crd engine tdc performance chip - Page 3 - JeepForum.com
post #31 of 223 Old 05-20-2008, 01:46 PM
boxcab
boxcab's Avatar
2007 WK
Originally Posted by Three Oh DSL View Post
The DPF in the '07 model year JGC has *what appear to be* two fuel delivery lines.
Those tubes lead to pressure transducers in the engine bay. They determine soot loading across the DPF.
Doug
2007 WK CRD
boxcab is offline
post #32 of 223 Old 05-20-2008, 02:09 PM
Aha, thank you! I was begining to rethink my theory today when I loaded the new DashHawk version and was able to read from these sensors.
---- is offline
post #33 of 223 Old 05-21-2008, 11:37 AM
bigd450
2007 WK
What can all be read from your Dashhawk. The important things I would want are EGT, rail pressure, fuel pressure, boost. Hitting 1350-1400 egts for short times will be fine 1500-1600 I wouldnt let it say there for more then a second.
Do you know what your boost and rail pressure were at when it was stock vs the TDC? How many levels are on the TDC?
bigd450 is offline
post #34 of 223 Old 05-21-2008, 09:38 PM
Big news folks!
Tested EGTs without the CR box connected... The "stock" setup will reach and exceed exhaust temperatures of 1250*F. Not joking here...
Anyhow, I thought I would let all know.
bigd450: The DashHawk is limited only by the available PIDs (readings) the onboard computers are reading. There's a growing list of PIDs located HERE. -Happy motoring!
---- is offline
post #35 of 223 Old 05-22-2008, 08:31 AM
bigd450
2007 WK
Big news folks!
Did you happen to notice what your boost and rail pressure were at with the box off. Just curious to see the performance difference and how the TDC is actually making more power.
bigd450 is offline
post #36 of 223 Old 05-22-2008, 09:40 AM
LEDFoot
Are there any CRD performance tuner that actually manipulate boost levels and things like that rather than just overfuel?
--Martin
_____________________________________
'99 WJ 4.7 Quadra-Drive w/ 242HD swap... 2WD since my front diff is kaputt :(.
LEDFoot is offline
post #37 of 223 Old 05-22-2008, 10:57 AM
mister17_5_9
the boost with that box is still wastgating at ~23psi... the rail pressure does not change from stock... the turbo will spool faster with the increased amount of fuel injected.
The way the CR box makes power is by increasing the duty cycle of the injectors and *maybe* changing the injection timing
mister17_5_9 is offline
post #38 of 223 Old 05-22-2008, 01:19 PM
I have another data log run from the DH that I've yet to post. I'll get that up here this eve for comparison. The new run was taken without the CR box.
---- is offline
post #39 of 223 Old 05-26-2008, 11:49 AM
With CR Powerbox
Without CR Powerbox
Attachment 49051
---As you can see, acceleration has decreased, while EGTs have stayed relatively the same.
Note, runs were from approx. 38MPH to about 70MPH. Speed is light blue in the first chart and yellow in the second.
Another neat trend is how regular the fuelPSI is from the first graph to the other. A smoother, more consistent line is had with the Powerbox versus without.
---- is offline
post #40 of 223 Old 05-30-2008, 02:47 PM
mitek
2008 WK
Powerbox CR
Hi there!
I was wondering what setting are you at with Powerbox CR? I guess the box was preset from the factory at 12 turns which is 60% of the total increase. I just installed mine today and turned the screw another 6 turns counter clockwise. The performance increase is awesome! I just wonder if it is ok for the engine.
mitek is offline
post #41 of 223 Old 05-30-2008, 05:21 PM
I'm using full power as is stated in my signature. Level 24 makes the CRD a bigger, fiercer beast. If you're nice to the throttle, it'll pay you back with increased MPG. Congrats on your new mod! Also, be sure to join the WK Diesel group. Click in my sig to team up.
---- is offline
post #42 of 223 Old 05-30-2008, 08:39 PM
mitek
2008 WK
Thank you! I just noticed that you have diagnostics equipment installed in your Jeep so I thought better to ask you if there are any potential problems I should look out for. I understand there are no problems with overheating or anything like that?
Cheers
mitek is offline
post #43 of 223 Old 05-30-2008, 09:09 PM
No sweat. Just make sure you don't run it full throttle for and longer than a 1/4 mile on a flat. My EGTs have run as high as 1380*F with no problem. Running the temps at 1350 or higher for long durations will kill the engine. I would recommend a pyrometer be it digtal (my preference) or analog. Have fun!
---- is offline
post #44 of 223 Old 05-31-2008, 08:43 PM
magellan
My main point in getting a CRD was to run bio diesel. I want ot go through at least one more regne cycle and get my oil analyzed again before going up to B20 (running B5 now). I would like to do anything I can to increase mileage, so if a PowerBox will do that, I'm in. Does anyone know if it will work with BD?
Also, Three-oh, would love to see some pics of your intake. All K&N offers is a drop in, which will help with mileage, but probably not as much as something more open.
magellan is offline
post #45 of 223 Old 06-01-2008, 01:26 PM
Check the WK picture thread on page four (i believe) post 240 or thereabouts. the last picture is pretty close to what i'm running now. Let me know if you have any questions.
---- is offline
ZJ Performance chip etfuller ZJ Grand Cherokee Forum 26 08-04-2012 09:13 PM
Performance Chip RingRingRing ZJ Grand Cherokee Forum 3 12-07-2008 08:09 PM
performance chip help mpg???? Audienceofone ZJ Grand Cherokee Forum 5 07-23-2008 10:05 AM
Performance Chip?? thejeeper02 ZJ Grand Cherokee Forum 4 09-26-2006 09:49 AM
What performance chip?? BradBurdett ZJ Grand Cherokee Forum 2 04-12-2005 12:09 AM
