check engine and glow plug light on? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Grand Cherokee & Commander Forums > WK Grand Cherokee & XK Commander Forum > check engine and glow plug light on?
HMF Fabrication 50" Light Bar Mounts for CJ/YJ Made IIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRuffstuff XJ Unirail Channel Reinforcement....
Unread 06-13-2012, 08:12 PM   #1
Sandib210
hi all,
hoping someone has run into this before and can give me a hand. Today I noticed when I turned over my 07 diesel Grand Cherokee the check engine light came on (and stays on) and the glow plug light comes on for about 3 seconds or so.
Any clue as to what would trigger this??
Sandib210 is offline   Reply With Quote
Unread 06-13-2012, 08:56 PM   #2
Sandib210
I'll add that when I retrieve the code by turning the ignition on and of 3 times quickly I get "service 4wd system"
Unread 06-14-2012, 08:01 AM   #3
NDSU_Bison
2008 WK
You probably need to have one of the glow plugs replaced. I had the same thing happen to me although they had to replace the glow plug control module when replacing the plug listed in the fault code didn't help. It's probably not a big deal in the summer like it would be on a nice cold Saskatchewan winter day.
NDSU_Bison is offline   Reply With Quote
Unread 06-14-2012, 06:04 PM   #4
TurboDiesel
2008 WK
i hope ur not litterally turning the truck on then off....
-]All Blacked Out[-
2008 Jeep Grand Cherokee 3.0 CRD
2" RC lift
255/75R17 BFG KM1's
17" ion alloy rims
15" kicker solo baric L7 w/ Alpine m1000 amp
aftermarket headlights w/5000k HIDs
Red interior LEDs and Red license plate LED
Tinted tails
5% tint over the rear windows
more to come....
TurboDiesel is offline   Reply With Quote
Unread 06-14-2012, 07:05 PM   #5
quicksilverado
2007 WK
You turn just the ignition switch on and off 3 times. You don't actually start the engine. You can do this with most vehicles and then count the sequence of flashing lights to get the trouble code.
07 Grand Cherokee Limited CRD 4X4 GDE tune
00 Silverado 10 sec work truck
quicksilverado is offline   Reply With Quote
Unread 06-14-2012, 08:24 PM   #6
Sandib210
yes, that's what I meant. . . some call it the key dance?? When I do that I get 'service 4wd system', but no other codes.
I changed the battery today, and now the glow plug light no longer comes back on. Just the check engine light comes on.
Unread 06-14-2012, 10:30 PM   #7
TurboDiesel
2008 WK
yea i know how to do it...just wasnt sure if the OP did lol glad we got that cleared up atleast
-]All Blacked Out[-
2" RC lift
255/75R17 BFG KM1's
17" ion alloy rims
Tinted tails
more to come....
Unread 06-29-2012, 11:21 AM   #8
Sandib210
I could still use a hand with this problem. I've installed a new battery, I'm getting the battery light on at start up until I rev it up a bit, and I still have the check engine light on. Could this be a belt? bad alternator? any ideas??? sometimes the glow plug light also comes on for a second or two immediately after start up.
Unread 06-29-2012, 12:14 PM   #9
jiggadog
2008 WK
have you pulled the codes? as mentioned, you likely need to replace a glow plug. you may have an alternator issue if the battery light is coming on.
2008 WK CRD Limited 4x4. Every available option package
jiggadog is offline   Reply With Quote
Unread 07-01-2012, 12:56 PM   #10
Sandib210
Maybe I should buy a code reader? Key dance gives me DTC report - ---- most of the time and occasionally "service 4wd system"
Unread 11-20-2012, 11:55 PM   #11
va7cid
2008 WK
if you are still trying to fix this, it's likely a bad glow plug. I would suggest to get an OBD reader that will give you the correct code. It will come in handy with an newer vehicle especially with us CRD owners.
Same thing happen to mine that started with a bad #5 glow plug, for me it's the on in the middle at the left engine side or the driver side. Replaced it with a Bosch Glow Plug for $35 at VAP (dealer wants $80 each) and 3-4 weeks later the engine light came on again with a glow plug module code. I had no choice but to replace it as it was a dealer item at $350 and erased the code and it has been fine since.
Love the torque with this engine but we must deal with the minor hick up as they age, good luck with it
va7cid is offline   Reply With Quote
