CRD Break-In Period - JeepForum.com
post #1 of 11 Old 06-23-2009, 12:01 PM Thread Starter
WKJPSTR
2008 WK
CRD Break-In Period
Greetings. I am new to the WK world, but have currently have a 2006 VW TDI. I have not been able to find much guidance beyond the owner's manual about break-in periods. Is the following advice for the TDI applicable to the CRD:
Rules that apply for the life of the car
-When the engine is cold (below the first 3 white marks at the base of the temp gage) rev the engine to at least 2,500 rpms.
-When the engine is warmed up (above the first three white marks) Rev the engine to no less than 3,000 rpms.
The reason for this is to keep the turbo on boost, clear the VNT guide vanes and apply firm pressure to the rings for optimal sealing against blow-by gasses. The rings need the boost to seal since its a turbo charged engine, babying the engine is detrimental and will lead to issues with compression if done so for very long.
First 1,000 miles
Keep rpms below 3,800. Avoid steady rpms. Frequent firm application of power is strongly recomended up to 3,800 rpm. Avoid the use of cruise control so that you naturally fluctuate the power with your foot.
1,000-5,000 miles
Use the full 5,100 rpm power range. Avoid steady rpms. Avoid the use of cruise control. Frequent application of full throttle is recomended to help seat the rings. City driving is ideal for breaking in a TDI due to frequent stops and acceleration. Once you get to 5,000 miles change the oil and perform your first service per the manual
5,000-10,000 miles
Use of the cruise control is ok at this point since most of the initial break in has occured. Continue to use occasional full throttle accelerations to continue to seat the rings. You will notice the engine become slightly louder during this phase due to less friction from the engine breaking in (normal for a diesel to become louder under lighter loads). If your going on a long drive and you are using the cruise, every so often step on the peddle to accelerate up about 20 mph then coast back down to your preset speed.
10,000-60,000
This is when the rest of the break in occurs. The engine from the factory will check out with about 475psi of compression pressure out of the crate. It will take at least 60,000 miles to reach the peak pressure of 550psi. For the most part once you get to 10,000 miles your compression will be around 510psi meaning that most of the break in has occured.
60,000-the life of the motor
The engines I have seen so far using a 5w40 oil are maintaining 550 psi of compression pressure with over 200,000 miles on the odometer. The owners have followed the advice above and do not have any oil consumption issues. This also means that with the higher pressure the engine is more efficient returning optimal fuel economy and reduced smoke output.
Thanks for any insights.
WKJPSTR is offline
post #2 of 11 Old 06-23-2009, 02:08 PM
chadhargis
2008 WK
60,000 mile break in! Wow!!
I've always been a big fan of this guys techniques for all engines:
http://www.mototuneusa.com/break_in_secrets.htm
Works like a charm for motorcycles.
Might want to use some common sense with the oil change interval and synthetic oil (since I don't think any dino oil meets the spec).
Chad Hargis
Nashville, TN
2008 Grand Cherokee CRD
chadhargis is offline
post #3 of 11 Old 06-23-2009, 02:13 PM
TonyVideo
TonyVideo's Avatar
2008 WK
I have always heard to use it hard and not baby it. I use interstate on ramps to get on it while getting up to speed. I surprise quite a few people on how fast it gets up to speed being a diesel. This is not great for fuel mileage but is fun.
Tony
2008 GC 3.0L CRD Limited, ProVent Installed, Clear Bra, Scangauge
1999 GC 4.0L Larado
1985 Jeep Larado 4.0L Sold
TonyVideo is offline
post #4 of 11 Old 06-23-2009, 07:56 PM
chadhargis
2008 WK
Fuel mileage be damned.....I love nailing the throttle and feeling that torque.
Chad Hargis
Nashville, TN
post #5 of 11 Old 06-23-2009, 07:58 PM
SSF556
2008 WK
Read the owners manual for the CRD...none of the stuff you mention is in the owners manual. Page 68 specifically says "A long break in period is not required for the engine in your new vehicle."
5000 miles until you can use the cruise control is funny.....is the info mentioned by the OP actually in the VW manual?
SSF556 is offline
post #6 of 11 Old 06-23-2009, 08:00 PM
SSF556
2008 WK
.is what my wife does when I hit the torque button...
SSF556 is offline
post #7 of 11 Old 06-24-2009, 08:57 AM
chadhargis
2008 WK
Mine too.
Thank goodness my 4yo daughter shouts with glee, "Go faster daddy!". Ah...I've trained her well!
Chad Hargis
Nashville, TN
post #8 of 11 Old 06-24-2009, 09:37 AM
colinzj
2006 WK
You've raised that kid right for today, but that's gonna come back and bite you in 12 years.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is offline
post #9 of 11 Old 06-24-2009, 03:23 PM
chadhargis
2008 WK
Oh no....no it won't.
When she turns 16, Daddy and her will be attending the Skip Barber school at Road Atlanta.
http://www.skipbarber.com/driving_sc...ng_school.aspx
Chad Hargis
Nashville, TN
post #10 of 11 Old 06-24-2009, 09:09 PM
NDSU_Bison
2014 WK
I always begged my dad to drive through puddles and he usually obliged. I still like to drive through puddles.
Mine too.
NDSU_Bison is offline
post #11 of 11 Old 06-25-2009, 06:32 AM
Mish_Mish
Mish_Mish's Avatar
2008 WK
I put 21K on my CRD and it still was blowing some oil through CCV, however compared to brand new it was day and night. After some miles engine became much easier to spin, about 15% more economical and quicker to rev up.
I still have it sitting in my yard, until car hauler is gonna show up...
06 Touareg V10 TDi
Mish_Mish is offline
99 WJ - Disconnecting the battery for a long period of time? MajorJeep ZJ Grand Cherokee Forum 4 10-23-2008 09:52 AM
Hemi fuel economy during break-in period Marcus86GLHS WK Grand Cherokee & XK Commander Forum 26 05-06-2008 05:23 AM
Do U joints have a break in period or..... NHJeeper ZJ Grand Cherokee Forum 3 10-12-2006 01:24 PM
Engine break in period? nationm ZJ Grand Cherokee Forum 7 06-28-2006 10:27 AM
Battery disconnected for extended period: 2001 WJ won't move Andre ZJ Grand Cherokee Forum 5 07-11-2005 10:22 AM
