Changing out the UCAs - JeepForum.com
post #1 of 32 Old 10-15-2012, 08:49 AM Thread Starter
Budasac
2005 WK
For those of you who have swapped UCAs, can it be done without removing the strut assembly. I need to replace my UCAs and the bushing on the LCA where the strut fork attaches. I have a very limited window of time to make the repairs and I'm trying to determine how involved it's going to get.
Budasac is online now
post #2 of 32 Old 10-15-2012, 09:52 AM
JeepN4KC
Keep on Jeepin on........
JeepN4KC's Avatar
I don't see why you couldn't just jack the front end up, let the IFS droop, unbolt the fork and swap the bushing, unbolt the UCA and bolt, swap in the new UCA and put it all back together - never unbolting the strut tower bolts or removing the assembly.
I don't know - I'm trying to imagine this in my head w/o looking at my WK but it seems doable.
~Mike~
WK
XJ
Sept '13/Jan '15/Jun '16 COTM
JeepN4KC is offline
post #3 of 32 Old 10-15-2012, 11:19 AM Thread Starter
Budasac
2005 WK
That was the plan, but looking at it I question if the UCA bolts will clear the spring when removing them. Just want to know if any one was successful in doing this, or should I just plan on pulling everything. I like to know exactly what I'm getting into before I start. If I have to pull it all it's not that big a deal but, since I'll be wrenching solo, I'd rather not have to deal with re-installing the springs without a second set of hands.
post #4 of 32 Old 10-15-2012, 11:41 AM
SSF556
2008 WK
This
Silver WK Club Member #1
2008 CRD QT2
SSF556 is offline
post #5 of 32 Old 10-15-2012, 02:42 PM
jstand22
One UCA bolt on each side will not clear the strut assembly....all you have to do is take mounting nuts off the top, let everything sag, and move the strut like 1 inch and you're all set....you don't have to take it out. Otherwise you'll have to sawzall that one bolt out on each side.
jstand22 is offline
post #6 of 32 Old 10-15-2012, 03:40 PM Thread Starter
Budasac
2005 WK
Thanks, that's what I wanted to know. I was kinda hoping that once the springs were fully extended the bolt might fit between the coils. oh well. It shouldn't be bad. Just not thrilled about dropping $450+ on parts.
post #7 of 32 Old 10-15-2012, 04:06 PM
06WKHEMI
2006 WK
I hear ya dude kolak just got $650 from me lol
2006 Black wk overland HEMI QDII. OME HD bilstein struts with 58643 monroe load levelers RRO uca, afe cold air intake,hella 500FF behind grille, RC 1.5 wheel spacers s4xc cb antenna mount with 5ft firestik and midland 1001wx CB,265/70-17 falken rockymountain ats, pinch weld mod, door lock mod, Rola basket with 2 Hella 500 FF`s.
06WKHEMI is offline
post #8 of 32 Old 10-15-2012, 04:31 PM
hoaxci5
1995 XJ Cherokee
^ This, I ran into the issue also when installing my JBA UCAs.
Unknown - 1995 XJ - 4.5 RC lift, drop brackets, 33" MT's, SYE, Custom Bumpers/Rockrails
Rambo - 2007 XK Limited 5.7 - OME HD - Monroe Load Levelers (F150) - Flashpaq - RRO SuperSliders - 4XGuard all over - SOLD
hoaxci5 is offline
post #9 of 32 Old 10-15-2012, 05:00 PM Thread Starter
Budasac
2005 WK
So you dropped the strut a little as well? What if I bought replacement bolts and just cut the old one off and installed the new one from the inside? Does that save me any time?
BTW Hoax, did I see some where on UJ that you moved to the East Coast?
post #10 of 32 Old 10-15-2012, 05:13 PM
hoaxci5
1995 XJ Cherokee
Yea I'm pretty sure I loosened the 4 top bolts on the strut until they where almost off, and maybe even loosened up the bottom pinch bolt.. I can't remember for sure, and it was kind of a pain in the *** still as I recall.. I think I was doing it when I had my RRO 2.25 lift in place so that might make a difference also since spacers would move the spring to a different location.
Omelet said he removed his and reversed them in case he needed to remove them again. I'm not sure about cutting them, I think they are pretty stout and it might be quicker to just drop the strut at that point.
Yes I moved.... currently in Elkton, MD while we wait to close on a house in Claymont, DE (we were supposed to close 9/28 but dealing with some property line issues..) come out to RC Oct 27th weekend, there is a pretty good sized group planning on going.
hoaxci5 is offline
post #11 of 32 Old 10-15-2012, 06:05 PM
Omelet
Evil Overlord!
Omelet's Avatar
2005 WK
Yep what Jake said! Don't reinstall the bolts like they come from the factory (From the inside out) install them from the outside in. That way you never have to worry about having to remove the strut to remove the UCA again, whether it be in the driveway or on the trail
Omelet is offline
post #12 of 32 Old 10-15-2012, 06:06 PM
YB Normyl
YB Normyl's Avatar
2016 JK Wrangler
To remove the bolts I used a spring compressor to maneuver the coil spring up or down but it was a real pain, then I inserted a little shorter bolt the opposite way. You could cut the bolts too, loosen them a bit and try to cut the head off so you can slide them the opposite way.
YB Normyl is offline
post #13 of 32 Old 10-16-2012, 05:26 PM Thread Starter
Budasac
2005 WK
Ok, so I'm just gonna plan on pulling everything. I'm ordering the JBA UCAs tonight along with the bushings for the lower strut fork bolt. I'm thinking I should replace the lower balljoints while I'm at it since they're only about $60 and I'll have it all apart. Sway bar bushings and endlinks were recently replaced, is there anything else anyone can think of that I should do while I'm there?
post #14 of 32 Old 10-16-2012, 07:32 PM
DavidsCyclops
2014 WK
I have replaced them before on a 2005 wk.
Jack the vehicle up and put the frame on jackstands.
Place a jack under the lower ball joint/control arm.
Then once you loosen the UCA bolts you can raise and lower the jack, which will compress and decompress the spring, and you can place it where you want it to slide the bolts out.
Same thing for putting them back in.
DavidsCyclops is offline
post #15 of 32 Old 10-17-2012, 04:54 AM Thread Starter
Budasac
2005 WK
Nice, welcome to the East Coast. I'd love to hit RC but that's the only day I have an opportunity to work on the Jeep. Coaching sucks up all my time. Right now football and wrestling season are overlaping so I have no days off at all.
BTW are you still rockin the beard???
