post #1 of Old 05-17-2012, 12:45 PM Thread Starter
myct90
2005 WK
Coil-rite installation
Just picked up the Firestone coil-rite air bag kit and have a quick question that I could some some help with.
Question: Wondering the safest place to put the jack stands? Can I jack up the axle, support the rear on jack stands directly on the frame, and then lower the jack to allow the spring to decompress?
myct90 is offline
post #2 of Old 05-17-2012, 03:55 PM
tom19511
2006 WK
Jack stands
I would use the same place where the service shops use.. Usually 4 flat spots on the frame
Tom
tchristopher1@twc.com
2006 G.C.65th Anniv. Edition
2007 Liberty Sport 3.7
tom19511 is offline
post #3 of Old 05-18-2012, 06:14 AM
IndyBlueWK
2005 WK
I'd lift it up so that the coil springs as much as possible to make it easier to get the coil rites in and please post lots of photos...
IndyBlueWK is offline
post #4 of Old 08-12-2013, 10:47 AM Thread Starter
myct90
2005 WK
Follow up: After a year with the coil-rite's not a problem at all. I didn't take any photos but installation is pretty easy. You really have to jamb them into the coils but it's really a pretty quick job. I have a dual motorcycle rack that I throw on the back once in a while. They're very small bikes (old Honda CT's) but these air bags help quite a bit.
myct90 is offline
post #5 of Old 08-12-2013, 11:03 AM
IndyBlueWK
2005 WK
Photos Please!
post #6 of Old 05-18-2014, 09:15 AM
afhanson72
I just bought the kit for my 05 Grand. The airbags look too small. They are only about 5" tall. Are these the size you installed? Some of the photos I have found online look like the bags are alot longer.
Al
94 YJ - Plenty of mods
afhanson72 is offline
post #7 of Old 05-18-2014, 12:29 PM
caddydaddy
2007 WK
I installed a set in my '07 2 days ago. And yes, with the axle unloaded, they don't take up all of the space. Once you lower the Jeep to the ground, the bags will be holding some of the weight.
Here's a bag with air pressure, testing for leaks:
Here it is with the Jeep on the ground and about 8 PSI in it:
And here's the air valves next to the hitch. If you put them there, drill the holes a bit lower than I did. The air lines are hitting the hitch brace.
2007 CRD Limited w/QDII
GDE HOT Tune, Turbo Resonator Delete
2" RC lift
184,000+ miles!
caddydaddy is offline
post #8 of Old 05-18-2014, 12:39 PM
afhanson72
Awesome, thank for the pictures too!
Al
post #9 of Old 05-18-2014, 12:42 PM
caddydaddy
2007 WK
No problem! Does yours have a lift? I think someone said there's a different kit that does have longer bags.
2" RC lift
184,000+ miles!
post #10 of Old 05-18-2014, 12:49 PM
afhanson72
Yes but only 2" in the rear. I guess I better research that to see if I need a different kit. Thanks!
Al
post #11 of Old 06-21-2014, 09:26 AM
afhanson72
From what I found you only need longer bags if you have a lift with longer coils. I just have spacers in the rear. I got the kit installed last night. Everything seems to work perfectly. Now I need to go hook up my trailer!
Al
Coil rite kit? IndyBlueWK WK Grand Cherokee & XK Commander Forum 0 02-03-2012 01:28 PM
Firestone Coil Rite OttawaJeepClub WK Grand Cherokee & XK Commander Forum 0 12-16-2011 09:24 AM
Coil spacer installation question hike4it ZJ Grand Cherokee Forum 11 01-28-2009 10:56 PM
Done got the 242 TC swap!!And it is rite dapainter ZJ Grand Cherokee Forum 10 12-10-2005 02:31 PM
No-Slip and Lock Rite KillerZJ ZJ Grand Cherokee Forum 1 03-10-2003 06:51 PM
You may not post new threads
You may not post replies
