crd engine tdc performance chip - Page 9 - JeepForum.com
post #121 of 223 Old 07-24-2008, 01:23 PM
mister17_5_9
^^^ yeah... and what are the #s for power increases?
-05 Dodge Ram 1-ton, 3.73s, G56... MP-8, SBC DD 3600#, Airdog 150, CFM+, AEM intake, FBD 5" turbo-back, AMSOIL bypass
-06 Jeep COMMIE... with the 5.7L exhaust leak king HEMI
-and a bit of wrench work on some 07 CRD which is heavily UN-modified... lol
mister17_5_9 is offline
post #122 of 223 Old 07-24-2008, 02:19 PM
Mish_Mish
Mish_Mish's Avatar
2008 WK
Originally Posted by Three Oh DSL View Post
Increased rail pressure? Possible VGT actuation augmentation?
Would you happen to have a Gtech or Dash Hawk? I'd like to see what kind of est. E/T your getting.
Sounds pretty cool!
I do not have any aftermarket gages. I would like to get exhaust temp meter, always liked it on my turbo Isuzu.
06 Touareg V10 TDi
Mish_Mish is offline
post #123 of 223 Old 07-24-2008, 02:20 PM
Mish_Mish
Mish_Mish's Avatar
2008 WK
Originally Posted by LJS8510 View Post
how much did this set you back?
Total $1055 US clams.
06 Touareg V10 TDi
post #124 of 223 Old 07-24-2008, 02:22 PM
Mish_Mish
Mish_Mish's Avatar
2008 WK
Not sure, how would I tell without dyno?
They promise 272hp at 450lb.ft, but who knows for sure what it comes up to in reality.
Car feels a lot different, like it lost 500lb. Takoff lag is almost gone, she feels now like gas vehicle. Will see on the long run.
06 Touareg V10 TDi
post #125 of 223 Old 07-24-2008, 02:47 PM
LJS8510
LJS8510's Avatar
2015 WK
sounds good please keep us up to date!
thanks
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #126 of 223 Old 07-24-2008, 05:38 PM
Rocketron
2008 WK
More power.... more fun
Good Job!! Is this a "Plug and Play" unit? Or are there adjustments to fine tune it to your vehicle requiring a service tech? Exciting news, please tell us more. It looks like more wires than my TDC cr plus. How long to install and have you had any CEL lights to deal with? Last question, where can I get mine???? Thanks man! Have fun. As for me, I am still waiting for new MBRP Filter back, 3" exhaust to be delivered. I have located "Dry Cone Filter" with 3.25" ID from AEM. And from research AEM seems to be one of the better dry filter. I found it on thier web site and I have ordered one.
Rocketron is offline
post #127 of 223 Old 07-24-2008, 06:17 PM
Mish_Mish
Mish_Mish's Avatar
2008 WK
There are 5 points where it attaches between sensor and the engine harness.
Boost pressure sensor
Cylinder 1 injector
Cylinder 4 injector
Fuel rail pressure sensor
and Quality control sensor on the fuel pump (I think)
Also one attachment to the ground.
Mercedes installation has controller box mounted next to strut plate, in separated from under hood heat area, in my case, I ran harness through the firewal and mounted controller box inside the dash, next to fuse box.
Engine started and ran for the first time like nothing changed, no CEL, no RPM jumping.
I actually just came back from dealership, they activated my towing harness and ran system scan. Everything checked out fine, no remarks, Brabus box is invisible to them.
So far I feel no difference in operation, just performance is different.
I found my box on eBay, some nice guy from UK is selling all kinds of MB and Brabus parts. If I was looking for something similar, I'd get cheaper Spider box, stat is supposed to be even better:
http://www.dieseltuning.co.uk/chrysl...el-tuning.html
You can buy directly from them, they will ship to US.
BTW, here is picture of inside the Brabus box (as far as I could open it), I suppose there is more than just resistors in there.
