CRD #6 Glow Plug Circuit Error - JeepForum.com
post #1 of 27 Old 02-01-2010, 09:36 AM Thread Starter
tallguy6464
I have an 07 Grand Cherokee CRD and the DTC code tells me that the #6 glow plug circuit is defective. Where is the location of this plug/cylinder on the engine? How can you tell if the glow plug or the glow plug controller is shot?
tallguy6464 is offline
post #2 of 27 Old 02-01-2010, 12:21 PM
kreso
2010 WK
Most probably it is not a circuit but glow plug by itself. Eider it draw to much current or no current at all. If I am correct cylinder #6 is the last one on the right cylinder bank looking from the grill(driver side near the fire wall).
kreso is offline
post #3 of 27 Old 02-01-2010, 09:18 PM
suzieque
2008 WK
you should also search this forum for "glow" or "glow plug" you will find a number of threads to read.
2008 WK "S" Limited bright metallic silver exterior, light graystone interior, 5 speed W5J400 transmission, June 18/2008 build, C213RE rear differential with 3.73 axle ratio, C200FE front differential with 3.73 axle ratio, 245/60R18 Goodyear Fortera tires (stock summer tires), NV245 transfer case, GT2056V turbo, 3.0L CRD (OM642.980)
suzieque is offline
post #4 of 27 Old 02-02-2010, 09:06 AM Thread Starter
tallguy6464
Since my Jeep is past the 60000 km bumper to bumper warranty I try to diagnose it myself. FYI if anyone wants a good source for glow plugs I suugest Europarts of San Diego where they run for $38.91. Thanks for the suggestions. Does anyone have a diagram that shows all the cylinder numbers on the engine in case I have another glow plug fail?
post #5 of 27 Old 02-02-2010, 08:25 PM
suzieque
2008 WK
I think its worthwhile doing some research into the topic of glow plug failure and see what we can find...
I came across a couple posts on different sites where owners replaced their batteries and the glow plug failure message went away. You may want to have your battery load tested prior to replacing a glow plug.
I also read about a glow plug reamer to clean the port where the glow plug goes
http://www.mercedessource.com/node/2842
And there was an article about a guy that cleaned his glow plugs regularly with ATF (automatic transmission fluid) because he ran bio diesel and glow plugs carboned up.
suzieque is offline
post #6 of 27 Old 02-02-2010, 11:17 PM
sbv20j
2007 WK
This may be of interest
sbv20j is offline
post #7 of 27 Old 02-03-2010, 01:27 PM Thread Starter
tallguy6464
Thanks for this diagram. Know any good sources for a service manual on this diesel engine?
post #8 of 27 Old 02-04-2010, 11:03 AM
merlinTec
merlinTec's Avatar
where did you get this? this is incorrect it's 1 to 3 down the right side of the picture 4 to 6 down the left side. Atleast it is on UK vehicles.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #9 of 27 Old 02-04-2010, 11:38 AM
suzieque
2008 WK
I didn't want to say anything, but the numbering is backwards from a North American V8 as well.
suzieque is offline
post #10 of 27 Old 02-05-2010, 03:59 AM
sbv20j
2007 WK
This was from a manual I downloaded from
SELL DOWNLOADS: Stock Photo Sales, Sell MP3s, Sell Software
Wow i wonder what else is wrong it looks like a genuine manual
I apologise if I have mislead anyone with this info
Regards,
Merlin
sbv20j is offline
post #11 of 27 Old 02-09-2010, 12:08 PM Thread Starter
tallguy6464
So Merlin this is the correct version?
post #12 of 27 Old 02-09-2010, 12:10 PM Thread Starter
tallguy6464
In case it doesn't go through.
post #13 of 27 Old 02-09-2010, 03:46 PM
merlinTec
merlinTec's Avatar
Hi
Well 6 is in the same place. I have back up CD's at work that look like about when opened up so I will see if they say the same.
post #14 of 27 Old 03-01-2010, 09:16 AM Thread Starter
tallguy6464
So to recap... the #6 glow plug by what I understand is on the North Americans driver side nearest the firewall? I have checked the threads here on this site and can't seem to find one on testing these glow plugs for the do-it-yourselfer. Would a continuity test on all of them work and the one that has zero or a different resistance than the rest be the defective one? Can they be tested while still in the engine? Thanks for any advice...
post #15 of 27 Old 03-01-2010, 03:53 PM
merlinTec
merlinTec's Avatar
Yes the resistance would be different and yes you can test in place centre poll of the glow to the head.
Glow Plug life roadman WK Grand Cherokee & XK Commander Forum 59 03-25-2016 12:17 AM
glow plug issue not solved roadman WK Grand Cherokee & XK Commander Forum 8 10-09-2008 04:58 PM
why canīt find glow/reverse glow gauges overlays for 2000 GC ? eschapiro ZJ Grand Cherokee Forum 0 02-14-2007 02:32 PM
Glow gauges Guumba ZJ Grand Cherokee Forum 15 01-24-2005 07:36 AM
Glow Guages snipr22 ZJ Grand Cherokee Forum 4 10-21-2004 03:38 PM
