Commander door seals - JeepForum.com
post #1 of 3 Old 08-20-2012, 07:49 PM Thread Starter
lightning95sc
Has anyone had problems with door seals leaking on their Commander, and if so, did Chrysler take care of it ?
I never saw any leakage in the wife's truck, but the carpet is soaked after a heavy rain. Chrysler says they're leaking at the bottom, both the door and body seals, but I don't see any damage to either one. They're not loose or pulled away, I checked. And, of course, Chrysler won't warranty them.
But there is a TSB to reseal the body at the roof/bodyside junction.
Just wondering if anybody else has had this problem......Its driving me crazy and I want to kill someone at the dealer.
Chuck
lightning95sc is offline
post #2 of 3 Old 08-20-2012, 11:31 PM
trax95008
2006 XK Commander
Do you have a sunroof? If so, are you sure that's NOT the source of water?
trax95008 is offline
post #3 of 3 Old 08-21-2012, 01:30 AM
Berk483
2013 WK
I had the same problem with my WK. I would see a little water on top of the driver side-body mounted weather stripping right on the corner near the dead pedal and I noticed one day when taking my mats out to vacum the bottom of the mat was wet. Since I have a sunroof that was my first thought, so I checked all the drains and they were flowing fine. I "added" a little drain hole in that area of the weather stripping and also put some double sided mounting tape between the door and the weather stripping on the door where there are gaps in the attachment points. One last thing I noticed was that it seemed to be worse if I parked and the nose of the Jeep was lower than the rear. Now I try to park nose up everywhere but I haven't had a leak since I made those little changes.
Berk483 is offline
$50 for DOOR SEALS! cory25 ZJ Grand Cherokee Forum 5 05-01-2010 08:50 PM
Another try at a Commander door ? Crazypilotgal WK Grand Cherokee & XK Commander Forum 0 01-07-2008 01:12 PM
Commander door adjustment? Crazypilotgal WK Grand Cherokee & XK Commander Forum 2 12-31-2007 09:05 PM
Door Seals (weatherstripping) 2k Limited ZJ Grand Cherokee Forum 3 10-13-2003 05:49 PM
Door seals Skillet ZJ Grand Cherokee Forum 0 05-07-2003 08:32 AM
