Commander 06 transmission problems - JeepForum.com
post #1 of 14 Old 03-18-2013, 06:50 AM Thread Starter
Dukenukemx
1997 XJ Cherokee
Friend of mine wanted my help in changing his transmission fluid, and now it has problems. It has delayed shift and slams into certain gears. Even reverse is effected.
We went to a newly opened Advanced Auto Parts to get the filters and gasket for the transmission. The brand we got was what they sold, "Driveworks". We also got 5 quarts of ATF+4.
Specifically we got.
http://shop.advanceautoparts.com/web...mission+filter
After we changed the filters and put the 5 quarts of ATF+4 we started it up and the Jeep wouldn't move. Not in reverse or drive. We went back and got 2 more quarts and added them and the transmission began to respond. My friend insisted and we added another 2 quarts after that. So far 9 quarts of trans fluid.
When it was able to move it was stuck in 3rd gear. I cleared some codes from the Jeep and the trans seemed to work fine. After a few days though, the trans slams into certain gears and has delayed shift sometimes. What the freak is going on? Is this the result of crummy filters?
Everything went in easy with 0 problems, other then AutoZone and Advance Auto Parts not knowing what a transmission filter kit was. I did insist to my friend to get the kit from NAPA, but they were further away.
97 Jeep Cherokee Sport - Custom cone air, exhaust header, KYB, custom Stereo, 2.5 inch Rear lifted
98 Jeep Grand Cherokee - Custom cone air, exhaust header, KYB
Dukenukemx is offline
post #2 of 14 Old 03-18-2013, 08:38 AM
90grandoneer
90grandoneer's Avatar
2006 WK
What engine and transmission?
06 GCO, Dk Khaki, QDII, Flshing Hi 3rd Bk Lt, MDS "ON" Lt, Airtab Vortex Gens, Debadged, Fumoto Drain Valve, BT Catch Can, Chopped EGR Tube, SRT8 CAI, TruFlow Filter, Sonnax Trans Line Press Booster, SC Tuner W/Adv Trans Tune App, Transgo Shift Kit, DS Tuner, Cust tubular hdrs w/3 in Magnaflow/Xlerator AP Exh Sys, Bilsteins, SRT Springs/Sways, Cust Eng Cvr, SRT8 frt/rear bumpers, FRI Sidewinder Cam w/6* advance/6.1 valvetrain, SLP 25% UD Pulley, BBK true 90mm T-Body, SOS Ign Coils w/.060 spark plug gaps, TEA ported/milled heads, SRT Reps with 265/45&295/40X20's.
90grandoneer is offline
post #3 of 14 Old 03-18-2013, 09:59 AM
colinzj
2006 WK
Did you make sure the old O-ring came out of the trans? Were the filters installed correctly? The O-ring goes flush into the trans, not onto the filter shaft.
2006 WK Laredo 4x4 4.7L
1993 ZJ Laredo 4x4 4.0L Dead, sold, and rolling again
colinzj is online now
post #4 of 14 Old 03-18-2013, 11:52 AM Thread Starter
Dukenukemx
1997 XJ Cherokee
It's the 4.7L with I'm guessing the W5A580 transmission. It's the same transmission that this guy has in the video.
You mean the oil seal for the filter? The flat looking one, and not the engine oil shaped filter? That was a pain to remove, like it is in any car, but I put the new seal on the trans before installing the filter.
I basically did everything
The only difference was that he didn't change the seal, but I did. Also, he primed his oil filter with oil, where as I didn't. I just screwed the filter onto the trans. Not sure if that was a mistake.
A few months ago my friends Jeep ran into a problem with it being stuck in limp mode. It wouldn't shift gears, and was stuck in 2nd. So it could be the transmission oil change may have aggravated an already existing problem.
Just got a phone call from him and he has a check engine light now. The engine's idle tends to bounce as well, but that maybe a bad idle air control motor. I'll see what the codes are. Mind you I have a cheap OBD2 bluetooth reader that I connect with my Android cell phone using Torque to get codes.
post #5 of 14 Old 03-20-2013, 10:52 PM Thread Starter
Dukenukemx
1997 XJ Cherokee
Guess the trans is just done? Take it to dealer?
post #6 of 14 Old 03-23-2013, 06:46 PM Thread Starter
Dukenukemx
1997 XJ Cherokee
Ok I pulled the codes and got the following.
