Cooling system questions. - JeepForum.com
 2Likes
  • 1 Post By caddydaddy
  • 1 Post By JKM
post #1 of 11 Old 05-17-2016, 01:01 PM Thread Starter
chobobulous
Hello, I am Scott. I have a 2006 Grand Cherokee Overland. Im living in southern New Mexico and it gets pretty warm here. I apologize in advance if I am posting in the wrong place. I am experiencing an odd issue with the coolant system and have a couple questions. First off, where should the temp gauge sit. Mine sits one notch to the left of the half way point. All other cars I have driven usually sit about a quarter of the way. Is that normal?
My second situation is as follows. Coolant will not go from the excess tank to the radiator. I found this out the expensive way. After getting the engine fixed it still will not drain into the radiator. The hose is not clogged. If I pull it off of the nipple that leads into the radiator it will flow.
Thanks in advance for any advice!
Sent from my SAMSUNG-SM-N900A using Tapatalk
chobobulous is offline
post #2 of 11 Old 05-18-2016, 11:08 AM
caddydaddy
2007 WK
Just below half way is what most read. It might go past half if you're going up a big hill in the Summer.
Have you checked the radiator cap? If the gasket is leaking, it wouldn't get a seal to create the vacuum to draw the coolant back to the radiator.
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
195,000+ miles!
caddydaddy is offline
post #3 of 11 Old 05-18-2016, 11:12 AM Thread Starter
chobobulous
Hey thank you for your reply! I figured I would change the radiator cap out just for good measure but the dealership told me they do not sell just the cap. This seems silly to me but maybe the guy did not know what he was talking about. If that is the case which ones work the best?
post #4 of 11 Old 05-18-2016, 11:32 AM
caddydaddy
2007 WK
They don't sell just the cap? haha! Any auto parts store should be able to sell you a Stant or Gates replacement cap. Just make sure it's an 18 PSI cap like the original. They are cheap, probably $5.
JakeWK likes this.
2" RC lift
195,000+ miles!
post #5 of 11 Old 05-18-2016, 11:36 AM
caulk04
2008 WK
Hah, won't sell just the cap? Whatever...
I replaced mine a couple years back. Found that when straining the system (long grades, heavy towing) it would push a little coolant out the gasket. New cap fixed it.
Agreed on the gauge location too. Stock thermostat is 203 and will read just a bit below halfway. Halfway on the gauge is about 215 as I recall.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #6 of 11 Old 05-18-2016, 12:34 PM Thread Starter
chobobulous
Thank you so much, you guys are very helpful. I picked up a new cap when I was picking up my battery. Fingers crossed that is what the problem is.
Hearing about the thermostat is comforting. Thank you very much everyone
post #7 of 11 Old 05-18-2016, 03:40 PM
JKM
2005 WK
first off, your dealership parts guy is a complete retard. part number for OEM rad cap is 4596198
If he was a real parts guy he would have also informed you that due to issues with leaks, the cap has been upgraded. New style has a black plastic top to the cap.
see image here of what new redesigned OEM cap looks like.
http://www.justforjeeps.com/radiatorcap.html
JakeWK likes this.
JKM is offline
post #8 of 11 Old 05-18-2016, 09:03 PM
caddydaddy
2007 WK
What year and/or engines are the upgraded caps for? The CRD isn't listed.
2" RC lift
195,000+ miles!
post #9 of 11 Old 05-19-2016, 04:33 AM
caulk04
2008 WK
The CRD is likely a different cap anyway since the overflow bottle is pressurized and the cap is there, rather than on the rad like all the other models.
That link shows what it's for:
Mopar factory replacement Radiator Cap for the following Jeep and engine combinations.
2003-2004 WJ Grand Cherokee with 4.7L
2005-2010 WK Grand Cherokee with 3.7L, 4.7L, 5.7L or 6.1L
2011 WK Grand Cherokee with 3.6L or 5.7L
2006-2010 XK Commander with 3.7L, 4.7L or 5.7L
2008-2011 JK Wrangler with 3.8L
2012-2013 JK Wrangler with 3.6L
2002-2007 KJ Liberty with 3.7L
2008-2012 KK Liberty with 3.7L
2008-2013 MK Compass & Patriot with 2.0L or 2.4L
Item # 4596198 (Replaces Item # 55116897AA)
caulk04 is offline
post #10 of 11 Old 05-19-2016, 06:25 AM
caddydaddy
2007 WK
Ah, I didn't realize the cap is on the radiator for the gas models. Seems like most cars built since the 2000's had them on the overflow tank though.
2" RC lift
195,000+ miles!
post #11 of 11 Old 05-19-2016, 07:42 AM
caulk04
2008 WK
Doesn't make much sense to me why the CRD would have it on the overflow tank since the cooling system is the same as the Hemi otherwise. I'm sure the dealer would really screw a CRD owner on a new radiator since it's 'special'.
In cars it makes more sense as the rad is usually buried and you wouldn't be able to get at the cap. That said...my 4.7 Dakota had a rad cap in the upper hose, not the rad. 21psi at that!
caulk04 is offline
