Chrome trim removal? - JeepForum.com
post #1 of 10 Old 06-08-2014, 07:24 PM Thread Starter
sheepdog918
2007 WK
Any idea on how removal is for chrome mirror caps and door handles are? I really don't think the door handles will be that big of deal, but how is the chrome mirror caps attached?
sheepdog918 is offline
post #2 of 10 Old 06-09-2014, 05:04 AM
caulk04
2008 WK
I don't think these ever came stock with chrome mirror or door handle caps, so they're likely just taped on aftermarket JCWhitney crap.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #3 of 10 Old 06-09-2014, 11:56 AM Thread Starter
sheepdog918
2007 WK
Well the door handles I'm almost positive are just stuck on there no problem with them, but the mirror caps seem solid on there, can't get them to even bend up so I can look underneath them I didn't know if they came screwed on or what the deal is
post #4 of 10 Old 06-09-2014, 08:06 PM
CavallinoRed
2006 WK
I'm guessing you have something like this held on with 3M tape https://www.youtube.com/watch?v=BWBlxKgY-98
Might try heating the cover up with a hot air gun to see if you can get the adhesive to release. I would be concerned over damage to the paint underneath so....Good luck!
CavallinoRed is offline
post #5 of 10 Old 06-10-2014, 09:23 AM
robpp
some early overland ones came with chrome caps/
not many though.
the mirrors are most likely NOT painted underneath the chrome but just black plastic...still could get damaged just not as easily as paint.
get some wd-40 or googone sprayed under there for a few days and then a blow dryer heat....not heat gun. and PULL or use a trim stick to pull on it little at a time.
but as said be prepared for damage underneath.,
alternative would be to scuff the chrome and paint it or plastidip/
Rob 007 Laredo 4.7 FFV 27X; DeBadg'd; Zaino'd; SRT8 Grill, Pedals, Strut; ClearBra; WeatherTech; LED Reverse; HIR Hi/Lo; SS Fog; Stealth Turns; 15% Tint; Stubbie; Rear Spoiler; Magnaflow; V1; 22Elite Console/Visors; Body Kit; Color Match Everything; TintedTails; K&N 63; Front Skid; QuickOilDrainValve; BatteryTender; SuperChips 91; Bilstein; Billet Window Switches; Greasable Addco Sways; RamMedic Hood; Fastman TB; BWoody Links; Kicker Upgrade w/Single Sub; AVIC F90BT Hacked; NeffyWrap ABCD; Putco LEDs; Viper 20s w/255/50; R1 Slot/Dimple w/Hawk Pro Ceramic; Whistler Mod w/FlashTech Halos
robpp is offline
post #6 of 10 Old 06-10-2014, 10:09 PM Thread Starter
sheepdog918
2007 WK
I'll probably just try to ease it off and say if it happened to be painted and damaged Ill just scuff it up and paint it then, I'm really not a fan of chrome just makes it look really tacky IMO
post #7 of 10 Old 06-11-2014, 06:01 PM Thread Starter
sheepdog918
2007 WK
Update on the trim-was able to remove the trim on the door handles without problem, just a little patience and citric cleaner, no damage was gonna attempt to remove the mirror caps but got rained out so looks like a project for tomorrow!
post #8 of 10 Old 06-11-2014, 07:43 PM Thread Starter
sheepdog918
2007 WK
Well I just removed the mirror covers, those surprisingly were easier, no damage and looks great! Thanks for all advice guys you helped me out a lot!!!
post #9 of 10 Old 08-23-2014, 11:22 PM
Xmind
2007 WK
It wasn't until this thread a few months ago that I realized the "chrome" trim on my door handles was aftermarket. I always thought it was weird that the only shiny trim that Jeep would put on the vehicle is the door handles. Anyway, finally got some time to remove it. Just a couple tips for anyone else attempting this:
Tools:
Heat gun/hair dryer
Tar/GooGone/whatever auto safe sticky remover
plastic trim remover/scrapper (I used this: http://www.harborfreight.com/5-piece...set-67021.html)
Paper towels/rags
At least for the door handle pieces, all the adhesive is on one strip on the front of the cover. So just put a pry bar on the edge of the trim piece and start applying heat with gentle pressure on the plastic pry tool (see attached picture). As the trim gets enough heat it will start to deform and you can press the tool along as you move the heat gun down.
Once off, scrap/rub whatever you can without putting too much effort into it. Then douse the foam adhesive with your Bug and Tar remover (that's what I used as it was safe for auto paint). Let it sit for a few minutes and scrap off what comes off easily. I had to rinse and repeat about 3 times to get it all off each side, but while one was soaking, I was pulling off another. A little elbow grease, but not too bad with the tar remover....made it much less painful than without it.
'07 GC CRD QDII, EHM, GDE ECO, DPF & intake rez delete, Paramount Perf Valve Body, Roof drain mod
Xmind is offline
post #10 of 10 Old 08-24-2014, 01:46 AM Thread Starter
sheepdog918
2007 WK
When I took mine off a really good strong citric cleaner helped me out, soak the adhesive tape that they were stuck to and it peeled right off, then I just took a little elbow grese to remove the residue, then a trip to car wash and some really good pressure washing on it got it to come the rest of the way off and I highly recommend the scraper as I was to impatient and used a flat head screwdriver, it worked but it nicked a couple of places, but patience is the main thing don't rush it
