changing trans fluid on W5A580 - JeepForum.com
post #1 of 61 Old 05-27-2008, 12:10 PM Thread Starter
stgry1
2006 WK
I guess my ?? is this. No dipstick on these trannies. Tech reference says 4-6qt capacity needed on service. Has anyone serviced these themselves and if so, what did you do on fluid amounts? I can drop the pan and "guess" on the amount...but I don't really like that choice. I may just put in 4 qts and go to the dealer and have them 'stick' it to see if I'm low. I'm sure I won't be over. Thoughts??
db
Brandon, FL
USMC
06 Silver Laredo
mopar bug shield, rear mopar air deflector, K&N drop in w/ modified OEM air intake, 08 Gladiator wheels w/ 255/60/18s.
stgry1 is offline
post #2 of 61 Old 05-27-2008, 12:48 PM
jeepgaffer
2006 WK
Yeah...I hate this 'closed system.' Allegedly, the dealer only can check the fluid level (due to it needing to be checked at a strict temperature, or something). Thanks, Jeep!
2006 Bright Silver Grand Cherokee Laredo
3.7L 4WD ("mostly" stock)
jeepgaffer is offline
post #3 of 61 Old 05-27-2008, 12:58 PM
merlinTec
merlinTec's Avatar
Hi
I believe dash hawk or some other after market monitor with tell you trans temp (needs to be in drive or reverse or it shows engine temp( well star scan does)) then all you need it a plastic stick with 10mm notches and away you go. I will post the temp/oil level chart should you want it.
Regards,
Merlin
UK Chrysler Jeep Master Tec.
merlinTec is offline
post #4 of 61 Old 05-27-2008, 01:09 PM
jeepgaffer
2006 WK
So, take a plastic stick that will fit in the tube, and make marks/notches on it every 10mm, starting from the bottom? Could a dipstick from the other WK tranny work?
Post that info, please!
Thanks!
post #5 of 61 Old 05-27-2008, 02:48 PM Thread Starter
stgry1
2006 WK
Welp, I was JUST at the dealer 2 weeks ago and they replaced the infamous leaking "sensor o-ring" and topped off the system. My thoughts now are that the level is correct so If I can get my hands on a stick that will make it down to the bottom of the pan, I'm in business. Then I can post where it should be on the stick and which to use etc. Let me know if you agree Merlin. Thanks!
db
Brandon, FL
USMC
06 Silver Laredo
stgry1 is offline
post #6 of 61 Old 05-27-2008, 03:31 PM
sabre364
2007 WK
Did you ask them to check the ring or did they just notice a little leak? From what I've been reading on here, the leak is almost barely noticeable, certainly not enough to drip onto the blacktop below the vehicle.
sabre364 is offline
post #7 of 61 Old 05-27-2008, 03:54 PM
merlinTec
merlinTec's Avatar
Hi
You will need something to read the trans temp.
post #8 of 61 Old 05-27-2008, 04:03 PM
Merlin is correct. The DashHawk will read trans. temp. (although 2.5 BETA FOUR fails to do so) on almost every version. The temperature is only displayed when engaged in a drive gear.
---- is offline
post #9 of 61 Old 05-27-2008, 04:04 PM
johnniebravo
2008 WK
check out this link, it even has a link for the dipstick and i think it is around 70 dollars. Someone even used the dodge ram 5.9L dipstick with some success.
http://www.300cforums.com/forums/per...-dipstick.html
dipstick
http://www.wyckoffchryslerparts.com/troillechto.html
temp chart for those with a 5.7L
http://www.300cforums.com/forums/att...k-untitled.jpg
2008 CRD GC
johnniebravo is offline
post #10 of 61 Old 05-27-2008, 05:36 PM
CEPCNC
2005 WK
My dealership actually called me up a few months after I bought it from them and told me I needed to bring it in so they could perform the fix for the 0-ring TSB. I was impressed then, but now their service sucks if I get in contact with anyone else but this guy named Jon at the service counter.
Tomorrow morning I'm going in at 7am to have them look at a re-occuring problem with my gauge cluster/control panel. It's been faultless since February.
CEPCNC is offline
post #11 of 61 Old 05-27-2008, 06:34 PM Thread Starter
stgry1
2006 WK
No, I had brought it in for leak. I noticed the pan "sweating". I also complained about the slow gear engagement but couldn't get them to do the bulletin for the oil cooler return. I was hoping they would, then I would have just paid extra for the filter and service would be done!
Regardless, you guys keep mentioning trans temp? What I don't get is if it's at NOT in park, why couldn't you get an accurate readin on the stick?? I realize when cold it will read diff, but when warm? What am I missing?
db
Brandon, FL
USMC
06 Silver Laredo
stgry1 is offline
post #12 of 61 Old 05-28-2008, 04:36 AM
TJJP77
TJJP77's Avatar
If you are referring to the oil cooler return filter TSB, then there's a good reason why they didn't do it - it only applies to the 545RFE trans. I gather from you initial post you have a 3.7L A580 combo....
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline
post #13 of 61 Old 05-28-2008, 04:52 AM
tednelson83
thats interesting, i just got gas today, and i checked all my fluids, including the tranny. i have the w5a580 tranny too, and mine has a dipstick. did they change it after 05? or was this one of the changes to rental cars?
Sacramento Alumni. ASE A6, A8, and L1 Certified. CA Smog License.
1993 Jeep Grand Cherokee Limited 5.2 4x4, IRO 3.5" lift, Spidertrax adapters, 32" BFG M/T's on 17" cragar soft 8's, Flowmaster muffler.
1987 Pontiac Fiero GT 2.8
Liberalism stems from the notion that it's entirely possible to pick up a turd by the clean end.
tednelson83 is offline
post #14 of 61 Old 05-28-2008, 06:19 AM
merlinTec
merlinTec's Avatar
Hi
No you shouldn't have a dip stick.
Regards,
Merlin
post #15 of 61 Old 05-28-2008, 07:26 AM Thread Starter
stgry1
2006 WK
Chris, your right. I guess I overlooked that one. Dang.
db
Brandon, FL
USMC
06 Silver Laredo
stgry1 is offline
Changing Trans Fluid Questions jeep360limited ZJ Grand Cherokee Forum 19 12-05-2009 11:11 AM
Changing trans fluid tapuout2 ZJ Grand Cherokee Forum 3 04-28-2009 02:57 AM
Trans Fluid/Filter Change, bad for trans? ddeadserious ZJ Grand Cherokee Forum 8 01-18-2009 08:23 PM
W5J400/W5A580 swap ---- WK Grand Cherokee & XK Commander Forum 1 07-31-2008 05:28 PM
changing tranny fluid 2tone93zj ZJ Grand Cherokee Forum 3 12-31-2006 03:22 AM