06 Touareg V10 TDi
post #128 of 223 Old 07-25-2008, 02:59 PM
Oh goodness, I hope its not the one I'm picturing. Although it's the right neck size, the cone length is very short. If you get this before you open the box, double-check the overall length. Good luck.
---- is offline
post #129 of 223 Old 07-25-2008, 04:41 PM
Rocketron
2008 WK
aem dry filter, 5" or 9"?
I did not know which length to order so I ordered the 5" because I was not sure the 9" would fit in the space. I have not received it yet. Which would you recommend?
post #130 of 223 Old 07-25-2008, 05:01 PM
I'm using the gray dry media filter. It measures 7" from the filter neck to the top. They may have released a new series which fits the specs needed. Do you have a part number for the filter you ordered?
-If the overall length is greater than 5" the filter you ordered should work just fine.
---- is offline
post #131 of 223 Old 07-25-2008, 06:00 PM
Rocketron
2008 WK
Thank you for your information. Most helpfull. Is the Spider box similar to the Cr Plus box I already have? Or does it re map part of the ECU? I think the Brabus remaps part of the ECU, is this correct?
Thanks and look forward to udates of how Brabus is working for you.
Cylinder 1 injector
Cylinder 4 injector
post #132 of 223 Old 07-25-2008, 06:13 PM
Rocketron
2008 WK
aem dry filter
The part number for the 5" I ordered is 21-2110 and the part number for the 9" is 21-2109. I believe 5" refers to th length of the filter media.
post #133 of 223 Old 07-25-2008, 08:37 PM
Mish_Mish
Mish_Mish's Avatar
2008 WK
Spider is more advanced, it has 2 maps, one economy and one power, it switches between these two automatically, based on your driving. I am not sure how these compare to CR and stuff, because all CR connects to is fuel rail, meaning it probably works on more primitive level than Spider.
06 Touareg V10 TDi
post #134 of 223 Old 07-27-2008, 06:06 AM
s3eblue
2007 WK
The Spider only controls fuel pressure and pulse width and plugs into the rail just like the others, but it's able to switch performance modes by monitoring RPM and load, it's a little more expensive than most performance boxes but once it's installed you start to discover why. If any of you have any question's just email Mike at Spider, there really proud of there product and have been one of the best companies I've ever dealt with.
s3eblue is offline
post #135 of 223 Old 07-27-2008, 09:39 AM
Mish_Mish
Mish_Mish's Avatar
2008 WK
So what is different about Brabus box then? Does the fact that it connects to 5 points, instead of 1 mean it is more advanced?
BTW, it was day 3 of my driving with brabus box and I think it fine tuned itself to match the engine.
Take off delay is much less notieceable now, it is now about the same as medium sized gas engine with A/C on.
Top end power went up a lot, acceleration from 65 to 90 mpg now feels like i am in 3000lb turbo coupe. I think my old V12 Jaguar has more lag on highway than GC.
If I can trust fuel economy counter, city mpg went up. It now stays at 21 mpg solid, however highway mpg is yet to be seen. I am going 260 mile trip today, se we will see how she does. If fuel economy gage is based on cacuum, while tuner box is expanding injection phase, than actual fuel economy is going to decrease. I will see what my calculator says at the next visit to pump. BTW, yesterday I filled up at $4.03/gal, fuel did go down a bit.
06 Touareg V10 TDi
ZJ Performance chip etfuller ZJ Grand Cherokee Forum 26 08-04-2012 10:13 PM
Performance Chip RingRingRing ZJ Grand Cherokee Forum 3 12-07-2008 09:09 PM
performance chip help mpg???? Audienceofone ZJ Grand Cherokee Forum 5 07-23-2008 11:05 AM
Performance Chip?? thejeeper02 ZJ Grand Cherokee Forum 4 09-26-2006 10:49 AM
What performance chip?? BradBurdett ZJ Grand Cherokee Forum 2 04-12-2005 01:09 AM