P0700
P0841
P0734
P0868
Which I gather from a quick Google tells me it's either a bad valve body, or need to replace cooler return filter. Maybe transmission control module?
post #7 of 14 Old 03-24-2013, 03:57 PM
lauderdalechad
2006 WK
Sounds like the trans isn't getting the proper amount of fluid. 9qts is way too much...did you not measure it correctly? How tight did you put on the round "oil" filter? Should be no more then hand tight. Also could be a problem with the flat panel filter not seated correctly. I would pull the pan again and double check every thing! I highly doubt the trans took a dump from a filter change. Go back and redo it with the proper amount of fluid. Should only take 6.5-7qts to refill
2000 jeep wrangler sport: 31" BFG ATS, auto - wrecked
1997 jeep grand cherokee: stock - gf's zj
2000 Silverado 5.3l Z71- sold
2006 Overland HEMI QDII
lauderdalechad is offline
post #8 of 14 Old 03-24-2013, 04:15 PM Thread Starter
Dukenukemx
1997 XJ Cherokee
We first put 5 quarts and the Jeep wouldn't move forwards or back. Added two more and started to move, but jerking. At this point the dip stick showed right amount of fluid. My friend wanted to add two more quarts, and it clearly shows we added too much fluid.
I tightened it by hand, and then used an oil filter tool the further tighten it. It's tight, but not super tight.
That's what we figure, and we're going to try and get a Wix filter this time. That or NAPA brand, since I believe they also use Wix.
It's strange cause for about a week it was ok. He said it drove better then ever.
post #9 of 14 Old 03-24-2013, 05:03 PM
lauderdalechad
2006 WK
Good idea with a new filter. The the round filter should only be turned 3/4 of a turn after the filter seal makes contact (they strongly state "do not over tighten")
With the flat panel filter the biggest issue is going to be that seal (if its not in there flush and perfect it will cause problems) also don't forget to put the screw back into the filter.
From the factory the flat panel filter had a tendency to split open causing similar symptoms, that's why I'm leaning that way. Also if he drove around too much on an over filled trans he just might have ruined it. Make sure after you redo it all add 6qts and go drive around for about 30 min (not just around the block once or twice) then check fluid (in park while idling) and add 1/2-1qt if needed.
post #10 of 14 Old 03-25-2013, 07:38 PM
yzjwk
2005 WK
http://www.youtube.com/watch?v=81tt6-CC0VE
I basically did everything this guy did, since he has the same engine and trans as my friend does. The only difference was that he didn't change the seal, but I did. Also, he primed his oil filter with oil, where as I didn't. I just screwed the filter onto the trans. Not sure if that was a mistake.
No such thing as a 4.7l engine with a W5A580 trans . it's either a 3.7 with a w5a580 or 4.7 with a 545RFE . if it's a 4wd 4.7 with 545rfe then a service fill is 6.2l which means 5 wouldn't have been enough and 7 would have been too much . If you were at the full mark after 7 Qts then you were way too full at that point. too full because that full mark is at "full hot" condition and you couldn't even drive the vehicle let alone drive it far enough to get it hot .
5 and counting :05 WK 5.7 HEMI
90 YJ Islander 4.2L
94 ZJ Ltd 5.2 ,00 WJ 4.0
2010 MK Patriot
yzjwk is offline
post #11 of 14 Old 03-25-2013, 11:46 PM Thread Starter
Dukenukemx
1997 XJ Cherokee
So the trans fluid is way too much, and that's the problem then?
post #12 of 14 Old 03-26-2013, 04:24 PM
Triplecrown
2006 WK
There are times to do things yourself, times to visit your independent mechanic and there are times to go to the dealership service dept.
It can get very expensive doing guesswork or process of elimination. Whatever happens to be the issue, may not be as bad as you may think.
My advice:Take it to the dealership, have them run the Star Scan especially since you have a P0700 code!. Let them sort this out! Worst case scenario is you may have to pay them the diagnostic fee. You can always take it home or to another shop. Least you'll know what problem(s) is/are. The dealership will use the Star Scan which can read deeper codes than a normal OBDII reader or a scan tool from AutoZone or even a shop.
Good Luck,
-Tom
Triplecrown is offline
post #13 of 14 Old 04-02-2013, 11:42 PM
lauderdalechad
2006 WK
Any update??
post #14 of 14 Old 04-14-2013, 05:54 PM Thread Starter
Dukenukemx
1997 XJ Cherokee
Ok changed the filters and put new fresh oil, about 7 quarts. Firstly, the O ring for the filter popped out, and was on the filter. Second, when I removed the round oil filter, the center threaded hole didn't come with it. Replaced them both with Duralast stuff from Autozone. I insisted to my friend to get it from NAPA, but he did it on a Sunday and they're closed here on Sunday.
So far a week has passed and no problems. I made sure the new O ring was on good, and filled the round filter with oil before inserting it into the trans.
