Clock spring - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Clock spring
XJ guys, clock your transfer case!Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-20-2008, 10:11 AM   #1
rkoz1
2007 WK
Clock spring
What is a clock spring in the steering system used for and what happens when they go bad.
rkoz1 is offline   Reply With Quote
Unread 05-20-2008, 10:35 AM   #2
robpp
I dont know why we have it or what it does but read in another thread that it clicks when the wheel is turned.
Good Luck,
Rob
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline   Reply With Quote
Unread 05-20-2008, 10:46 AM   #3
Texas WJ
Texas WJ's Avatar
2005 WK
I'm no expert, but I believe it's called that because it looks like a clock spring when it winds and unwinds. Basically, it's how they make a positive electrical connection to the airbag and still be able to turn the wheel back and forth. Sometimes they run the cruise control and horn connections through it as well, so if those are dead too and your airbag light is on, you have a pretty good idea of what is wrong. I don't know if this applies to the WK though.
A general idea of what a clock spring assembly looks like behind your steering wheel:
Texas WJ is offline   Reply With Quote
Unread 05-20-2008, 08:17 PM   #4
nick500ss
2006 WK
A clock spring is basically an electrical connection that enables your horn, airbag and other steering wheel mounted electrical controls to function while the wheel turns. When it goes bad you have no functional airbag, horn and etc. They are'nt badly priced either, you can pick one up for 100 to 200 bucks if they go bad. They are'nt something you want to try to replace yourself either without eperience and knowledge of airbag systems and auto electrical, a mistake can be deadly!
nick500ss is offline   Reply With Quote
Unread 05-23-2008, 03:47 AM   #5
tednelson83
Originally Posted by Texas WJ View Post
yup, the above two posts hit the nail on the head, and the pic provided is a pretty good illustration of what it is. it is basically just like a spool of wire that is wound to look like a spring and keeps that electrical connection to the wheel. they should not make any noise. if you are hearing a clicking noise it is more likely coming from the cancel cam for the turn signals.
they are replaceable by the shade tree mechanic, but do not attempt it with out the guidance of a factory shop manual. and please if you try it, remember to physically REMOVE the battery from the car, and to not touch the air bag wiring for at LEAST 10 minutes to prevent accidental deployment of the airbag. once removed, just be careful with the bag, and use common sense while handling it, keeping in mind that it is a mild explosive device. these same guidelines also apply to servicing the reel side of the front seat belts as well.
Wyotech Sacramento Alumni. ASE A6, A8, and L1 Certified. CA Smog License.
1993 Jeep Grand Cherokee Limited 5.2 4x4, IRO 3.5" lift, Spidertrax adapters, 32" BFG M/T's on 17" cragar soft 8's, Flowmaster muffler.
1987 Pontiac Fiero GT 2.8
Liberalism stems from the notion that it's entirely possible to pick up a turd by the clean end.
tednelson83 is offline   Reply With Quote
