Checking fuel pressure??? - JeepForum.com
post #1 of 5 Old 10-23-2013, 04:08 PM Thread Starter
goflick
2005 WK
I believe that I may be having some fuel pump issues and want to check my fuel pressure. I'm trying to figure out where the schrader value for the fuel line is on a 05 GC WK 4.7L V8?
goflick is offline
post #2 of 5 Old 10-23-2013, 05:01 PM
WieSeL
There isn't one. You have to test in series with the line to the rail. Why do you think you have a pump issue?
WieSeL is offline
post #3 of 5 Old 10-23-2013, 10:48 PM Thread Starter
goflick
2005 WK
For the last 3-4 months my 2005 GC WK 4.7L(132K miles) has had some issued at start up. At first I thought it was the transmission slipping, I did a tranny filter and fluid change at 100K). The vehicle starts with no issues but when I put it in drive or reverse there is a delay before the vehicle will actually move. After the initial hesitation there are no issues until the last week. It seems that when I park in my driveway, which has a slight incline, I have the initial hesitation but then when I get to the stop sign at the end of my block the vehicle stalls. Start it back up and drive with no issues. When I park in the street I have yet to have the vehicle stall after initial start up. I've never had a fuel pump issue with any of my other vehicles and don't have any experience with fp issues. Anyone with any fp experience that could confirm my concerns???
goflick is offline
post #4 of 5 Old 10-24-2013, 06:41 AM
caulk04
2008 WK
Doesn't sound like any fuel pump issue I've ever heard of.
Sounds like a fairly normal priming issue with the 545RFE for the delay. The stalling issue could be a dirty TB and/or failing TPS or IAC valve or it could be a transmission issue. The subtle nuances of how it's stalling could tell whether to think trans or engine, but that's about impossible to troubleshoot with a keyboard.
08 Limited Hemi - wheels, tires, springs...ya know, stuff
caulk04 is offline
post #5 of 5 Old 10-24-2013, 06:54 AM
WieSeL
Originally Posted by caulk04 View Post
doesn't sound like any fuel pump issue i've ever heard of.
Sounds like a fairly normal priming issue with the 545rfe for the delay. The stalling issue could be a dirty tb and/or failing tps or iac valve or it could be a transmission issue. The subtle nuances of how it's stalling could tell whether to think trans or engine, but that's about impossible to troubleshoot with a keyboard.
x2
WieSeL is offline
