CRD Bad swirl motor symptoms? - JeepForum.com
post #1 of 10 Old 12-15-2010, 09:52 AM Thread Starter
Bzwth
2008 WK
What kind of problems/symptoms occur when a swirl motor goes bad?
Bzwth is offline
post #2 of 10 Old 12-15-2010, 01:00 PM
rsq41
2007 WK
If I recall (my mind is trying to block it), the jeep went into limp mode. They told me I needed a new computer... I told them it was the swirl motor based on what I had read here.. Waited days for computer to arrive... New computer did not help.. Then they fixed the swirl motor and all has been good since...
They had done up the turbo intake seal just a few weeks prior to all this...
07 CRD
rsq41 is offline
post #3 of 10 Old 12-16-2010, 11:51 AM
4running
Is there alot of oil on the outside of your swirl motor?
4running is offline
post #4 of 10 Old 12-16-2010, 06:53 PM Thread Starter
Bzwth
2008 WK
I have the new intake tube now so oil doesn't drip oil down onto it anymore. But down around the area where the swirl motor is, it has almost 30K miles of burnt, caked on old oil residue/carbon still down there from when it did. I'm thinking it could go out or start acting up at any time. Just wanting to know what to watch for.
Bzwth is offline
post #5 of 10 Old 12-17-2010, 08:13 AM
suzieque
2008 WK
start by searching in this forum for the word "swirl" and then sit back and read.
I've read a couple threads now about guys that pressure washed their CRD's engine and reported no ill side effects, mostly after oil leaks. I've briefly and carefully washed the area below my turbo tube just to try and wash away the residue that was on before I bought my Racor and so far I've not had a problem, maybe you want to try and do some washing like that too.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #6 of 10 Old 12-17-2010, 08:19 AM
zedtechus
2008 WK
Hi Bzwth,
I totally agree with you, I changed my intake tube at around 31k miles too under the warranty... but like you I'm really worry that the swirl motor could go out anytime and my standard warranty will expire in just about 2 months
2008 GC CRD Laredo - QT II - Jeep Black with 18" chrome wheels
zedtechus is offline
post #7 of 10 Old 12-17-2010, 09:18 AM
SSF556
2008 WK
You could always try some brake cleaner....I have done that on several occasions. I spray some under the turbo and down in the V...hopefully it cleans up some of the oil that has leaked in the past. I changed out to the new seal about 30,000 miles ago and I have not seen any oil leaks since.
SSF556 is offline
post #8 of 10 Old 12-17-2010, 11:23 AM Thread Starter
Bzwth
2008 WK
Originally Posted by zedtechus View Post
Hi Bzwth,
My warranty goes out in 2 months as well. If it is going to go out, I'd like to know now.
I'll search swirl and read up on it a bit and maybe try some cleaning as well and see how that goes.
Bzwth is offline
post #9 of 10 Old 12-27-2010, 11:20 PM
Burner
2008 WK
Ok newb question to for the CRD motor. What does this swirl motor do?
Burner is offline
post #10 of 10 Old 12-28-2010, 01:45 PM
fred99x
2008 WK
fred99x is offline
WK CRD: Swirl Motor Question for the experts Drewd WK Grand Cherokee & XK Commander Forum 19 02-12-2013 05:41 PM
CRD - cleaning swirl valves wookiee WK Grand Cherokee & XK Commander Forum 12 08-25-2010 01:43 PM
Canada - 5 year / 100,000km Powertrain Warranty - CRD Swirl Motor Covered? jjandersonn WK Grand Cherokee & XK Commander Forum 3 08-10-2010 02:51 PM
Swirl motor and turbo inlet mod ... where to fit Racor or Provent ianrmz250 WK Grand Cherokee & XK Commander Forum 26 08-02-2010 03:45 PM
Swirl valve parts mr12volt WK Grand Cherokee & XK Commander Forum 25 08-01-2010 01:59 PM
