Quick reply to this message
Unread 04-26-2015, 02:53 PM   #4
TurboDiesel
2008 WK
i love mine
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline   Reply With Quote Quick reply to this message
Unread 04-27-2015, 09:34 AM   #5
plunix
2008 WK
Originally Posted by TurboDiesel View Post
i love mine
That's exactly what I want, but in black.
Did you get a straight pipe welded in there with a bolt on tip or get a tip welded?
GDE Hot Tune
Unread 04-28-2015, 07:57 AM   #6
caddydaddy
2007 WK
Is it a 2.75" ID or OD pipe? I've been thinking of removing the resonator as well.
I've thought about just clamping a pipe on there, since I don't have a welder.
2007 CRD Grand Cherokee Limited 4x4
GDE ECO Tune, Turbo Resonator Delete
173,000+ miles!
caddydaddy is offline   Reply With Quote Quick reply to this message
Unread 04-28-2015, 05:16 PM   #7
TurboDiesel
2008 WK
cut reso off
slide 3" pipe over stock pipe
weld
done! sounds sick with dpf delete
Unread 04-29-2015, 11:04 AM   #8
oldsmoke
2009 WK
cut reso off
weld
HaHaHa, and with the dpf delete you get pretty good smoke to enrich that outlaw image even more. I'd have to dye my hair first
Unread 04-29-2015, 06:15 PM   #9
TurboDiesel
2008 WK
uhmm barely get any smoke and only when u stomp on it...more like a cough..i never see it in my mirrors
Unread 04-29-2015, 06:21 PM   #10
SSF556
SSF556's Avatar
2008 WK
should be no smoke...
2008 CRD QT2
Unread 04-30-2015, 06:47 AM   #11
oldsmoke
2009 WK
Well, to be honest I haven't seen it because when I have my foot to the floor I'm to scared to look in the rear view mirror but my buddy claims there is smoke.
Unread 04-30-2015, 07:03 AM   #12
TurboDiesel
2008 WK
i get alittle cough if anything...even in my exhaust video u can see alittle puff but i wouldnt call it shooting smoke
Unread 04-30-2015, 07:21 AM   #13
caddydaddy
2007 WK
Don't be ashamed to roll coal! All the cool truckers are doing it these days!
173,000+ miles!
Unread 04-30-2015, 03:01 PM   #14
oldsmoke
2009 WK
So what? I gotta get an exhaust cam now? I'm sure as hell not putting back my particulate filter. Ignorance was bliss untill my good buddy riding shotgun claims he spys smoke as we totally blow the luggage rack off a Toyota FJ.
Unread 04-30-2015, 06:08 PM   #15
TurboDiesel
2008 WK
i dont know if ur pissed he claims it blows smoke
or u want it to blow smoke
either way it doesnt really do much...
