Control Panel Lights - JeepForum.com
post #1 of 9 Old 02-01-2014, 10:02 AM Thread Starter
bcorbett
2007 WK
I have a few lights out on my center console. The C/T light was the first to go out. The button still works but is completely dark. Now, the right half of the air placement knob (the one that changes where the air blows from) doesn't illuminate but if I tap on the dash around the knob they come back on.
I'd assume they are LED but are they replaceable?
bcorbett is offline
post #2 of 9 Old 02-01-2014, 10:13 AM
overland-wk
2006 WK
Check out lmctruck.com they have replacment bulbs with the blue covers i dont know exactly where in the web site they are but the newer chevy trucks have these bulbs also and they sell replacements on the web site.
06 ROR lifted wk (mine)
07 RC lifted xk (wife's)
Youtube channel
Bumsmodified98xj
overland-wk is offline
post #3 of 9 Old 02-01-2014, 06:53 PM Thread Starter
bcorbett
2007 WK
I was able to locate them here... http://lmctruck.com/icatalog/ce/full.aspx?Page=123
Do you know which ones I need? And I'm assuming that I would have to desolder the old and solder in the new?
bcorbett is offline
post #4 of 9 Old 02-02-2014, 11:10 AM
overland-wk
2006 WK
Those are exactly what you need and if i where you i would just replace all the bulbs in that circuit board. And yes your gonna have to resolder them.
Youtube channel
Bumsmodified98xj
post #5 of 9 Old 02-02-2014, 08:30 PM Thread Starter
bcorbett
2007 WK
Was able to find a pretty good video on the replacement process if anybody else is interested.
bcorbett is offline
post #6 of 9 Old 02-10-2014, 07:26 AM
No5pam
2006 WK
For $70, you can get the whole panel here: http://www.factorymoparparts.com/68000123aa.html
I have the same problem. I don't have a soldering iron. Even if I did, I still wouldn't be able to do it. I just can't solder.
I wonder if you might be able to somehow use those LED light strips like they sell at Pepboys? I think they're designed to stick on the outside of your car to make it LOOK like you have LED DRLs or something. But if you wired them into the internal wiring somewhere (like the aux wire -yea, they'd be on when the ignition was on, but it seems easier than trying to replace them).
I hope to try it one day. IDK, maybe you'll have better luck soldering.
No5pam is offline
post #7 of 9 Old 02-16-2014, 10:16 AM Thread Starter
bcorbett
2007 WK
Finally had my Jeep back from the body shop long enough to replace the bulb. While it takes patience, it was pretty easy.
Just a side note, the bulbs for the info center buttons are much smaller so I'm still on the search for their replacements.
bcorbett is offline
post #8 of 9 Old 10-20-2014, 08:40 AM
justinmiller930
2011 WK
Going to purchase a few of these bulbs to replace the burned out ones in my Jeep. I have the passenger controls too. They're not all out, but most of them on the left side of it are. I hope it's as easy as you showed to replace them.
justinmiller930 is offline
post #9 of 9 Old 10-21-2014, 09:47 AM Thread Starter
bcorbett
2007 WK
If you're good at soldering it's probably not too bad but the bulbs are tiny and not all that easy to work with. Good luck!
bcorbett is offline
