Config FOB on remote starter ? - JeepForum.com
post #1 of 1 Old 11-03-2011, 08:08 AM Thread Starter
ImaSTAT
Hello,
I bought a 05 Grand Cherokee about 8 months ago. I noticed that a MOPAR remote starter was installed into it, but the seller only gave me the 2 keys that had no start option on it. I suppose that the past owner had a seperate FOB only to start the car. So, what I did was buying the FOB that fits with the starter and tried to make the programmation as the owner's manual told me.
It works, but it seems to not work properly. As the manual says, I pressed the programmation button on the starter for 10 seconds. There was supposed to be 3 light flashes and 3 horn chrip. All I had was 3 light flashes, no horn. I then pressed the remote button to make the starter learn it. Again, the light were supposed to flash 1 time and the horn chirp 1 time. Only the lights flashed one time.
Now, I can start the car, but I have to press 3 times on the remote button. I thought maybe it was a protection so the car does not start if I accidentaly press on the remote button. To stop the car, I have to hold the button for 3 seconds.
That seems to work fine, even if I have to press 3 times on the button. Now, when I start the car and then put my key in and drive, everything goes OK but the thing is, when I stop and take off the keys, it says "Programming active" in the dash.
I found this topic: http://www.jeepforum.com/forum/f67/p...essage-699480/
relating the same issue, but actually my case started after I programmed the FOB.
My best supposition would be that when I pressed that program button for 10 seconds, it did UNPROGRAM the keys. Althought the keys buttons still work, maybe I have to put both of them in the car when it says programming active ? Not sure...
Well, any ideas would be appreciated Thank you very much
ImaSTAT is offline
remote , starter
remote starter for WJ? phish832 ZJ Grand Cherokee Forum 1 12-05-2006 08:18 PM
Remote Starter shashank ZJ Grand Cherokee Forum 23 09-03-2006 04:38 PM
Remote Car Starter RIJEEP26 ZJ Grand Cherokee Forum 21 12-27-2005 12:26 PM
Remote Car Starter rollin2447 ZJ Grand Cherokee Forum 12 09-07-2005 10:29 PM
Remote Starter, once again Jayrod586 ZJ Grand Cherokee Forum 6 12-22-2004 07:59 AM
