Codes U0141 and U1113 - JeepForum.com
post #1 of 7 Old 09-04-2014, 05:30 PM Thread Starter
BAH101
2008 WK
O, just had my front wheel bearings replaced today, took it back for the brake shield rubbing. I backed up and put the jeep in drive, looked down and all the dash lights were on and 'Transmission overtemp' was displayed. Shut her down and tried to start again...nothing, absolutely nothing, not even a click. Took the key out, opened the drivers door and the Key in ignition chime sounded. Opened the hook, checked the battery connection, jumped in and she started right away and normal. Got home and pulled U0141 and U1113. U1113 was displayed twice and U0141 was displayed about 6 times. Cleared all and went for a drive, nothing came back.
U0141 is 'loss of communication with final control module, and U1113 is AC related.
So, any clue of what might be happening?
2008 CRD QDII, OME HD, Pintlers wheels with 265/70/17 Goodyear Silent Armour's, Jeepinbyal UCA's. 4XGuard Front guard, Side Guard, belly guard, Matrix HC. GDE ECO Tune w/ delete.
BAH101 is offline
post #2 of 7 Old 09-05-2014, 05:46 PM Thread Starter
BAH101
2008 WK
Anybody?
BAH101 is offline
post #3 of 7 Old 09-05-2014, 05:51 PM
Chirpz
Chirpz's Avatar
2007 WK
Sounds like a bad connection somewhere... may be a harness plug got jostled loose in the repair job??
Chirpz
2007 WK 3.0L CRD, Quadradrive II, GDE EcoTune, DPF-Delete
4xGuard Front, Rear, Belly, & Side Rails, Factory Skids
EHM MOD, Garmin Mechanic EcoHD, K&N Filter (Deleted)
Chirpz is offline
post #4 of 7 Old 09-05-2014, 07:00 PM Thread Starter
BAH101
2008 WK
Worth a look. Strange, that all they worked on was the front end.
BAH101 is offline
post #5 of 7 Old 10-05-2014, 03:02 PM
TurboDiesel
2008 WK
just got 4 of the u0141 codes on mine
went offroading yesterday...
i went for a drive cause i thought my intercooler was whistling again but it seems good
go home and decided to check codes anyways and had those 4.. drove find tho
any idea? has yours come back at all?
2008 CRD // GDE Eco // DPF delete // 3" intercooler // OME HD // 265 dirtytracs etc.
TurboDiesel is offline
post #6 of 7 Old 10-05-2014, 03:37 PM Thread Starter
BAH101
2008 WK
Originally Posted by TurboDiesel
just got 4 of the u0141 codes on mine went offroading yesterday... i went for a drive cause i thought my intercooler was whistling again but it seems good go home and decided to check codes anyways and had those 4.. drove find tho any idea? has yours come back at all?
Haven't seen them since. I did find, (a couple of weeks later), that my battery terminal clamps were loose, not really loose, but with force you could move them. I removed the clamps and cleaned the terminals. With how this Jeep is voltage sensitive, you never know.
BAH101 is offline
post #7 of 7 Old 10-05-2014, 04:24 PM
TurboDiesel
2008 WK
yea i removed bother terminals, looked clean but wiped the dirt off then tightened them up
check fuses which all seemed good
and it drives fine other than the normal vibration stuff
ill keep an eye on it for sure
