Quantcast Check engine light up solidly after oil change - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > Check engine light up solidly after oil change
Old 11-16-2009, 02:42 PM   #1
vz900
2008 WK
I changed oil on my 2008 grand cherokee 3.7 Laredo last Friday. I drove for 20 km without any problem afterwards.
The next day, as soon as I turned on the car, the check engine light was on.
I checked around and did not find any thing wrong. Now, the light kept on all the time whenever I drive.
I am totally confused because I used Mopar oil and filter, follow the same procedures as usual. Anybody here experienced this problem ?
By the way, my car has 55000 km on it and this is my second time changing oil since I bought it.
Thanks in advance
vz900 is offline   Reply With Quote
Old 11-16-2009, 02:44 PM   #2
thewalrus
2005 WK
What is the DTM code?
-Thanks
ASE Master Tech
thewalrus is offline   Reply With Quote
Old 11-16-2009, 03:06 PM   #3
vz900
2008 WK
I haven't got chance to read the code yet.
The guy from Jeep dealer told me to drive for couple days to see if the light could go off by itself then decide to read the code or not, they charge more than $100 to read the code which I think is quite expensive.
Old 11-16-2009, 03:57 PM   #4
wookiee
Bought, not built.
wookiee's Avatar
2007 WK
Are you sure that you didn't knock or loosen any connector off while doing the change?
On the diesel, there's a oil temp sensor close to the drain plug.
07 Steel Blue Overland CRD QDII | Bilsteins | 4xguard Matrix | Rear SRT8 SwayBar | DashHawk w/egt | GReddy Full Auto II Turbo Timer | Provent | MBRP XP Exhaust | New Intake Tube & Seal | Alternator Splash Guard | Crank Sensor | GPS AJ InMotion Hack | Fuelly.com - wookiee
Blue WK Club Member #13 | 100,000 Mile Club | Dogpiled Club
wookiee is offline   Reply With Quote
Old 11-16-2009, 04:02 PM   #5
vz900
2008 WK
Not 100% but quite sure that I didn't do anything wrong
Old 11-16-2009, 04:08 PM   #6
Texas WJ
Texas WJ's Avatar
2005 WK
Pull the code.
Flip to ignition from off to on (without starting the engine) three times and you should get the error code displayed on the dash. It can take several attempts to get it right.
Autoparts stores around here will also hook up a scanner for free, so you could also try that.
265/70-17 Mickey Thompson Baja ATZs, 2" lift, JK Wrangler Moab wheels, Rola Roof Rack.
Texas WJ is offline   Reply With Quote
Old 11-16-2009, 06:22 PM   #7
vz900
2008 WK
Does that flip key method only apply on old models only?
I tried yesterday without anything came out. I will try again. Thanks.
Old 11-16-2009, 07:04 PM   #8
Texas WJ
Texas WJ's Avatar
2005 WK
It should work for you. The driver's door needs to be closed, otherwise the readout will only display the open door warning I think.
It really can take a bit sometimes. Be quick, but not too fast.
Old 11-16-2009, 11:06 PM   #9
vz900
2008 WK
I would say, it works.
This afternoon, I tried again, yes, with the door closed
Instead of coming up a code as Texas WJ mentioned, the light went off.
So, everything is back to normal now.
Thanks for all your help
Old 11-16-2009, 11:49 PM   #10
Texas WJ
Texas WJ's Avatar
2005 WK
Cool.
Old 11-20-2009, 11:32 AM   #11
garsarno
My daughter's '07 Hemi check engine came on after a few days of driving it with a stumble in the performance. She went to Autozone, they scanned it and it came up oil level low, oil pressure problem. She checked the oil fluid level and it was down 1 quart after the dealer changed the oil 1,500 miles ago / 2 weeks ago. She added the quart of oil and it is running better / check engine light gone. I told her (she is in Cleveland) to watch it and if it acts up again, it needs to go the Jeeo dealer ASAP. Local gas station in PA said it might be the oil pressure switch.
garsarno is offline   Reply With Quote
Old 11-20-2009, 02:08 PM   #12
Texas WJ
Texas WJ's Avatar
2005 WK
It's possible, just had mine go out. It threw a permanently on "check engine" light and a "oil pressure light" at the same time. It was a cheap fix.
Old 11-22-2009, 07:43 PM   #13
dieth
2008 WK
You mean Chrysler still hasn't found a reliable vendor for oil pressure senders and switches??? They changed my oil pressure sender under warrenty 4 times on my 96 ZJ.
dieth is offline   Reply With Quote
Old 11-23-2009, 06:10 AM   #14
garsarno
The light is out on my daughters Hemi now and it is running the way it should. However, with 67,000 miles on it, she has soured on the experience (and also the 12 - 15 mpg) and is in negotiation to trade it in on a 2010 Ford Fusion SEL.
Old 11-23-2009, 08:07 AM   #15
ratmonkey
Living dead mod
ratmonkey's Avatar
the dipsticks don't read correctly on the hemis if i remember right. they always read low when the fill is correct.
ratmonkey is online now   Reply With Quote
Glock Forum
