cleaned throttle body abundance of codes - JeepForum.com
post #1 of 7 Old 08-24-2014, 12:16 PM Thread Starter
davidtownsend
2006 WK
I cleaned the throttle body with carb and choke cleaner. And now it has multiple codes. Starting with p0113 p0123 p0222 and p2111. I kinda know what they are. How can I clear them on my own without a scanner? In my old jeep I unhooked the battery and presses the brake plus held the key on for thirty seconds. Does any of this apply? Thanks for all the help!
1994 Jeep Grand Cherokee 5.2L Limited
2006 Jeep Grand Cherokee Overland 5.7L Hemi
davidtownsend is offline
post #2 of 7 Old 08-24-2014, 01:59 PM
Dylon531
2005 WK
disconnecting the battery for a little bit might clear them. if not you can always go to autozone and they can clear the codes for free
Airborne Infantry
2005 WK 4.7
OME HD, 265/70 Duratracs, Rola roof rack, superchip flashpaq 3872
Dylon531 is offline
post #3 of 7 Old 08-24-2014, 03:25 PM Thread Starter
davidtownsend
2006 WK
Thanks dude.
post #4 of 7 Old 08-24-2014, 04:58 PM
caulk04
2008 WK
How did you clean it? With it still installed? Engine running?
Just take the TB off to clean it so you aren't pushing all that filth into the engine.
At any rate, unhooking the battery (no need for any special trickery, just unhook for a moment and reconnect) will clear the codes. If they come back, you've got issues to fix.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #5 of 7 Old 08-24-2014, 05:23 PM Thread Starter
davidtownsend
2006 WK
I unhooked the connector and unbolted it off of the intake. I then sprayed and wiped and sprayed some more. How long should I leave the battery unhooked?
post #6 of 7 Old 08-24-2014, 09:12 PM
caulk04
2008 WK
If I ever have to clear codes that way (I have a scanner to do it) I just pulled the PCM connections out and then put them right back in. Same should work for the battery. Count to 5 and put it back on.
caulk04 is offline
post #7 of 7 Old 08-24-2014, 11:06 PM Thread Starter
davidtownsend
2006 WK
Thanks for the help. When I got off work tonight it didn't have a cel anymore. Maybe it needed to set out or sit for a little.
