Clunking after lift - JeepForum.com
post #1 of 9 Old 01-20-2013, 07:31 AM Thread Starter
Leeworthy
Clunking after lift
Just recently had my 2" rough country lift, spacers and larger tires installed. Noticing a clunking from the left front wheel area. Checked everything yesterday. Can't notice any loose bolts or anything like that. Clunks over bumps and when breaking over bumps. Any ideas? I'm thinking maybe end links or sway bar bushings,
Leeworthy is offline
post #2 of 9 Old 01-20-2013, 08:50 AM
BigCactus
2005 WK
mine is doing the same... could be worn upper ball joints. I'm going to be refreshing my suspension in a few months since my wk is already over 125k miles.
2005 WK 3.7L 4x4 Laredo | P255/70R17 falken WildPeak A/T | BDS 2" lift Kit | Deep Beryl Green
BigCactus is offline
post #3 of 9 Old 01-20-2013, 09:04 AM Thread Starter
Leeworthy
So has to be something else
post #4 of 9 Old 01-20-2013, 09:05 AM
biippy
2005 WK
Mine didnt have a lift but when we bought it, when ever we took turns or went over bumps you would hear a solid clunk... the dealership replaced the front sway-bar links and the noise is gone... just something you may want to check
biippy is offline
post #5 of 9 Old 01-20-2013, 10:53 AM
JKM
2005 WK
I'm having a similar issue on the left side on a non-lifted suspension. Recently changed out the strut to Bilstein, LCA and end-links and sway bar bushings. My mechanic says everything is tight. The only thing that hasn't been changed is the upper shock mount and the UCA. Would like to figure it out before throwing parts at it.
JKM is offline
post #6 of 9 Old 01-20-2013, 10:58 AM
theendresult
2008 WK
Maybe the shocks are fully extending?
theendresult is offline
post #7 of 9 Old 01-20-2013, 04:49 PM
oducks12
2005 WK
This thread will be your best friend. http://www.jeepforum.com/forum/f67/t...d-pop-1421373/
2005 WK Laredo - SOLD
2015 WK2 Limited
oducks12 is offline
post #8 of 9 Old 01-20-2013, 05:15 PM
R32R1
2006 WK
Same clunk for me too
R32R1 is offline
post #9 of 9 Old 01-20-2013, 06:05 PM Thread Starter
Leeworthy
Just bought the E20 Torx. Will give this a try when it comes in. Thanks for the info!
