CRD 2008 Swirl Valve $8,000 Repair Quote - Page 4 - JeepForum.com
post #46 of 93 Old 10-28-2013, 07:51 PM Thread Starter
revitup
The DPF was already replaced on warranty a couple of months ago, so from that angle it shouldn't be to bad to get those flange bolts off, and I have some BP Blaster to soak em with. I'll jack her up well and see what I can do. If it looks like it's something I can handle I'll do it, if not I'll just leave it for an other day.
Originally Posted by jaje View Post
Before starting - generously SPRAY the bolts now with some kind of penetrating oil to loosen up the nuts holding it on (it takes time and lots of vibration to get the oil to soak in). They will be rusted to a degree. WD-40 or PB Blaster might work but I use Aerokroil which is an industrial strength penetrating oil. Chirpz has a great DIY writeup on DPF removal as well.
revitup is offline
post #47 of 93 Old 10-28-2013, 10:01 PM
BAH101
2008 WK
If they are stuck, use a propane torch to heat them, not red hot, but hot, then hit them with penetrant and let cool. Nuts should come right off after that.
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #48 of 93 Old 10-28-2013, 10:28 PM
jaje
2007 WK
There's also the wax treatment - get them really hot then use an old wax candle and get the melted wax on the nut and it'll get sucked right into the threads (old trick a friend uses on really old cars he works on).
'14 WK2 EcoDiesel Limited
'13 Subaru BRZ
#74 Exocet - NASA ST3 / E0
jaje is offline
post #49 of 93 Old 10-30-2013, 04:31 PM Thread Starter
revitup
Just removed my DPF. JEEEEEZ talk about the job from hell.
I read all the lit and saoked the nuts/bolts with BP Blaster. To make a long story short every bolt/stud broke. Then I could not seperate the DPF from the sysyem. Had to get a saws all, jack the car up higher and cut all the bolts, the 3 studds closest to the engine. Finally got the sucker off. Then could not get the studs out of the DPF, so I had to heat the whole flange set up with my propoane garage heater..just a hudge blow touch, and then hammer the crap out of them to get them out.
Really, it was brutal, all the bolts had to be perswaded, took all my strenght, oil and Blaster dripping in your hair and eyes, sliding around on you back, couple of hanger bolts and flange bolts you can't even see. The two swage lock fiiting on the DPF were almost siezed, I could'ny believe who was the idiot who put them on so tight. JJEEEEEZ and then when I finished, party time....out of Beer!!!WTF.
Shooooo, If your not sure about your tools or talent don't start this project.
In any case just ordered my SS DPF insert pipe from "tnadanzig" he says it will be shipped by Friday. I should have my ECO Green tune any day now. Moving right along.
revitup is offline
post #50 of 93 Old 10-30-2013, 06:41 PM
fishinbama
2007 WK
Must be all the salt up there, mine weren't that bad, I did let them soak for a few days first. I still have no problems at all with just gutting mine. Cost me nothing.
2007 limited crd 2wd, 3.07 ratio, GDE eco tune, dpf delete, tnadanzig resonator delete
fishinbama is offline
post #51 of 93 Old 10-30-2013, 07:20 PM
zc911
Haha I could have told you that I got lazy and paid $95 for a shop to deal with it when I could not get my sawzal up to the top bolt on the flange with 3 bolts
zc911 is offline
post #52 of 93 Old 10-30-2013, 08:03 PM
BAH101
2008 WK
Mine was the same. Front bolts were so badly corroded there was nothing to get a wrench on. Just cut the bolts with the sawzall.
BAH101 is offline
post #53 of 93 Old 10-31-2013, 08:06 AM
GCDIESEL4ME
You said it was replaced a couple months ago? I would suspect not if it was this corroded up. This should have been easy to remove.
GCDIESEL4ME is offline
post #54 of 93 Old 10-31-2013, 12:23 PM Thread Starter
revitup
Yes Sir, I was thinking the same thing. But will have to verify. The wife cannot find our folder with all the dealer work/repair receipts in it.
On sorta a similar note, I drove the car home from the shop, about 5 miles max, (while it was at the shop all week I thought they may as well change the oil) and during this DPF removal project I checked the oil on the dip stick. It was black-as-black can be, with no clear oily swirls on the edges of the stick. Ya know I would not be at all surprised.....and up here it's $280 every 10,000 kls.
revitup is offline
post #55 of 93 Old 10-31-2013, 12:51 PM
tnadanzig
tnadanzig's Avatar
2007 WK
Your engine oil will be so much less polluted once your start running with the DPF removed. I was amazed at now much cleaner the oil was after I switched. Also the oil analysis I get with each oil change agrees with the lower amounts of contaminates. Also you will have a wider range and less expensive of oils to run once deleted.
CB Engineering
CB-engineer.com
2014 WK2 EcoDiesel - CBE Parts
2008 3.0L CRD WK LTD - GDE Tune 3.07 gears
2007 3.0L CRD WK LTD - Go Fast Parts
2005 KJ CRD - GDE Tune
tnadanzig is offline
post #56 of 93 Old 10-31-2013, 01:04 PM
Radcrd
2007 WK
I agree my oil is much clearer and I'm now changing it less often. Based on what others have reported in their oil analysis without a DPF you can easily go up from 10000km oil changes to 15000km interval oil changes.
2007 WK CRD QDII, GDE HOT tune. 275/55/18'' on Sahara's, SRT8 suspension.
2000 Jetta TDI (hers)
2006 Liberty CRD (sold)
3 VW TDI's (sold)
Radcrd is offline
post #57 of 93 Old 10-31-2013, 02:38 PM
Chirpz
Chirpz's Avatar
2007 WK
Well.... its not like a gasser. My XJ with the 4.0 inline six will keep clean oil for quite a while. The CRD is not so....it goes jet black very very fast. Now that I have the eco tune and dpf delete, it is cleaner than before but it does get dark pretty fast.
Are you saying that you drove it home 5 miles and then checked the oil and after 5 miles and it was jet black.....if that is what you meant, then that does sound fishy....although not impossible.
In my pre-ECO days, I remember my 1st oil change....the very next day it was jet black again....I don't know the number of miles I drove in that short period but it was not many.
Chirpz
2007 WK CRD, Quadradrive II, OEM Tow Hitch, GDE EcoTune, DPF-Delete, 4xGuard Front, Rear, Belly Guards, Side Rails & Full Matrix, OEM Skids, EHM, Dash Duck.
Chirpz is offline
post #58 of 93 Old 10-31-2013, 02:44 PM
Chirpz
Chirpz's Avatar
2007 WK
You also have to wonder, "did they change the oil correctly?"
Some workers suck the oil out with a suction tube...does that get it all?
And then, do they pour the first few quarts down the filter hole?
Do they drip any on the alternator, located right under the fill cap?
This can cause premature alternator failure.
Chirpz
Chirpz is offline
post #59 of 93 Old 10-31-2013, 05:01 PM
GCDIESEL4ME
My old GMC 6.5 TD would be instantly black if you did not blow all the old out of the oil cooler, it held a fair amount of black oil.
post #60 of 93 Old 10-31-2013, 07:10 PM Thread Starter
revitup
Yeh, I'm starting to get excited. So Tnadanzig do you think you will be ready to ship the DPF insert pipe tomorrow. I wanta see some bling and some clean(er) oil.
Now I'll start do my own oil changes, I'm thinking Mobile 1 ESP 5W30 with some sort of new way to catch the oil/spray/mess, will figure something out when I put on the DPF insert.
revitup is offline
