Changing rear shocks... - JeepForum.com
post #1 of 3 Old 06-11-2008, 06:20 PM Thread Starter
itasor
itasor's Avatar
2009 JK Wrangler
I will be helping a friend change the rear shocks on his 2005 Grand Cherokee.
Are there any special tips or tricks we should know before attempting this? Also, where can I find the torque specs that we need to know? I'm assuming we just need the specs for the upper and lower bolt on each side...
Thanks!
itasor is offline
post #2 of 3 Old 06-11-2008, 08:15 PM
Wiki-USMC
I just changed my rear shocks and didn't tighten the bolts to any specific ft lbs, it didn't seem an important area to be so precise. Just make sure they are decently torqued because you will get some clinking noise if you don't... and don't forget your LocTite!
Wiki-USMC is offline
post #3 of 3 Old 06-12-2008, 08:48 AM
Mickey63
2006 WK
Rear Shocks
Tighten the upper mounting bolt/nut to 95 Nm (70 ft. lbs.).
Tighten the lower mounting bolt/nut to 115 Nm (85 ft. lbs.).
Mickey63 is offline
Changing front shocks- no room for leverage or tools hanxtr ZJ Grand Cherokee Forum 9 05-18-2009 06:36 AM
Changing Oil in Rear Diff QM2Rick ZJ Grand Cherokee Forum 38 12-28-2007 05:03 PM
Changing rear brake pads... jeeper_creepers ZJ Grand Cherokee Forum 3 08-19-2007 01:57 PM
tips or tricks for changing my shocks ??? jpbellis ZJ Grand Cherokee Forum 10 12-05-2006 02:50 PM
Changing rear driveshaft W4x4J ZJ Grand Cherokee Forum 18 01-07-2006 04:39 PM
