CRD Diesel engine manual? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > CRD Diesel engine manual?
Dana 30/ Dana 44 Chromoly shaft Kits- ECGSFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitFlowmaster's Force II Axle-back exhaust system for the 201
Unread 07-07-2014, 08:22 PM   #1
TangoTango
2008 WK
Anyone have the pdf engine manual for the wk?
or have the injector bolt torque spec's?
I'm after the torque spec's for the injector bolts.
My injectors started leaking, so I took them out. The bolts and the copper o-rings are a one time used thing, and copper o-ring was the problem.
I'm looking for the torque spec's so I can put it back together tomorrow morning.
FYI these injectors do not look like they can go more than 100k before and R&R but I do not see them on the maintenance list. The o-ring copper seals are just junk and the plastic parts for the return line are just a problem waiting to happen. ALL under the black owner no-see-me foam. (vent)
TangoTango is offline   Reply With Quote
Unread 07-08-2014, 07:53 AM   #2
tnadanzig
tnadanzig's Avatar
2007 WK
I have the manual, but not in PDF. It's at home. I will look them up and see what the bolt torque is.
CB Engineering
CB-engineer.com
2008 3.0L CRD WK LTD - Wifes, GDE DPF Delete Tune, Turbo Resonator Delete, 3" Intercooler, Addcoo Rear Sway Bar, 3.07 gears
2007 3.0L CRD WK LTD - Stage 2 Custom Spooling Tune, Go Fast Parts
Pro-lite Build
2003 F250 6.0L CCLB - Gearhead Tunes
tnadanzig is offline   Reply With Quote
Unread 07-11-2014, 05:10 PM   #3
TangoTango
2008 WK
bump
Anyone have the CRD engine manual in PDF format?
Unread 07-16-2014, 10:48 AM   #4
tnadanzig
tnadanzig's Avatar
2007 WK
I don't have the manual in PDF, but the injector retaining clamps are torqued to 7 Nm plus 180 degress.
CB Engineering
CB-engineer.com
Pro-lite Build
Unread 07-16-2014, 03:20 PM   #5
furiousbudy
2008 WK
I will upload the PDF after work
furiousbudy is offline   Reply With Quote
Unread 07-16-2014, 04:25 PM   #6
TangoTango
2008 WK
Thanks got it!!
