CRD camshaft position sensor location? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > CRD camshaft position sensor location?
Unread 06-13-2013, 01:07 PM   #1
sshaughn
2008 WK
Need help, got a P0340 code and looking for the camshaft position sensor. Does anyone have a picture of where this is located? Thanks in advance
2008 WK Overland 4WD CRD 3.0L, QD2, Green Diesel Engineering Hot-Tune, MBRP Exhaust, CB Engineering Turbo Resonator Delete Pipe, Kolak Addco Rear Sway Bar, K&N Air Filter, Propel Fuels B20 Biodiesel
sshaughn is offline   Reply With Quote Quick reply to this message
Unread 06-13-2013, 04:21 PM   #2
suzieque
2008 WK
looks to be between cylinder #1 and #2 on the right hand side of the engine. You will have to remove the noise insulation foam to see the plug.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline   Reply With Quote Quick reply to this message
Unread 06-13-2013, 04:37 PM   #3
sshaughn
2008 WK
Thanks Suzieque! I think I looked everywhere except under the foam. Cheers!
Unread 06-13-2013, 05:04 PM   #4
suzieque
2008 WK
I do not like this diagram because the cylinder numbering is incorrect. 1-2-3 are on the right side, front to back. 4-5-6 are on the left side, front to back. But I didn't see anyone else answer your question, so I thought I'd post the picture I had.
