Commander Problem - Page 3 - JeepForum.com
post #31 of 46 Old 07-11-2006, 05:05 PM
odell
Junior Member
odell's Avatar
My newest problem is that the A/C fan or motor is excessively loud when turned up to 50% or more. Does anyone else experience this? Oops. I guess I should make a separate thread. I plan to take my Commander and get the windshield noise checked too.
Ours did the same thing, but through all the fan speeds. Took it in, they found some of the fan blades broke. Replaced the fan and no trouble now.
Black 03 sahara with some stuff.
odell is offline
post #32 of 46 Old 07-12-2006, 08:27 AM
Lizmara
2006 XK Commander
My Commander is getting fixed right now to reseal the windshield. I called the dealer to schedule an appointment and they knew exactly what was wrong and how to fix it. They said they just fixed another commander the day before. They said it was a 17-page repair problem so they'd have my car for a few days.
HemiCommander - I feel those same minor jolts when driving too. I'm not sure if it happens when the A/C is on or what. I noticed it most recenlty during our 12 hour drive to PA this past weekend. It's extremely minor and I didn't think anything of it. I actually thought it was me being paranoid but I'm glad I'm not the only one who has that problem. Has anyone else noticed this? I have the 4.7L 4X2 Limited.
Lizmara is offline
post #33 of 46 Old 07-12-2006, 11:26 PM
SYCOHEMI
SYCOHEMI's Avatar
Thanks for the fan and windshield info.
My Jeep is at the local dealer now, I dropped it off Wed morning, and they said they hope to have it done Thursday afternoon.
We'll see how it turns out.
'06 Commander Ltd, 5.7L Hemi, QDII, Midnight Blue, Gibson Exhaust, Raingler Net, K&N FIPK, Remote Start, Optima Yellow, Skid plates & Tow Hooks, Rocky Road 2.25 Lift, New Rear DT Shocks, 265/70R17 REVO's, 6061-T6 Custom Wheel Adapters, 4xGuard Rock Rails/Steps
'05 Land Rover LR3 SE
SYCOHEMI is offline
post #34 of 46 Old 07-15-2006, 04:30 AM
SYCOHEMI
SYCOHEMI's Avatar
Some piece had apparently fallen off inside the dash area and fallen into the fan. They removed that piece and the fan works fine again.
They could not identify the whistling sound, and it has been very sporadic, so no attempted fix. I'll bring it in again if it occurs.
SYCOHEMI is offline
post #35 of 46 Old 07-15-2006, 02:47 PM
solarpower
It seems as though they put weak *** fan blades in these. It's about 92 degress here (with 275% humidity) and wife calls to tell me her dash is vibrating ALOT when she uses the AC/heat.
After checking it out there is def. something either loose or not attached anymore in the blower motor cage area.
with a forecast of higher temps, and since my dealership is booked for another week solid I hope she does'nt destroy it totally. I poked around to maybe "patch it" lol alot of junk to get through it seems, and parts would be a quest.
04 TJ "U" package
06 XK Commaddy 4.7
solarpower is offline
post #36 of 46 Old 07-16-2006, 12:35 AM
cjenkins71
windshield whistle noise
Totally upset! Purchase a new Commander on 7/2 and the day we test drove we heard the windshield whistle. Were told it just needed to be driven, broken in. B S! Whistle noise occured off and on anytime between 50mph-85mph. Had it at dealership day and a half, windshield was resealed (so they say), but still have the problem today and picked it up from the dealership today. Called, and of course svc dept closed until Monday........does anyone know if it is better to get the windshield replaced or resealed again??????
cjenkins71 is offline
post #37 of 46 Old 07-16-2006, 02:35 AM Thread Starter
wpa4147
Chryslers Engineers have a fix for it. The dealership needs to contact them. There is a apoxy to seal the windshield.
wpa4147 is offline
post #38 of 46 Old 07-16-2006, 11:28 PM
SYCOHEMI
SYCOHEMI's Avatar
Does anyone know the TSB that applies to re-sealing the windshield?
My noise was only fleeting, but I know it will come back, and when it does, I want the proper ammunition to make sure they fix it this time.
Thanks in advance.
SYCOHEMI is offline
post #39 of 46 Old 07-17-2006, 12:46 AM
cjenkins71
Does anyone know how long it takes for the windshield to be "set"/ "dried" after it has been resealed? And from all the research we have done, it does not appear there is a TSB for the resealing of the windshield. The dealer knew all about it when I called and set the appt.....but unfortunately it does not seem to have fixed our problem.
post #40 of 46 Old 07-17-2006, 07:18 PM
05rr pilot
New here, what does TSB mean?
05rr pilot is offline
post #41 of 46 Old 07-17-2006, 07:37 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Technical Service Bulletin. Issued by the factory to aid the service departments in repairs.
Pacfanweb is offline
post #42 of 46 Old 07-17-2006, 07:58 PM
05rr pilot
Thanks for the info.
post #43 of 46 Old 07-19-2006, 12:00 PM
jlmolyn
whistle-Commander
The whistle is a sensor, not the a.c. or the windshield. If you drive before 8:00 a.m. CST or after dark, the whistle does not occur. It only occurs from 60+ mph and during warmer temperatures. Those of you who have had the windshield fix or the a.c fix will continue to experience the whistle (scream) unless yours is an air leak. An air leak is not the sound that I am experiencing.
jlmolyn is offline
post #44 of 46 Old 07-19-2006, 12:54 PM
hal2814
I can tell you it's not a sensor and I can even prove it to you if you have a sunroof. Wait until the whistle starts. When it does, open the sunroof and reach out and touch the channel at the top of the windshield with your finger (you may need to raise your seat up a bit to reach it). The whistle either changes pitches or stops. The reason it doesn't happen after dark is because it's cooler outside after dark. This also proves it's not an air leak. It's a whistling caused by the air passing over the top of the windshield. It does sound like some sort of sensor gone haywire. That's what my wife thought it was at first.
hal2814 is offline
post #45 of 46 Old 07-19-2006, 07:49 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Sorry, sensors don't whistle.
Electrical problem on 07 commander srtdodge05 WK Grand Cherokee & XK Commander Forum 6 01-18-2015 06:15 AM
HELP!!! 06 commander, 3.7 v6, trans problem joek926 WK Grand Cherokee & XK Commander Forum 2 01-06-2012 02:07 PM
2007 commander mds problem JB007Rules WK Grand Cherokee & XK Commander Forum 14 06-20-2008 01:20 PM
Commander Window Problem markdonnell1975 WK Grand Cherokee & XK Commander Forum 2 04-28-2008 01:26 PM
Commander - leak problem Kemp WK Grand Cherokee & XK Commander Forum 3 12-28-2006 01:52 PM
