crd engine tdc performance chip - Page 10 - JeepForum.com
post #136 of 223 Old 07-27-2008, 09:49 AM
YES! Diesel certainly went down!
As stated earlier: The "CR" [Common Rail Temperature Sensor] connection points for the D6, Spider and TDC all share a similarity; as do DiabloSport and others for the Cummins, etc. The tuning modules for the CRD are adding fuel, which is accomplished several ways as most of us know. Torque increases are relatively similar among all tuning boxes.
The boost pressure sensor for the D6 is increasing boost and possibly modulating other parameters to compensate for specific environmental conditions. The basic idea is more boost = more horsepower. The Brabus (on paper thus far) makes the most horsepower gain over the alternatives on the market. I would guess the boost pressure has been increased from 23-4psi to 28-30psi. Generally speaking, 1psi is roughly equal to 10hp at the crank.
The number 1 and 4 cylinder connections are likely increasing duty cycle and/or injection pressure. Stock inj. PSI is 24,000. I'm curious, does the Brabus connect to the CP3 (high pressure pump)? This would be the black Bosch box attached to the cam area of the right bank.
Of course, this is only my best educated guess.
---If anyone is interested: It would be fun to put a couple runs in on the track with another tuned CRD. But I'm probably just dreaming. Haha!
---- is offline
post #137 of 223 Old 07-27-2008, 04:43 PM
Mish_Mish
Mish_Mish's Avatar
2008 WK
All that sounds very harmful to engine. I wonder how Brabus was able to swing all these terrible for reliability things under Mercedes warranty?
I just came backfrom 300 mile trip, economy meter shows 23mpg, usually it is underestimated 1.5mpg, meaning that actual calculation will show 24-25mpg.
One thing bothers me the most, that damn low gearing. Other cars are going 80-85mpg at 2000-2500 rpm, when I am racing my over torqued diesel at 3000. After 3000 rpm engine becomes even louder and sounds like hot rod with straight pipes, so going 90 mph+ for me is out of question. I wish there was sixths gear on my transmission, or maybe different gear ratios for this one.
I hope some tuner company comes up with ring and pinions + transmission software to regear CRD's, for those who do not need to tow 7400lb. We could be cruising 80mph at 1800rpm and get 30mpg like we should be able to.
06 Touareg V10 TDi
Mish_Mish is offline
post #138 of 223 Old 07-28-2008, 10:01 AM
mister17_5_9
I would think it would be a good thing to beat a tuned cummins on the street before taking on a Diesel GC at the track... lol...
-05 Dodge Ram 1-ton, 3.73s, G56... MP-8, SBC DD 3600#, Airdog 150, CFM+, AEM intake, FBD 5" turbo-back, AMSOIL bypass
-06 Jeep COMMIE... with the 5.7L exhaust leak king HEMI
-and a bit of wrench work on some 07 CRD which is heavily UN-modified... lol
mister17_5_9 is offline
post #139 of 223 Old 07-28-2008, 10:17 AM
I thought only auto trannys were supposed to slip?! Hmmmm....
---- is offline
post #140 of 223 Old 07-28-2008, 11:29 AM
mister17_5_9
you've seen the new clutch awaiting install... lol
x-mod ehh??? that wouldn't have to do with the box full of stuff sitting in my garage would it? lol...
post #141 of 223 Old 07-28-2008, 12:26 PM
Mish_Mish
Mish_Mish's Avatar
2008 WK
I would like to take my GC to 4 wheel dyno, but not sure where to find one in my area.
I suppose torque went up a bit. Today I was going 20mph, hammered it and felt my entire car lean to the right, very odd.
Ok, I just found AWD dyno in Columbus, it is $75 for 3 pulls. Tomorrow at 4pm I am scheduled. Hopefully will have more than 150hp
06 Touareg V10 TDi
post #142 of 223 Old 07-28-2008, 07:51 PM
Let's imagine that was your left hand on the wheel, pleading with the merciless torque to relinquish its constrictor-like grasp.
---Or a puddle..
Lets see some dyno charts!!
---- is offline
post #143 of 223 Old 07-29-2008, 04:46 PM
Mish_Mish
Mish_Mish's Avatar
2008 WK
I got dyno results, will post graph and video after 9 pm.
For now, she pulled 215hp/380lb/ft at all 4 wheels. Supposedly with 19% drivetrain correction it comes up to around 260/450 at the crank.
Seeing my car run and whistly on dyno was a little freaky
06 Touareg V10 TDi
post #144 of 223 Old 07-29-2008, 04:52 PM
no-blue-screen
2008 WK
Sounds like a lot of fun :0
SOLD 2008 WK CRD Limited 4x4 - Jeep Green
no-blue-screen is offline
post #145 of 223 Old 07-29-2008, 07:20 PM
mitek
2008 WK
Looks like Brabus is right on the money with their numbers except MISH has the K@N that claims 10hp by itself. So may be the drivetrain loss is a little more than 19%..
mitek is offline
post #146 of 223 Old 07-29-2008, 09:46 PM
Mish_Mish
Mish_Mish's Avatar
2008 WK
HERE IS THAT VIDEO
Do you think the fact that read drum did not stop insync with the front one might have damaged something im my AWD system?
06 Touareg V10 TDi
post #147 of 223 Old 07-30-2008, 07:55 AM
LJS8510
LJS8510's Avatar
2015 WK
I would doubt it, your 4wheel drive is made to take a lot of off road abuse.
do you think your delay from dead stop is gone?
2015 WK II 5.7 Overland, Offroad Group II,- 2008 WK Limited 3.0 CRD, - 2003 WJ Laredo 4.7, - 2001 WJ Laredo 4.0, - 1999 WJ Limited 4.7-
LJS8510 is offline
post #148 of 223 Old 07-30-2008, 08:48 AM
Mish_Mish
Mish_Mish's Avatar
2008 WK
It is gone as far as when I punch pedal and engine chokes for a half second. It now acts more like gasoline engine, however still it is a little sluggish as any diesel would be from start. On sunday I had to jump left to clear intersection and did not have the usual scare, I even thought about it later when I realized that I did not have to compensate for slow take off.
06 Touareg V10 TDi
post #149 of 223 Old 07-30-2008, 08:50 AM
Cool. Were you able to upload the charts?
---- is offline
post #150 of 223 Old 07-30-2008, 09:03 AM
LJS8510
LJS8510's Avatar
2015 WK
that is what I want to hear!
thanks
LJS8510 is offline
ZJ Performance chip etfuller ZJ Grand Cherokee Forum 26 08-04-2012 09:13 PM
Performance Chip RingRingRing ZJ Grand Cherokee Forum 3 12-07-2008 08:09 PM
performance chip help mpg???? Audienceofone ZJ Grand Cherokee Forum 5 07-23-2008 10:05 AM
Performance Chip?? thejeeper02 ZJ Grand Cherokee Forum 4 09-26-2006 09:49 AM
What performance chip?? BradBurdett ZJ Grand Cherokee Forum 2 04-12-2005 12:09 AM
